You can download it here
Description:
Crosshair BIOS release version 1103.
1. Fix System fails to detect Optional fan 4# and 5#.
2. Fix system might not get booted with AMD Semprom 2800+ CPU.
3. Hidden virtualization Technilogy option when installed CPU does not support this feature.
4. Fix it might fail to run certain AMD utilities under Microsoft Windows Vista OS with AMD AM2+ CPU installed.
5. Fix system might fail to overclock when using AMD AM2+ CPU.
6. Enhance compatibility with certain add-on RAID card.
7. Fix LAN might fail to work after system resumes from S3 mode.
8. Fix system might fail to resume from S3 mode when using AMD triple-core CPU.
Fix number 5 is the most imortant one as you never knew when you actually overclocked it. Tempted to test my crosshair again as it's extremely mem tweakable
