04-01-2008, 07:22 AM
#1
Xtreme Mentor
9800GTX voltmod thread
Whos got one?
Please post up high-detail pics of the rear of the card and lets get things moving
__________________
Proudly using
Crucial Ballistix
Xigmatek air
watercooling by XSPC
Originally Posted by T_M
Originally Posted by soundood
you sigged that?
why?
04-02-2008, 02:31 AM
#2
Xtreme Guru
vGPU mod is almost identical to G92GT/GTS.
GDDR3 vDD (vMEM) + vDDQ are a bit trickier as they are controlled by the same 3-way buck controller. The problem is I can't tell which regulator feedback pin is for vDD and which for vDDQ just by looking at the pics as I don't have the card...
First, I would need someone to measure the output voltages of those Delta HAHE1040 chokes on the front side. One should be ~2.00v, the other under 1.5v.
__________________
You were not supposed to see this.
04-04-2008, 08:43 AM
#3
hopefully I can find a 500k so i can test it on mine!
do you think a 1k will work on this card as well?
04-04-2008, 09:07 AM
#4
Xtreme Mentor
*if* 500 Ohm is fine, 1K ohm will be fine too, but you will have a little less accuracy with voltage setting.
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
04-04-2008, 09:34 AM
#5
Xtreme Guru
K404,
What's with the "if"?
I did have the necessary measurements at hand before scribbling the "500Ω" into the pic...
__________________
04-04-2008, 09:47 AM
#6
Xtreme Mentor
Sorry- I was responding to the "preliminary"
absolutely no offence meant
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
04-04-2008, 10:00 AM
#7
Works no problem, indeed just like the 8800gts g92 due to the same primarion controller chip. used a 1k tuned down initially to 500 ohm. I was in a hurry and didn't measure the resistance at the end. @ 1.389 idle, was good for 891/2228/1235. Tried up to 1.45 idle - 900 MHz core is still not stable under water. I need to try a remount of my blocks though (swiftech mcw-60), I forgot to clean the old TIM off  it was late.
My pictures of the mod are camera-phone terrible. if anyone wans torture I can upload  .
@largon, delta chokes read 2.02V top, and 2.10V bottom. hope this helps, I can take any other readings tonight if you need them  also, the components to the right of the prim' chip look a little different... thinking towards ocp, any ideas?
here a quick 3dmark, 115 pcie. stock ram, mild overclock otherwise.
Edit: oops, got cut off. ram @800MHz, 790i Ultra
04-04-2008, 11:04 AM
#8
Xtreme Guru
SergeRY
Those voltages make perfect sense, thanks.
Dunno what I was thinking when I said the other (vDDQ) should be <1.5v...
 @ me
I doubt there's need for an OCP mod as the GTS with *just* 3 phases doesn't need it even at 900/2400/DDR-2200, those 4 phases on GTX should be enough for pretty much anything.
K404,
Heh, I was just kidding.
__________________
04-04-2008, 01:45 PM
#9
Originally Posted by largon
SergeRY
 @ me
I doubt there's need for an OCP mod ...
np, glad to help. not TOO far off
as far as ocp: I set vgpu while at bios screen to 1.4(?) it jumped to 1.505 idle in windows. this was enough for extreme instability. crashing withing 5 seconds of rivatuner. so there may still be a need if higher voltages are needed. Dunno though, maybe the 4th phase will make it unnecessary when going to colder temps (enough voltage to get really crazy without ocp removed).
just my thoughts
-serge
04-06-2008, 06:11 AM
#10
__________________
-Intel I5@4968MHz,
-Gigabyte P55A UD6,
-BFG GTX 295 single PCB,
-2gb Adata 7 7 7 20, 3gb Corsair Diminator
-Samsung Spinpoint F3 1TB + Samsung 500GB 16M + WD 250GB,
-Arkangel 850W
www.test-ing.com
04-06-2008, 07:12 AM
#11
Xtreme Mentor
is the 1.38V for idle or load?
910MHz is nice!
__________________
Proudly using
Crucial Ballistix
Xigmatek air
you sigged that?
why?
04-06-2008, 07:23 AM
#12
where are the measuring points on the card?
04-06-2008, 11:48 AM
#13
Doesn't seem worth it to me  I can bench @ 865 anyway?
__________________
920 c0
6gig Mushkin 1600 6-7-6-18 (Many thanks to TheGoatEater)
285gtx
Dfi x58 t3eh6
04-06-2008, 01:52 PM
#14
Hy everyone, same question here where can we read the GPU voltage ??
thxs
04-06-2008, 02:02 PM
#15
__________________
-Intel I5@4968MHz,
-Gigabyte P55A UD6,
-Arkangel 850W
www.test-ing.com
04-06-2008, 03:47 PM
#16
Originally Posted by cole2109
lol, thanks, my photo capabilities are severely limited
4 phases on GTX s
 of course, 4 phases = 4 resistors needed, im an idiot  anyone point me in the direction of figuring out the values?
improved 3dmark:
http://www.xtremesystems.org/forums/...1&d=1207521394
04-07-2008, 10:06 AM
#17
hi guys just wondering what waterblocks fit the 9800GTX?
04-07-2008, 10:29 AM
#18
most. swiftech mcw-60, dtek I'm sure, and many others.
here is a photo of my vmod, complete with easy disconnect on ground.
04-08-2008, 11:57 AM
#19
when i read voltage at idle and load
i can read 1.21v and 1.228v
is this correct ??
I can see here than you put these setting at 1.38v
04-08-2008, 12:10 PM
#20
i think there is something wrong
i read from other resistanse 1.235 v
what's wrong with this value and where is exactly the measuring point
before i solder anything
04-09-2008, 11:01 AM
#21
is this correct ??
I read 1.208V idle from the first resistor(?) to the top left of the GPU(backside of card, see pic). I measure from the right side of the resistor.
not sure why that is, other than a load, the voltage is the same for me. measure from the same point, and with the same ground every time.
04-09-2008, 12:51 PM
#22
Xtreme Guru
Would someone be kind enough to measure resistance from the marked pads to ground on this pic:
__________________
04-11-2008, 08:06 AM
#23
How to read VGPU voltage for this babe?
__________________
04-11-2008, 09:30 AM
#24
Xtreme Guru
See post #15.
__________________
04-11-2008, 06:59 PM
#25
ok gonna volt mod my 9800gtx's, iv never volt modded b4 but this thread is helping, can somebody plz post some more pics....
This correct guys?
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
