Results 1 to 24 of 24
Thread: [Team.AU] 3DMark Single Card Damage (3D'03 WR?)
    Turkey Man
    Mar 2005
    Jakarta (ex-Australia)
    My second session with 9800GX2 on LN2, and im pretty happy in general with my first set of full 3D suite results.
    GPU clocks vs OCP was a constant battle, with '06 able to do significantly higher clocks than the rest at the same temp and volts.
    Spent a long time trying to get '05 Firefly to pass, only to find Canyon tripping it worse.
    In '03 it was Nature being difficult.
    In '01 i was suprised by DL, while the rest could run at much higher clocks.
    As usual Firefly '06 was the OCP tripping test.
    With only 30L LN2 i wanted to get the full set of tests covered, so none are particularly optimised (definately not '01 heh).
    System
    Intel QX9770 on LN2 (Astra pot) @ -140C to -165C
    Gigabyte GA-X48T-DQ6 (F4 Bios) with Vcore mod
    Gigabyte 9800GX2 on LN2 (XFX Bios, Tek9 4.0) with VGPU/VMem/Cap mods
    Patriot 1866MHz DDR3 @ 2.25V
    Western Digital WD5000AAKS SATA
    Windows XP SP2 general benching install
    NVidia 174.88 Driver
    3DMark'06 - 29661
    3DMark'05 - 36544
    3DMark'03 - 93726
    3DMark'01 - 107419
    Jan 2005
    belgium
    u got a lazzy 01 bro
    http://service.futuremark.com/compare?2k1=9367485
    for compare , 300mhz less cpu power and same DL :s .
    but for the rest good run and nice score's T_M
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Not bad at all...
    Keep pushing it...
    Xtreme X.I.P.
    May 2004
    Hammel/Denmark
    Very nice T_M
    The 01 problem is the driver. Either you have to run CH first with the driver you use, or use 173.67 driver, and run it in normal order
    Also..did you use LOD for nature? if not, it looks like the cold hit it, and dropped the FPS. should be 1500+ fps sometime the coldbug comes for a milisecond, and its hard to notice, but drops the fps by a lot.
    The whole world's hip and thats not cool !
    Rip Van Hippy
    Doesn't expecting the unexpected make the unexpected the expected ?
    Light travels faster than sound. This is why some people appear bright until you hear them speak
    One-Eyed Killing Machine
    Sep 2006
    Inside a pot
    Tim, where's AquaMark 3 ?
    Nice scores, apart from 3Dm2001se, but like you said you didn't have the time to tweak them properly.
    Anybody tried 174.93 with 3Dm2001 ?
    Banned
    Feb 2008
    Buffalo, NY
    Nice work man! Congrats on the 03WR! I am also curious about AM3 did you run that one?
    Edit: And VERY nice insulating job. Any particular kind of tape you used?
    Aug 2007
    Greece
    Nice Tim OMG, that 3D 03 run is literally breathtaking ... Yeah, if I recall well ... there is no greater score in single 03 ! Must be a WR
    Everything's great ! You used only 30 liters of LN2, and benched the whole suite (well apart from the new Vantage, but a bird told me some things about it that made me kind of sad ), using a VGA that has a really, really annoying OCP problem ...
    The only thing that I don't like, is 3D 01 ... But 174.xx are bugged drivers ---> low Nature and low CH ... Using 173.67 and the correct LoD settings could easily get you > 111k
    Awaiting for more thrilling results !
    Xtreme Legend
    Mar 2005
    Australia
    congrats on the W.R. Tim
    Team.AU
    Got tube?
    GIGABYTE Australia
    Mar 2005
    NJ
    Doesn't Sham's 97K 03 count? Definately nice runs though!!
    Only Extreme Need Apply
    Nov 2006
    Singapore
    that 06 is really higher!
    driver t_m?
    good work man!
    till i find another 5.6ghz cpu hahahaha~ catch ya soon. i wont be meeting ya in tw. so.. have fun the week after!
    Buildin
    uncore challenged...
    Feb 2006
    ontari-ho (canada)
    very nice session Tim, really putting it all together in these runs with that setup. congrats on the killer scores
    i don't quote in my signature, but best WR ever...
    Quote Originally Posted by Jor3lBR View Post
    It holds the current WR for the least vcore required to run 4500Mhz stable (1.32vcore)
    i can't even make that shyt up ^^^
    Turkey Man
    Mar 2005
    Thanks guys, yeah '01 has never going to be good (and never has been for me) and here is how that particular run went (which was the first completed run after failing DL a few times):
    5L-8L remaining
    LOD 3.9
    CPU - 5600
    GPU - 930 / 1124
    N-CH-DL-DH-LL-LH-CL x 3
    Submit 106k score
    CPU - 5660
    GPU - 980 / 1154
    Rerun N-CL-CH-LL-LH
    Submit 107k score
    Wow, 97k '03 from sham is going to be hard to beat without OCP mod or coldbud BIOS.....
    This is my last LN2 run for a couple weeks so I might pull apart the card and do some '01 tests on air
    I did run AM3 but it started doing that annoying crashing after explosion before score thing.
    Getting sick of it happening so i just moved on.
    xwards
    Guest
    great scores
    I am Xtreme
    Jan 2005
    Congratulations on the 3DM03 single card record, Tim!!
    Shame on you for that crappy 01, though
    Where courage, motivation and ignorance meet, a persistent idiot awakens.
    Nov 2005
    Sweden, Örebro
    Great runs, but I hate to be a killjoy. You're still about 400 points short of the 3DMark 03 record. linky
    If anyone can do it, it's you
    //Andreas
    Master of nebulah frost
    Dec 2004
    Dolomites(Italy)
    Really good resuts as always T_M
    And really good QX
    Battlefield 3: Nachthymnen666
    Sep 2007
    Australia
    Nice runs T_M.
    So AM3 dosn't only do that for me
  18. #18
    Team KOC2.com
    Nov 2005
    Indonesia
    nice run there bro... the astra pots looks Great
    E8600 Q820A750
    DFI LanParty UT P35-T2R - Abit IX38 QuadGT - Asus P5B Deluxe - Biostar TP45 HP
    Team Xtreem PC-5300 C3 2GB - Crucial 10th Anniversary 2GB - Team Xtreem PC8500 C5 2GB
    Winfast 8600GT
    Silverstone Olympia 1000w
    andre X_X -72c CO2 Cascade
    My R22/CO2 Cascade Project
  19. #19
    Champion
    May 2006
    Bangkok, Thailand
    Very nice results Congrats for WR Tim
    Sorry For My English
    OverclockZone Team
    THAILAND
  20. #20
    Memory Addict
    Aug 2002
    Brisbane, Australia
    congrats Tim.. looks like those patriot DDR3 are doing nicely too
    no youtube vid this time ?
  21. #21
    Oct 2002
    Florida
    Quote Originally Posted by harleybro View Post
    thats what i was thinking 97048
    Win7 64 Ultimate
    i7 930 - 4200mhz 24/7 - Dtek v2
    ASUS P6X58D-E
    2 x MSI 6970's xfire
    3 x 2gb G-Skill 2000mhz
    Samsung 27" LCD
    SilverStone ZM1200w psu
    2 x 300gb WD Velociraptors Raid 0, 4TB storage
    PS3-used mostly for bluray and media server
  22. #22
    Jan 2008
    Sweden
    he he always the drivers fault, nice results!
    24/7 Setup: Asus maximus x38 / E8500 E0 (500x8) Dtek Fuzion / Ballistix old rev 4-4-4-4 @ 1000MHz / 2900XT Ek fullcover cf / Silverstone TJ-07
    Bench: Commando / Tpower i45 / P5K / E8500 E0 @ http://valid.x86-secret.com/show_oc.php?id=433935 / modded mach2 r507 / Old rev ballistix /
  23. #23
    Sure it does
    Shams owning EVERYONE LOL ...97k+ single gx2
    He doesn't care about hwbot.
    Still nice work though team AU.
  24. #24
    Turkey Man
    Mar 2005
    Thanks Vince.
    @ begrip, i never blamed the driver. Im the first to admit that '01 is my weakest bench.
