Results 1 to 20 of 20
Thread: Super C/P ratio DDR2 motherboard, DFI LANParty DK X38-T2R introduction
Threaded View
    Nov 2004
    Intel launched its X38 almost more than 3, 4 months.
    Then, X48 also shows up in the market this year.
    Since X48 has been postponed the official launch time, so many gossip about X38 and X48 were upon the internet.
    Users are compares with X38 and X48 so hard recently.
    X48 is around the corner now.
    So, X38 still the highest-end of Intel’s product line.
    Coz, the price of DDR3 memory is still sky-high in market,
    therefore, DDRII + X38 chipset seems the best choice for a super C/P ratio platform.
    The review target board this time is LANParty DK X38-T2R, which belongs to LANParty series, an entry level overclocking board.
    The package box is still reminding the same in Black color.
    Accessories inside the box
    The Northbridge heat sink is the same with LT X38.
    The thermal paste is high quality product.
    The lower left of the motherboard:
    2 x PCI-EX16(CrossFire mode in X16+X16)
    1 x PCI-EX4
    3 x PCI
    Realtek ALC885 7.1 channels audio codec
    The lower right of the boar
    1 x Floppy
    6 x SATAII,ICH9R
    ICH9R支援RAID 0, RAID 1, RAID 0+1 and RAID 5
    Built-in power/Reset button and debug light, a good design for DIY users.
    The upper right parts:
    1 x IDE
    4 x DIMM DDRII supports 667/800/1066
    The upper right:
    The board incorporates with 4-phase digital PWM
    IO parts:
    6 x USB 2.0
    1 x 1394
    1 x Gigabit LAN
    Red jumper is for clear CMOS function.
    The audio module card uses electrolytic capacitors,
    but I think if the solid state capacitors can be in place of them, the quality of sound will be better.
    Booting scene
    BIOS main option page
    Voltage and FSB option setting page:
    The following 3 settings are new functions:
    1.CPU Clock Amplitude=>Clock Generator, The voltage enhances function. The default setting is 800mV.
    2.CPU Clock 0 Skew=>CPU’s Clock signal, this option is for increasing the stability with FSB while overclocking
    3.CPU clock 1 Skew =>NB’s clock, this option is also for increasing the stability with FSB while overclocking
    DRAM multiplier option
    CPU Feature
    DRAM parameters option:
    Clock Fine Delay: This function is mainly for pushing the limit of memory by its “characteristic”
    Voltage page:
    CPU VID Special Add +12.5mV~787.5mV
    DRAM Voltage 1.800~3.375V
    SB Core/CPU PLL Voltage 1.510~2.380V
    NB Core Voltage 1.265~2.040V
    CPU VTT Voltage 1.100~1.603V
    (These are reference for Quad core CPU)
    System details:
    CPU:INTEL Core 2 Duo E6300/Xeon X3320
    MB: DFI LanParty DK X38-T2R
    DRAM:CORSAIR Dominator TWIN2X2048-8888C4DF
    VGA:ELSA GLADIAC 880GT PW 512M
    HD:Seagate 7200.10 320G
    POWER:Corsair VX450W Power Supply
    Cooler:Thermaltake V1
    E6300 Dual core CPU, OC to 533MHz. Dual Super PI 32M
    This CPU can be performed around 540MHz in UT P35 platform(others around 520~530MHz)
    X3320 Quad core CPU overclocked to 460MHz FSB, Quad super PI 32M.
    This processor can reached 480MHz(Maximum) with LP DK P35.
    the others P35 are also can reach 460~470MHz.
    Memory OC parts:
    DDRII 1200 CL5 5-5-15 2.01V, Dual SP2004(stable)
    EVEREST the bandwidth of memory
    DDRII 1200 CL4 4-4-9, EVEREST the bandwidth of memory
    works with Elsa 8800GT “whale version” 630/2000
    3DMARK2003
    3DMARK2005
    3DMARK2006
    The result of 3D rendering test of X38 is just like the one before hand, a little higher than P35.
    DFI LANParty LT X38-T2R summaries:
    Goods:
    1.DK series has a constant image and price around 190~200USD
    2.Fully solid state capacitors, also provides PCIE x16 + x16 bandwidth
    3.Rich BIOS OC options and voltage settings
    4.Good product strategy for DDR2 users, the performance for DDR2 is excellent too.
    5.The OC performance with Quad core CPU is better than P35.
    Drawbacks:
    1.some users blame that the board is a bit hard to buy
    2.It would be better if the voltage option can be set a little lower
    Performance ★★★★★★★★☆☆
    Component use ★★★★★★★☆☆☆
    Appearance ★★★★★★★★☆☆
    C/P ratio ★★★★★★★★☆☆
    Although DK X38 is a step lower than LT X38.
    But the performance of overclocking and component using are having a similar
    Standard with LT X38.
    This is such a reasonable choice for users
    Most of the X38 based motherboard is launched in 2007, but only a few can satisfy users.
    DFI’s X38 is still doing well in overclocking parts by its rich BIOS settings and Dual PICE x16 design.
    For price and performance, should a good choice for users.
