My samples ... every with P45/G45 ...
GA-P45-DS4
GA-EP45-DS5
GA-P45-DS3R
GA-G45M-DS2H
I have lot of hi-res photos here ...
here is one example ...
GA-P45-DS4
GA-EP45-DS5
GA-P45-DS3R
GA-G45M-DS2H
thanks for the contribution OBR
High res... Sure, the resolution is high, but the focus is crap
Numbers please.
Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
Yeah, this is only first shot ... i will make better for reviews later ... BUT i am sure every of these board are DEAD! On this planet does not exists fully working Gigabyte P45 board (except Giga factory) ... but one with working PCIe is on the way to me (Extreme One) ... results later.
no DQ6?
i5-750 w/ Thermalright Ultra120X
Coolermaster HAF-932
MSI GD65
2x2GB G.skill Cas7 1600MHz
Sapphire HD6870
Western Digital 640GB.AAKS
2x Samsung F1 1TB
2x Samsung SLC 64GB SSD
Pioneer DVR-212BK
Corsair HX620W
Creative X-Fi Xtreme Music (dead, using onboard -.-)
LG W2286L
gotta save something for later hey hehhe
Any chance of closeups of the EP45-DS5?, so we can see the layout/chips better?
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
You must [not] advance.
Current Rig: i7 4790k @ stock (**** TIM!) , Zotac GTX 1080 WC'd 2214mhz core / 5528mhz Mem, Asus z-97 Deluxe
Heatware
Sooo many sata ports I will never use, but I'm likin the ds5. Perhaps there is a dq6? =P
x6.wickeD
I'm confused by that DS5, 6 SATA ports (yellow) controlled by the Intel ICH10R, ok. Then we have 2 Silicon Image controllers, SiI5723...each chip controls 2 Purple ports....thus 10 in total.
So how the hell are they supporting IDE and the PCI bus?, the labeled "Gigabyte SATA II" chip is actually a rebranded Jmicron controller...but what chip is it?, JMB363 or JMB368?....if it's 368 then that acts as a PCI-E to IDE controller, which will give it IDE support.
So, how the hell are they getting PCI bus support?, i see no chips that function as this, unless this Jmicron chip is new and is acting as an IDE and PCI bus controller.
OBR....give us some insight.
Something else i noticed, the solid capacitors no longer have the black plastic shrouder around them, they like support the capacitor on the PCB.
GA-G45M-DS2H looks sweet!
xcept for those s-ata ports!
ny specs on it? pci express 2.0 x16?
...building hardcore mini workstations...
Why can't they put the Floppy connector at a 90 degree angle????????
Hold on...do i see bios flash parts located close to the Silicon Image chips?, does that mean then that we/consumers can flash the bios/firmware on these chips as needed?
today tedailed pictures ... wait
There are definately bios flash chips for the Silicon Image controllers....so we should be able to flash the firmware as and when new revisions become available.
The Power/Reset/Clr CMOS buttons are in a bad location, they should located higher up the PCB...next to the front panel header connectors.
Any new info or pics?
i am testing now AMD nForce 780a platform, result of first working P45 later this week ...
