So, I've been toying with my Q9450 C1 on a Gigabyte GA-X48-DQ6 (the DDR2 version)... I'm coming from an ASUS mobo background and trying to get my footing...
*** Most importantly: how can I tell what the DEFAULT "AUTO" VOLTAGES are so that I can properly compare them and adjust them versus what others are getting? The whole +1/-1 system is a touch annoying. ***
I have a few overclocking questions with respect to this combo. Generally, I'm trying to get an idea of how to translate the few BIOS changes it permits vis-a-vis the BIOS settings I read others are using.
Using FULL AUTO on ALL of the voltage selections, I can easily amp the Q9450 to 3.6 GHz (8x450), but it seems awfully hot (50 C idle, 70 C at load - as read by RealTemp, I know CoreTemp reads 10C higher due to an incorrect TJ Max) [prime stable at around 1hr+, I was afraid to run it longer than that due to the temps]. On full auto, it is putting the CPU volts at 1.45 as read in CPU-Z in Windows Vista Ultimate 64-bit, which I can only imagine means nearly 1.50 in the BIOS. If I take it OFF of full auto and even if I manually set this to 1.45, and nudge up a bunch of other items by 0.15, I can't even OC it to 3.2 GHz.
Someone, please, help me translate the volts so I know what to set.
I wish anyone that posted an O/C also posted EXACTLY what settings they used, as they appear in the BIOS, leaving nothing out. It would help the newb-ier among you greatly in discerning which items matter most.
