So, I've combed the internet looking for the vdroop mod for the revision 2 ds3l.
Mine looks like the on found here.
I've found mods for the ds3r, and dq6, (and for the ds3l rev 1) Nobody has cracked the code on this one yet? Does anyone know where to measure cpu volts on this mobo? (Or how i would go about finding the vdroop mod?)
The Vdroop is terrible. Bios set to 1.6 i get 1.54 according to occt @idle. Once loaded it goes all the way down to 1.47!!!!!!!!!!!!!! This is with a q6600 at 3.72 ghz. The next in bios voltage increment after 1.6 volts is 1.8 volts, which is a bit extreme, even for me. (IF THERE is a mod to bump up voltage, that would be great, and would even eliminate the need for this mod.)
I have 2 fast 120 fans above the mobo, 2 blowing air onto the mobo, and 1 sucking air out the back of my case. (i also threw on some ram sinks onto the mossfets, and power management smd's right above the cpu socket.
(the multi reading is of the video card)
Thanks !!!!!!!!!!!!!!!!!!!!!!!!!!!!
What is fb?
so any expert advice would be greatly appreciated. I measured around the fb, idroop, and fb pins, and found some very confusing results.
