Results 1 to 7 of 7
Thread: E2140 G0 stepping = neutered conroe?
    Nov 2007
    I know the E2140's are not supposed to have G0 stepping, but check this out......
    Unfortunately I hit FSB wall around 440, missing out on the 2GHz overclock.
    spec number is SLALS, which is not even recognized on intel's own website.
    batch L719B.
    On closer inspection the caps on the underside of the chip are set out the
    same way as a G0 conroe instead of an allendale, so I think these are just
    neutered conroes.
    E5440 @4GHz
    ip35-E
    4x1G ddr2-800
    msi 7850 1G
    antec earthwatt 380
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    wow over 400 fsb thats amazing that rez must be way better than the Mx
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    I am Xtreme
    Sep 2006
    That's a nice OC mate mine was stuck at 410FSB but I was already happy with the 100% OC... too bad they didn't leave extra cache too
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    G0 efficiency is improved- Clock per clock you should get better numbers than the M0?
    Where did you get the chip? My own E2140 does 437 under water so not much of an difference, but every little helps
    you sigged that?
    why?
    ______
    Jul 2007
    California
    @Teh neutered core part, yeah it pretty much is...
    Intel for some reason changed the name of all the lower end Conroes to "Pentium Dual Core", not to be confused with the heatsink-melting Prescotts.
    Really retarded imo.
    If you get an E2180, it will also show up as a "Pentium Dual Core".
    1.7%
    Jun 2007
    I have G0 E2140 with me now
    did a rush bench few days ago,
    stock vcore (1.264v) 3.6GHz Super Pi 1M passed
    changed to crucial 10th anny later on,
    3720MHz achieved. Super Pi 1M again.
    Sorry no 32M or orthos yet,
    will try them soon.
    My rig
    Jun 2007
    oh ya,just now i didn't attach cpu-z validation link,
    here you go,
    http://valid.x86-secret.com/show_oc.php?id=352236
