Results 1 to 14 of 14
Thread: Maximus Formula...flash to 1004bios or mod to Rampage?
    NREMT-I
    Jul 2005
    near Atlanta Georgia (and hate it)
    I have a bunch of new goodies coming for my PC to upgrade it into 2008era (See new updated sig)
    I will be using 4 sticks of 2gb each for 8GB's of the G.Skill PC8500 stuff which seems to have great reviews. My goal is to achieve a stable DDR1066 speeds with all 8GB's in use (G.Skill says it not a problem for X38) but what BIOS is best? Im currently using 903 and it has been flawless for me using my current 2x1GB ballistix sticks which are running @ DDR1135 using only 2.16V. I see there is a new 1004 BIOS on asus' website, but I've also been reading through the "turn your maximus formula into a RAMPAGE formula, and that seems like another route to go, just a little more dangerous. Can someone please point me in the right direction . What Bios to use, or is it possible that my current 903 bios could be good to stick with? My new parts *should* be here Friday (I HOPE) but just wanted to get a head start on finding information
    Nothing anymore
    Aug 2006
    Oxford, UK
    From what I've seen, people are able to get slightly better settings from their memory with the rampage BIOS.
    I didn't go from the Maximus, but the P5E to the Rampage and it made quite a lot of difference.
    || 2500K @ 5GHz 1 thread, 4.8 2 threads, 4.7 3, 4.6 4 1.284V ||
    || P8P67-M Pro || 8GB @ 2133MHz ||
    || 5850 @ 1000/1225 || XFX 650W || Silverstone FT03B ||
    || 37" LCD TV || CM Hyper 212+ || Samsung 2.1 Soundbar ||
    Mar 2008
    Toronto, Ontario
    Seeing that it's really easy to flash between the two. Test both and see what runs better for you.
    My anecdotal evidence shows that the Rampage bios tends to give better overclocks and better memory bandwidth @ similar settings.
    Aug 2006
    Oxford, UK
    yup you can always flash back! The process is extremely easy.
    Mar 2006
    If he flashes to rampage there is no turning back....isnt the mod one way ?
    ThermalTake SuperTower XASER III
    Asus Rampage Formula
    Core 2 Duo 8600@4500MHz ( 450x10 ) /Thermalright Ultra 120 Xtreme ( 38degrees Idle - 58degrees OCCT2 Load )
    4GB OCZ REAPER 1066MHz
    GeForce GTX260 ( 702/1458/2376 )
    X-Fi Extreme Music
    Thermaltake ToughPower 850W
    Windows Vista Ultimate x64
    Samsung 21' 215TW
    CL Inspire 5.1 Digital 5700
    Xtreme Mentor
    Jun 2002
    No you can flash back to the 907 bios.
    {2012 27imac-3.4i7-680mx-32gb ram-768SSD+External TB Samsung840pro ssd + TB velociraptors-Moto828mkIII/Marantz/Amphion Sound-HPzR30w 2nd monitor}
    Aug 2006
    Oxford, UK
    Quote Originally Posted by HellasVagabond View Post
    Can go both ways, I've already flashed back and forth from my P5E a few times.
    I am Xtreme
    Jul 2005
    Quote Originally Posted by xgman View Post
    But can you flash to 1004 after 907?
    [SIGPIC][/SIGPIC]
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Guys, you can change between EVERY BIOS OUT THERE (Rampage, Maximus and P5E). Someone put that in a sticky so we don't have to answer the same question 10 times a day
    Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
    Quote Originally Posted by PerryR, on John Fruehe (JF-AMD) View Post
    Pretty much. Plus, he's here voluntarily.
    Mar 2006
    Nice GUNDAM Avatar Stargazer
    Also what is the latest stable Bios for the formula ? 1004 ?
    X-Fi Extreme Music
    Samsung 21' 215TW
    Xtreme Mentor
    Nov 2006
    Spain, EU
    Yes, 1004 is the lastest BIOS available for the Maximus.
    PS: HellasVagabond, hehe I'm looking forward to this season last episode, airing this saturday
    Banned
    Nov 2007
    Quote Originally Posted by newls1 View Post
    Kup had great success with going back to MF 505 for his quad and 4GB.
    I would recommend re trying that bios b4 any conversion.
    MF 1004 is very 45nm friendly and is a HUGE improvment , so if your running a MF bios I would recommend that.
    The Rampage conversion is worth it imo, easy as hell to do and with the proper afudos you can bounce back if you so choose.
    In the beginning I was a bit uneasy with the conversion, some very minor bugs, but a fresh OS install sorted any issues out, and I would recommend a clean install if converting.
    Rampage bios is full of new memory settings and tweaks so it should play very well with 4 and 8 gb of ram.
    In short if your not happy with the Rampage conversion you can flash back to ANY bios you so choose
    NREMT-I
    Jul 2005
    is there an easier way to flash to the rampage BIOS? If not can someone please explain it better, then what is in the thread about the rampage bios tweak...Please! Thanks
    Nothing anymore
    May 2007
    Richmond (GVA), BC, Canada
    Everyone should read this to gain better knowledge about Rampage bios and its characteristics to help you better with OC.
    I'm still reading it atm...looks like a new bios flash to rampage can means many days of playing and tweaking...have fun guys.
    http://www.anandtech.com/mb/showdoc.aspx?i=3208&p=1
    Xtreme Air-Cooled OC System:
    Mobo: Asus Rampage Formula (X38 Edition) Rev 1.03G (BIOS: 0803)
    CPU: C2Q Q6600 "G0" L723A765, VID 1.2625, 3720mhz, FSB 465*8, Vcore: 1.464, Idle/load temp: 31c/64c
    CPU Heatsink: Thermalright Ultra120 Xtreme lapped (2* Scythe S-Flex SFF21F S-FDB 120mm Push-Pull configuration)
    RAM: Kingston HyperX T1 2x2GB PC2-8500 (DDR2-1116)(5-5-5-15-3-52-6-3-8-3-5-4-6-4-6-14-5-1-5-5)(2.264 Vdimm)(Rated @ 2.3v default clock)
    HDD: Western Digital Caviar Black 640GB WD6401AALS-00L3B (AHCI)
    Video Card: XFX 8800GTS 320mb Xtreme, Core 612 Shader 1420 Mem 900 (Stock cooling)
    Sound Card: Auzentech Meridian 7.1 (8788 chipset)
    DVD: Pioneer 212D SATA DVD-RW
    PSU: Corsair HX620W Modular
    Xtreme Air Cooled Case: Antec 900 case | 3*120mm intake | 1*120mm & 1*200mm exhuast
    OS: Vista Ultimate x64 SP1 Build 6001
