Results 1 to 5 of 5
Thread: FLEX MODE?? add stick to channel 0 or 1?
    Mar 2008
    90706 so cal
    I already have 2 sticks of the f2-8500 mem. i bought 1 more stick to have 3gb for vista 32. didnt want to use 2 b/c thats alot of stress on mem controller plus vista cant see and effectively use all 4 gigs.
    The board im using is a ga-p35-ds3l. the MCH is suppose to support Intel Flex Memory. (2 gigs in dual channel, last in single when needed by a program/game) is there any preference which channel i should add the extra gig to, channel 0 or channel 1??
    Gigabyte EP45-UD3P
    Intel q6600 g0 @ 3.6 VID 1.3 9x400 @1.42V
    Asus 4890 TOP 950/975
    G Skill- F2-8500CL5 3x1, Flex mode @ 800, 4-4-4-12
    Antec TruPower New 750
    Western Digital Caviar Black 1TB+
    Western Digital RE2 5001ABYS + 160gig WD storage drive
    Raidmax Smilodon Case
    ..goodbye 939..
    Mar 2008
    90706 so cal
    ok so i added the 3rd stick to dimm 4, MCH registers flex monde on boot up, cpuz and pc wizard show dual channel operation. other 2 sticks are in dimm 1 and 3. Should i do a +.1volts to the vdimm for 3 sticks for more stability or will they run fine at 1.8v? im using them at 800 with 4-4-4-10 timings.
    Gigabyte EP45-UD3P
    ..goodbye 939..
    G.Skill USA Tech
    Sep 2005
    i never use thsi flex mode. it really works with 3 sticks with dual channel?
    do you have any problem to run in this few days?
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Mar 2008
    90706 so cal
    hi. yeah its worked fine for 3 or 4 days now.i started playing the Witcher and was having problems with slow load times and crashing. people on the witcher forum say more system memory and setting a bigger page file/virtual memory will help. i did both and the game has only crashed once since. The game use to crash every 30 mins to an hour.
    i used the f2-8500 at only 800spd 4-4-4-10 with 1.9 vdimm. it was really stable to i set it back to 1.8 vdimm. still no probs. pc wiz and cpuz show vdimm is around 1.85.
    Gigabyte EP45-UD3P
    ..goodbye 939..
    Mar 2008
    90706 so cal
    i bumped the memory speeds up to 1000 now.. 333fsb, using the 3x multiplier. voltage at 2.1 works great in flex. love g skill.!!!!
    Gigabyte EP45-UD3P
    ..goodbye 939..
