(with a huge clock deficit,2.3Ghz Vs 3.16, 2 socket configurations)
Taken from RWT forums,the latest entries from spec:
http://realworldtech.com/forums/inde...89784&roomid=2
that green font is unreadable... show me benchmarks relevant to what we do on xtremesystems, we already know amd does well in server tasks with muti-socket setups.
Core i7 920 3849B028 4.2ghz cooled by ek hf | 6gb stt ddr3 2100 | MSI HD6950 cf cooled by ek fc | Evga x58 e760 Classified | 120gb G.Skill Phoenix Pro | Modded Rocketfish case + 1200w toughpower | mcp 655 pump + mcr 320 + black ice pro II
Great! Yawn.....
let me go out and grab a Barcelona, NOT.
Asus Z9PE-D8 WS with 64GB of registered ECC ram.|Dell 30" LCD 3008wfp:7970 video card
LSI series raid controller
SSDs: Crucial C300 256GB
Standard drives: Seagate ST32000641AS & WD 1TB black
OSes: Linux and Windows x64
This isn't terribly shocking.... Intel will choke on heavy BW apps like this compared to Barcelona.
One hundred years from now It won't matter
What kind of car I drove What kind of house I lived in
How much money I had in the bank Nor what my cloths looked like.... But The world may be a little better Because, I was important In the life of a child.
-- from "Within My Power" by Forest Witcraft
Is this a lukewarm response from intel fanboys that I'm feeling?
And personally, meh.
E7200 @ 3.4 ; 7870 GHz 2 GB
Intel's atom is a terrible chip.
im assuming this is a fsb bench lol
DFI P965-S/core 2 quad q6600@3.2ghz/4gb gskill ddr2 @ 800mhz cas 4/xfx gtx 260/ silverstone op650/thermaltake xaser 3 case/razer lachesis
Nehalem will have double the bandwidth of Barcelona anyway.
No matter how powerful a core is , if the memory subsystem can't feed it with enough data , it will lose BW dependent tests.
Barcelona has a 40% frequency deficit, but enjoys a 300% memory BW advantage ( + lower latency ) .The later more than compensates.
Intel will ship Nehalem in Q3 , it is in a hurry simply because there are a few apps where K10 offers a decent platform vs. Xeon.Nehalem will change that across the board.
Fast computers breed slow, lazy programmers
The price of reliability is the pursuit of the utmost simplicity. It is a price which the very rich find most hard to pay.
http://www.lighterra.com/papers/modernmicroprocessors/
Modern Ram, makes an old overclocker miss BH-5 and the fun it was
don't care. I want performance in things I do and a synthetic that's not even widely used by benchers is not something I do.
this is a 2cpu with 4cores each so there is no comparison from the amd using ecc and the intel with FB-dmm, this dosnt reflect a desktop chips at all
5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
Flame thread... flame thread !
Let's not take away the key strength Barcelona brings to the table gentlemen. Argue the data, not with who is fan of what...
Barcelona has much better aggregate BW available to it... the Spec scores for this bench are very high throughput demanding loads, Barcelona should shine here if the load is limited by the pipe giving or taking data from the cores. If the bench were CPU core limited, the story would be different.
Spec scores are up for barcelona on both the FP, Int and the rates, the data says the same thing... in core limited workloads Harpertown/Clovertown is strong, in BW limited workloads Barcelona is strong.
Intel leads signficantly in SpecInt, AMD is leading (adjust for clock speed) in SpecFP_rate. The data is availble here:
www.spec.org
Jack
My buddy does procurement for an investment bank's server farm. I play Crysis. He's psyched about Barcelona. I like Penryn. What's to argue about?
165 @ 2.9 @ 1.45V | 2x1GB G.Skill HZ | NF4 Ultra-D
MSI X1900XTX | G500 21" Trinitron
X-Fi Fatality | Z-2300s | Little Dot MkIII | Beyerdynamic DT770 Pro
TDX | Maze4 GPU | DDC Topmodded | BIP3
Stacker STC-T01
wow, so after months and months of looking for a bench where barcelona outperforms c2q cpus, they finally found one
Well, if there was no such thing as Nehalem this would be something. Still the Opteron was a great processor so there's no wonder these are good at certain tasks. Too bad they don't at above 3Ghz properly...
Sorry, I'm snipping this post as I didnt realise this was a server chip when I posted it.
Yea, i'm a dunce at server stuff (puts on dunce hat and goes to sit in the corner)
opteron's have their place and with 4cpu setups they work the best
Snipped too, see above post for why
That many?
There is also the memory BW benchmark. So thats up to 3 cases now!
But again, if you run this kind of things you would use a single Sparc T1/2 chip thats designed for this and get a score of about 37000. So nobody would buy Barcelona or Xeons for this if performance mattered.
Crunching for Comrades and the Common good of the People.
LOL, what a pathetic and fanboyish thread.
An AMD configuration marginally outperforms Intel configuration in 1 benchmark and somebody made a thread about it, claiming superiority of the AMD configration.
If anyone didn't noticed yet, the Intel system is using Harpertowns with FSB 1333MHz and FB-DIMM DDR2-667. There are Harpertowns with FSB 1600MHz(X5472, X5482 and QX9775) and FB-DIMM DDR2-800 which are outperforming Barcelona in SPECweb2005.
This thread is misleading and pointless and IMO should be removed.
