Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Thread: 9800GTX iandh ramsinks
    Mar 2008
    can you give us an ETA on these please iandh. I really want to get my graphics cards back on water and am waiting till petras gets yours in stock.
    Oct 2006
    South Africa
    +1 here I need a set badly.
    920 c0
    6gig Mushkin 1600 6-7-6-18 (Many thanks to TheGoatEater)
    285gtx
    Dfi x58 t3eh6
    Mar 2007
    They're done.
    Should be at petra's tomorrow or wednesday, sidewinders will arrive shortly after.
    Asus G73- i7-740QM, Mobility 5870, 6Gb DDR3-1333, OCZ Vertex II 90Gb
    Oct 2006
    South Africa
    Awesome thanks
    920 c0
    285gtx
    Dfi x58 t3eh6
    Mar 2008
    sweet thank you, i'm off tomorrow so i'll be able to order them right away hehe
    Oct 2006
    South Africa
    Available at petra's now btw
    920 c0
    285gtx
    Dfi x58 t3eh6
    Aug 2006
    What water block are you guys using for your 9800gtx? Nice Memory & VRM cooling kit iandh!
    Feb 2007
    Do we need TIM pads to use these sinks or can we use MX-2 or AC5?
    May 2004
    San Diego, CA
    Quote Originally Posted by spider_d View Post
    I would use ceramique.
    intel i7 3770k 4.40GHz
    ASUS Maximus V Extreme
    EVGA GTX 680 FTW
    16GB GSKill 2400MHz
    (1) OCZ Vertex 3 60GB SSD
    (1) Samsung 840 Pro 256GB SSD
    (1) 1.5 TB WD Caviar Green SATA
    Sound Blaster X-Fi Titanium Fatal1ty Professional
    Corsair 700D
    Corsair AX850
    Water Cooled (EK blocks on CPU and GPU, TA 120.4, DDC-1+ with XSPC ResTop)
    Mar 2008
    i'm going to use the D-TEK fuzion graphics, from the way it looks it will work because it has about the same footprint as the MCW60 that everybody is using. can't wait till they get here tuesday. Thanks for that info as well Trice, i was actually gonna ask that same qustion, i wasn't sure if TIM pads would be needed or not.
    Mar 2007
    Quote Originally Posted by moose517 View Post
    TIM pads are compatible, but a good thermal paste is recommended. I also prefer ceramique for this application.
    Mar 2006
    Los Angeles CA
    I used mx-2
    Its non-conductive, doesn't have to cure and works fine universally.
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    Oct 2006
    South Africa
    Thanx Iandh I was wondering if we needed TIM. As little as possible??
    I'm also getting this and a d-tek GFX
    920 c0
    285gtx
    Dfi x58 t3eh6
    Mar 2006
    Los Angeles CA
    Why are you going for the D-tek block, the MCW60 has much less restriction.
    EDIT, I'm dumb
    I am Xtreme-ly Unemployed
    Nov 2005
    Palmdale, CA USA
    Quote Originally Posted by aspire.comptech View Post
    Why are you going for the D-tek block, the MCW60 performs better and has much less restriction.
    Not quite... The D-Tek FuZion GFX should perform better than the MCW60 on bare-die GPU's but, as you mentioned, it does so at the cost of overall system flowrate due to its rather high pressure drop. Now, if you're handy with a drill and have some small-ish drill bits, you can very easily reduce the pressure drop of the FuZion GFX (though, I haven't established how much of an impact on performance this modification results in).
    I'm doing science and I'm still alive...
    Oct 2006
    South Africa
    The D-tek performs better and I will only have gpu + nb in that loop
    920 c0
    285gtx
    Dfi x58 t3eh6
    Mar 2007
    Basically enough TIM to cover each chip well. Sometimes it takes a couple of fits to get perfect contact. A circuit board is hardly a flat precision surface; some are quite warped.
    Put a dab on each component, screw down the sinks gently, remove them, add more TIM as needed to any chips with bad contact, and then adjust the rest out using the screws.
  18. #18
    Feb 2007
    On Order
    I ordered a black anodized set of these today from Petra's Tech Shop. I can keep my MCW60 for a fourth video card! I love the idea of full cover, but that would have been over $400 and I've spent more like $100 with good or better performance.
    I have used ramsinks in the past and I am sick of the added effort. I am trying to reduce the number of times that I pull off a Vreg or mem chip (happened twice now).
    Thanks Iandh and thanks Petra for the fantastic, way above average, better then any dealer that I've dealt with, service! It's almost like the guys at Petra's enjoy their jobs and enjoy delighting their customers.
  19. #19
    Nov 2005
    Palmdale, CA USA
    That's because we do
    Quoc and I do this whole bit because we love helping the community in any way that we can (it's just convenient that the method of helping we've chosen occasionally allows us to buy food ).
  20. #20
    Mar 2006
    Los Angeles CA
    Quote Originally Posted by Petra View Post
    And the occasional BMW
  21. #21
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Circles SucQ!
  22. #22
    Nov 2005
    Palmdale, CA USA
    Hey, you leave my leased South African tax write-off out of this...
    ...or I'm going to have to tell everyone about that extravagant bicycle of yours
  23. #23
    Banned
    Feb 2008
    Slappyville - North Bay,CA
    I used mx-2
    Yup read on one of thereviews compairing all the best of them that mx-2 came in 2nd & is non=conductive with no cure time and lasts for at least 8 years
  24. #24
    Banned
    Feb 2008
    Quoc has been the best help i've ever had !
    these guy's are great
    still pulling my rig together
    anybody pull all the stock cooling off yet ? & what did you replace it with ? I'm testing the mobo tomorrow to make sure it's not DOA & them off with stock cooling (freeZe sounds the best way ) gotta go.... just got the box from Quoc some extra goodies L O L ! one day service thanx Q
  25. #25
    Mar 2006
    Los Angeles CA
    I wish I had an extravagant bicycle...
    Damn thing only lets me shift when its in a good mood, and even then it doesn't ever let me get into 3rd gear on the main sprocket...
    Also my rear tire seems to have a small leak so that after a bout 2 days it will get flat. And I've been too lazy to fix it. lol
