XtremeSystems Forums
Go Back   XtremeSystems Forums > Cooling > Vapor Phase Change Cooling
Reply
Old 04-10-2008, 10:10 PM   #1
FUGGER
Xtreme Owner
FUGGER's Avatar
Send a message via MSN to FUGGER
Cryo-Z initial notes
The units came pre-tested, both arrived intact and no damage.
The shipping carton is styrofoam panels and the base has holes for the feet of the cooler to prevent shifting in the carton.
The cardboard top is an upside down box that drops over the unit and straps are needed to secure the whole thing together.
The straps double as handles, it is natural to grab the straps and lift the unit, they can support the weight easily. This also keep the units upright for delivery.
The neck has a channel that it sits in during transport and the head has its owns foam socket.
The evaporator and mounting is chilly1 based, a retention clip holds the head assembly on.
The compressor is made by Zel and has a few minute timer to prevent quick restarts, so far it has not been a problem, defeating the timer might reduce the life span of the compressor.
They are charged with R507 and set for -50c idle
The case looks good but on very close examination you see gap flaws and other minor blemishes, function over looks is to be expected. OCZ kept the costs down, this was an area they were able to deliver a good looking unit and retain quality. The outside shell is bolted in the back and slides off similar to a PC case. Inside is a square frame with solid steel top. The controls are mounted on the underside of that steel plate. Screws are used, no rivets.
The routing of the Z logo and vent holes are clean and finished, no burrs or blemishes in the routing on both units. There is black screen mesh behind the logo and vents for a more stylish appearance.
The display is simple with scrolling OCZ, evap suction temp and ambient temp.
The harder I run the CPU the colder the suction temp reads.
No white packing foam was present inside units.
The finish on the blocks is acceptable, both are correctly finished, brazing is clean.
The lineset is a little longer than those found on competing units.
The controller is setup to start the compressor and drop to -30 before the PC starts, the unit will shut down at 70c if the cooling fails.
A molex for power and rewire the power button (unplug from mobo and connect the wire from the cooler) and that is it for wiring. No external controller.
My first setup is a 790i with E8400, breaking 5Ghz is no problem at all and benching at 5.2Ghz now.
Firing up the cooler with a motherboard and power is the best route, hot wiring the unit is not advised.
I believe 5Ghz 24/7 is definitely possible with an E8400 or E8500, the quad I am yet to run.
I expect these to sell out the first day, they are equal to a chilly1 single stage charged with R507. It would be advisable to watch the forums for the minute when they do go on sale if you are planning to buy one.
The BE did not arrive today.
__________________
Intel Core i5 661 @ 4.6Ghz
Gigabyte P55A - supports 32nm now
Gigabyte GTX 260 SOC
Corsair Dominator 8GB 2200C8
Intel SSD RAID 0
http://valid.canardpc.com/show_oc.php?id=925582
FUGGER is offline   Reply With Quote
Old 04-10-2008, 10:28 PM   #2
pak
Noisy? Could you compare the noise it makes to something?
--pak
__________________
Q6600 400x9 1.5vcore
P5kdeluxe Ballistix 2x1gb
D5 coolrad32t Fuzion
EVGA 8800GTS 320 600/900
2xRaptor 36g Raid-0
Creative X-Fi Extrememusic
PCP&P silencer 750 copper
Built for the sole purpse to play World Of Warcraft and troll XSforums.
Heat
pak is offline   Reply With Quote
Old 04-10-2008, 10:31 PM   #3
FUGGER
Xtreme Owner
FUGGER's Avatar
Both units sound exactly the same. Exactly like a new good running phase unit should sound. The compressor is a little louder than the fan, not by much.
I will bring a DB meter home from work tomorrow.
__________________
Intel SSD RAID 0
Old 04-10-2008, 11:41 PM   #4
biglipzit
I am Xtreme
biglipzit's Avatar
Send a message via AIM to biglipzit Send a message via MSN to biglipzit Send a message via Yahoo to biglipzit Send a message via Skype™ to biglipzit
I am just really interested to see what the max load it can hold is. Will you be putting this on a set dummy load to show us proper load testing temps?
Daniel
__________________
Thermaltake Xaser VI Case
Gigabyte MA790FXT-UD5P
AMD Phenom II 955BE
Dual Sapphire 3870X2's
4 gigs of Kingston HyperX DDR3 333mhz
Coolermaster V10
Coolermaster UCP-1100W PSU
Originally Posted by {GOD}Raptor22
I find it exceedingly humorous how you sit here and continue to play keyboard warrior even though you know you are wrong.
biglipzit is offline   Reply With Quote
Old 04-10-2008, 11:44 PM   #5
metro.cl
Xtreme X.I.P.
metro.cl's Avatar
Send a message via MSN to metro.cl
i just wish they made a unit for 220v and sell it outside US.
__________________
metro.cl is offline   Reply With Quote
Old 04-11-2008, 12:00 AM   #6
[XC] gomeler
Diablo 3! Who's Excited?
[XC] gomeler's Avatar
Send a message via AIM to [XC] gomeler
Could maybe find a builder in the US willing to drain/chop/cap the lines and ship an empty unit to an European builder who will drop in an NF11F and recharge the unit? It might still end up being cheaper than a VapoLS/Mach II even if it is a ton of effort.
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
[XC] gomeler is offline   Reply With Quote
Old 04-11-2008, 04:10 AM   #7
Clemmaster
Clemmaster's Avatar
Send a message via MSN to Clemmaster
What about true temperatures? Did you set a K-probe on the CPU?
First tests on a TEC wasn't very good (especially on that kind of heating element), that's strange....
Clemmaster is offline   Reply With Quote
Old 04-11-2008, 04:19 AM   #8
naokaji
I7 Fanboy
naokaji's Avatar
with so much effort it would probably be better to buy from a european builder since the price advantage of the cryo-z would be gone, we have a fine selection of builders, so thats not really a big problem (piotres for example).
Good to see that the units Fugger got are working fine, will be interesting to see how they do with quads, finally they are real, all the speculation, drama, delays are over and there are real cryo-z units out there.
__________________
920 D0, EX58-UD5, 6GB Corsair 1600 7-7-7, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's. Seasonic M12 700W, Cosmos S
Loop1: Swiftech GTZ, Koolance 4870x2 FC, Laing DDC 3.2 with XSPC Res Top, Blackice GTX 360
Loop2: Mips Gigabyte x58 blocks, DDC 3.2 with EK top, pa120.1, xspc acrylic 5,25" res
Come crunch with us for the Cause at WCG, we don't bite
I deny any responsibility for hearing loss or Overspending at PC Shops.
naokaji is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
