XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Hardware Mods
Reply
Old 03-28-2008, 01:59 PM   #1
NapalmV5
LOVE=MC˛
NapalmV5's Avatar
XS Xclusive: Auzen X-Meridian Total Recap:
look ma.. no caps!
i just finished removing all the caps.. 1 pad gone.. good thing i can work around that
since ive recapped the mx300 after 10 years with great results.. i decided not to wait that long to mod the xm
why news? if this was done before, it certainly wasnt posted publicly.. if it was, please post a link..
if everything goes fine ill be back later with a pic of a new xm
NapalmV5 is offline   Reply With Quote
Old 03-28-2008, 02:05 PM   #2
sdkevin
sdkevin's Avatar
lol totally naked!! how long it take for you to got all the caps off? can't wait to see newly reborn X-Meridian!
sdkevin is offline   Reply With Quote
Old 03-28-2008, 02:06 PM   #3
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
Just a quick question...
why?
__________________
IntelŽ Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is offline   Reply With Quote
Old 03-28-2008, 02:10 PM   #4
jas420221
why?
Thats what I want to know...
__________________
Giga EP45-UD3P
Q9650 @ 4.05Ghz 1.28v (4.6+ benchable @ 1.4v)
RaptorX, 640GB Caviar Black
GTX260 216 55nm @ 810/1656/1215 (max benchable @ 1.12v)
4GB OCZ Platinum @ 5-4-4-12 950Mhz PL9
X-Fi Extreme Gamer
Corsair 620HX / Antec 1200
HP 2207 22" 1680x1050
MCP655 - 120.3 - Fusion v1 - MCW60
jas420221 is offline   Reply With Quote
Old 03-28-2008, 02:14 PM   #5
Brother Esau
D.F.I Pimp Daddy
Brother Esau's Avatar
Not to deter you on this but a sound card of that caliper the question at hand here is Why
__________________
D.F.I LanParty DK 790FXB-M3H5 ~ 7/27/2009 ~ "Beta" Bios
AMD Phenom II 720 Black Edition ~ For Bios Testing
Custom Water
2x2gb Crucial Ballistix Tracer 1333mhz 6-6-6-20
POWERCOLOR AX3870 X2 CROSSFIRE
ULTRA X3 1000w
Danger Den Torture Rack
Brother Esau is offline   Reply With Quote
Old 03-28-2008, 02:16 PM   #6
Psykocyber
Psykocyber's Avatar
What are you hoping to achieve? Better sound quality like the Creative X-fire mod?
Psykocyber is offline   Reply With Quote
Old 03-28-2008, 02:32 PM   #7
Martijn
Mr. Boardburner
Martijn's Avatar
Send a message via MSN to Martijn
Exactly. Better caps generally give a much steadier voltage, resulting (at least what he hopes) in better audio quality.
__________________
Main rig:
CPU: Xeon W3570 C0 ES @ 3.8Ghz (160x24, 1.35v)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
OS: Intel X25-M G2 80GB
Apps: Spinpoint F1 1TB
Media/Storage: 2x Spinpoint F1 500GB, 1x Seagate 7200.11 1.5TB, WD MyBook 1TB (USB)
PSU/Case: BeQuiet 650W DPP, Silverstone TJ07
Crunching:
Server: Dual XeonLV s479 @ 2.0Ghz (up), Lappy: T9300 (up)
Badges:
Statistics are like miniskirts. Sure, they give you ideas, but they hide the essence of what we're doing.
Martijn is offline   Reply With Quote
Old 03-28-2008, 02:37 PM   #8
Rolle2k
Rolle2k's Avatar
Seriously, don't you people understand what he tries to archive?
Of course its better sound quality. There are alot of expensive and good caps that is especially made for hifi stuff, and my guess is that hes going to put some in there.
Cant wait to hear what you think about it!
Also, this is xtremesystems, so what do you other people think?
__________________
Asus M4A79 Deluxe / Phenom II 940 @ 3.6GHz
Thermalright TRUE w. 2x 120mm San Ace @ 5v
4x2GB F2-8800CL5Q-8GBPI 1100MHz
Silverstone DA750 750w 60A Single Rail 12v PSU
ATI x1800GTO 256MB PCI-E
160GB WD OEM Raptor 10K RPM 16MB / 1000GB Samsung HD103UJ
Rolle2k is offline   Reply With Quote
Old 03-28-2008, 02:40 PM   #9
jas420221
I think nothing. I have never seen anyone do this before.
__________________
Giga EP45-UD3P
X-Fi Extreme Gamer
Old 03-28-2008, 02:54 PM   #10
XS Janus
Xtreme Mentor
XS Janus's Avatar
Wow this IS extreme: no caps = infinite sound quality
j/k of course.
Good luck on piecing the thing together.
I hope you can do some tests on proper equipment that actually will be able to distinguish those differences you are hoping to obtain.
Nice project.
XS Janus is offline   Reply With Quote
Old 03-28-2008, 02:54 PM   #11
NapalmV5
LOVE=MC˛
NapalmV5's Avatar
it didnt take too long to remove.. just like you remove teeth.. one by one
why? i trying to get as much as possible out of the xm.. a lot of potential hidden @ stock
before im off to soldering heres a pic of the caps
all rubycon black gate nx
thanks xs Janus
Old 03-28-2008, 03:18 PM   #12
Xope_Poquar
Xope_Poquar's Avatar
Send a message via MSN to Xope_Poquar
Wow, I don't know if I'd have the patience to solder all of those. Props to you!
Xope_Poquar is offline   Reply With Quote
Old 03-28-2008, 03:25 PM   #13
Scubar
I am Xtreme
Scubar's Avatar
cant wait to see it finished.
Scubar is offline   Reply With Quote
Old 03-28-2008, 03:30 PM   #14
One_Hertz
One_Hertz's Avatar
Send a message via MSN to One_Hertz
hahaha I was very seriously considering doing this when the prelude just came out. Got too lazy when it came close to it. I really hope to hear your results because if it works well for you I will do the exact same thing. Its not too difficult.
One_Hertz is offline   Reply With Quote
Old 03-28-2008, 03:35 PM   #15
WeStSiDePLaYa
Aint No Real Gangster
WeStSiDePLaYa's Avatar
I don't understand. First thing you should be doing is replacing the opamp. Then the bypassing caps.
I'm not sure why this is news though, I did this to my X-fi months ago. Many other people have also done the same on head-fi.
__________________
Specs
Asus 780i Striker II Formula
Intel E8400 Wolfdale
2x1GB OCZ PC2-9200 FlexXLC
BFG GTX 280 OC2
Maxtor 6L250S0
Maxtor 6V300F0
Western Digital WD2500JS
Western Digital WD500AAKS
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
HardwareLabes Black Ice Extreme 2
Arctic Cooling S1
Audio Setup
X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
WeStSiDePLaYa is offline   Reply With Quote
Old 03-28-2008, 03:36 PM   #16
Frank M
Frank M's Avatar
With a hammer? Just like at Soviet KGB
Total recap...
Man, if you forget from where you took which cap off, you're gonna need
some total recall
But rly, to recap what the others said: why? In hifi circles, modding
the e-mu cards like the one I have was common; however, the mods were
usually about replacing opamps and dacs, I don't remember anyone doing
a full recap.
Just be careful with resoldering which to where, not to end up with a
total crape soundcard from a short.
OK, enough p(h)uns for today!
__________________
Still chugs along: E2160 M0 (bsel mod) | GB 945GCMX-S2 | 2×1GB/800 | HD4850 | (modded CPU block | Heatkiller GPU-X - to be modded | 2×BIP2 | Laing DDC1-VC) | modded P-180 | e-mu 0404 | SeaSonic S12-600
mITX DC Atom-Ion machine: entering planning phase, waiting for A330ION board release
Laptops: F-S Lifebook T4215 tablet, Vaio TX3XP
Frank M is offline   Reply With Quote
Old 03-28-2008, 03:45 PM   #17
KTE
Xtreme Mentor
I've seen it done before quite a lot of times (offline). I used to mod everything I own incl. musical equipment for better filtering, bandwidth and sound quality, and caps were easy so they came first.
Where'd you pick up the Rubycon Black Gate NX from Janus?
Why didn't you opt for Philips Low Loss (Q LL) caps?
They are what is used far often in the best musical equipment (amps too), have higher and tighter tolerances and frequency bandwidth, temperature tolerances, life and quality. Pair them up with Black Gate FK for best results.
KTE is offline   Reply With Quote
Old 03-28-2008, 03:45 PM   #18
thenrz
Holy crap, you must have a steady hand and an ungodly air pencil
__________________
E8600
2x ASUS 4850
DFI X48 board
4 gb DDR2
650w FSP PSU
Working on some liquid cooling!
Desktop 2:
Opteron 165 @ 2.610 (1.425v)
- Prime Stable, Stock HSF
DFI LanParty UT Expert
2gb G. Skill Dual Channel Ram 2.5-3-3-6
7900gt CO SuperClocked
2x WD250gb SATA in RAID 0
FSP Epsilon 600W
thenrz is offline   Reply With Quote
Old 03-28-2008, 04:18 PM   #19
WeStSiDePLaYa
Personally I think polymer caps are the best in DC-blocking positions when you need high capacitance. Provide great sound quality. the chemicon PSA series is good.
The next best thing to no cap though is film caps, electrolytics cant touch them.
For all other power filtering positions, the best are low esr caps like the panasonic FM, which is what I use.
__________________
Specs
BFG GTX 280 OC2
Maxtor 6L250S0
Maxtor 6V300F0
Antec Quatro 850W
Cooling
Swiftech Apogee
Swiftech MCP-600
Arctic Cooling S1
Audio Setup
Old 03-28-2008, 05:23 PM   #20
naokaji
I7 Fanboy
naokaji's Avatar
why?
because this is spar ehh xs
crazy but nice work, I hope it works out
__________________
920 D0, EX58-UD5, 6GB Corsair 1600 7-7-7, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's. Seasonic M12 700W, Cosmos S
Loop1: Swiftech GTZ, Koolance 4870x2 FC, Laing DDC 3.2 with XSPC Res Top, Blackice GTX 360
Loop2: Mips Gigabyte x58 blocks, DDC 3.2 with EK top, pa120.1, xspc acrylic 5,25" res
Come crunch with us for the Cause at WCG, we don't bite
I deny any responsibility for hearing loss or Overspending at PC Shops.
naokaji is offline   Reply With Quote
Old 03-28-2008, 05:29 PM   #21
jas420221
Any chance of links showing THD loss and things along those lines... thats kind of cool!
__________________
Giga EP45-UD3P
X-Fi Extreme Gamer
Old 03-28-2008, 07:53 PM   #22
KTE
Xtreme Mentor
Yep, the Panasonic FM are good for this too.
Old 03-28-2008, 09:29 PM   #23
NapalmV5
LOVE=MC˛
NapalmV5's Avatar
done! AD797 opamps
beauty to beast
all 10/22uf @ 47uf BG NX
100uf @ 220uF BG NX - 2x @ crystal = 470uf BG NX
470uf @ 2200uf BG NX but ill ecap one more
i was about to tell u guys that it turned out unsuccessful.. for a couple minutes i was doubting everything ive done..
reseated the card in the mobo once more and its all good
success!!!
im testing right now and noticed increased clarity/purity/rich sound right away.. and this is after power cap mod
ill get back to the replies tomorrow
Old 03-28-2008, 10:13 PM   #24
sdkevin
sdkevin's Avatar
wow impressive! those caps looks like mushroom growing on the log very tight space between those opamps, how about putting OPA637 for a test run?
Old 03-29-2008, 08:14 AM   #25
LordofDoom
LordofDoom's Avatar
Send a message via AIM to LordofDoom Send a message via MSN to LordofDoom
Lol it really did turn to a beast.
Looks ugly as hell XD
I'm sure it sounds great though!
__________________
LordofDoom is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
