I will buy 2 4GB sets of this stuff (8GB) if I have a good chance of obtaining my goal of DDR1138 speeds using 8GB's of this G.Skill mem in my Maximus Formula X38 motherboard..... http://www.newegg.com/Product/Produc...82E16820231166. Thanks![]()
Nothing anymore
I'd say basically zero, but it depends on what you consider stable.
With current chipsets, running 8 GB truely stable over DDR2-1000 speeds is not easy.
Gigabyte X58A-UD3R | i7 930 @ 4 GHz | Corsair H50
G.Skill RipJaws 4x2 GB @ DDR3-1600 7-7-6-24-1N | HIS Radeon HD 5870
3x Intel X25-M 80 GB RAID-0; OCZ Agility 120 GB | Samsung SH-S243D
Corsair HX1000 | Dell 3007WFP & Samsung 204T | 7 Ultimate x64
Non-sense...
All the following motherboards are capable of running 8gigs at 1066speeds stable.
Abit IX38
Abit IP35-E
Abit IP35
Abit IP35 Pro
Asus X38 Maximus Formula
Asus P5K Deluxe
Evga 780i
Gigabyte P35 / EP35 DS3 series.
Gigabyte X38 DS4
Gigabyte X38 / EX38 DQ6
The x48 and 790i variants will too.
As far as hitting DDR1138 speeds... I'm not sure.
Computer: Intel i7-4770k | Asus Z87 Maximus VI Impact | 240GB Corsair Force GT | 240GB OCZ Vertex 3 | 16GB G.Skill Trident X 2400MHz | EVGA GTX690 Hydro Copper 4GB | Corsair AX850 | Steelseries 7G | Logitech G500 | 27" 2560x1440 Overlord Tempest X270OC 120Hz S-IPS
Cooling: Koolance 380i CPU block | Swiftech Hydro Copper GPU block | EK X3 150 Reservoir | EK X-TOP D5 PWM drive | PrimoChill PrimoFlex PRO LRT Bloodshed red | Alphacool NexXxos 240mm XT45 | Alphacool NexXxos 280mm UT60 | Bitspower Fittings | 4x Bitfenix Spectre Pro 120mm | 2x Bitfenix Spectre Pro 140mm | Lamptron FC-5V2
Case: Custom modded matte black Caselabs Mercury S3
up thje chipset voltaghe and u should be fine
i7 920 | Asus Rampage II gene | 6GB ocz Blade | 4870x2
maximus IV extremegtx580
gigabut p67-ud7
p67 sabertooth
2500k+2600k
antec 1200watt
EVGA classified 760
920 Batch# 3849B018 4.985ghz@1.52vgtx285 ftw sli
OCZ3RPR1866LV6GK hypers
dfi ut p35rampage extreme
gigabut p35c-ds3r![]()
bios suks
gigabut x38-d6qdead thank god
ballistix 8500![]()
1240mhz@2.02v
How about DDR2-1066 8 GB like you're claiming?
I can post screenshots of my 8 GB @ DDR2-1080, but it's not stable.
You feel it's easy to hit DDR2-1066 with 8 GB, but it's not.
Anyone who thinks it's easy can show me their HCI Memtest (as many instances as it takes to utilize all 8 GB) or Memtest86+ screenies with 8 GB @ DDR2-1066 stable for hours.
No, Prime95 doesn't count, neither does Super Pi, or Everest bandwidth, as those do not really test stability for 8 GB at all.
I'll show you once I get my Rampage Formula. The sticks will only run 8gigs at 1066 speeds on the motherboards that are listed... that list isn't from me, it's DIRECTLY from G.Skill.
Only those motherboards are capable of running 8gigs stable at 1066 speeds. They are still looking for more capable motherboards.
Examples:
Maximus Formula running 8gigs at 1066
Maximus Formula running 8gigs at 1080
Workstation >>> ASUS P8P67 WS Revolution :: Intel Core i7 2600K @ 4.5GHz - 1.29v :: 16GB Corsair Vengeance 1600MHz CL8 :: ASUS GTX 580 DIRECTCU II :: Creative X-Fi Titanium HD :: 80GB Intel X25-M G2 :: 4 x 150gb Velociraptor [RAID-0] :: 1TB Western Digital Black
Laptop >>> MSI GX740 :: Intel Core i7 920XM :: 8GB Kingston HyperX CL9 :: Radeon 5870M @ 800MHz - 0.98v :: 160GB Intel X25-M G2 :: 500GB Western Digital Scorpio Black @ OBHD
nice results Darkstormz
Nothing anymore
Has anyone had a chance to test 8gb of the new 2x2gb OCZ reaper 8500's
http://www.newegg.com/Product/Produc...82E16820227289
dropped to $115 post rebate. I wondered if there would be any real diffrence in overclocking between these and the dominator 8500's?
I am looking for 4x2gb sticks for my dfi ut p35 board so any input would be greatly appreciated
[COLOR="DimGray"]LanParty UT P35-TR2 :A1 (12/24)
Q6600 :G0
2 x 2GB OCZ Reaper X 1000
CM Real Power 1000w
7800GTX
2 x 150GB Raptor :non raid
Plextor 755SA
Vista Ultimate x64
well I would never have thought, on a lark I purchased 8gb's of Mushkin EM -PC2 6400 $180+tax total cost, ok, so took out 4gb's Ballistix 4-4-4-9, put 8gb's EM in, only changed bios to read SPD, well I'll be a (*&^%%$$ uncle the ^&*(%$ frickin stuff booted played Counter Strike for a 1/2 hour no hiccups, albeit, at 5-5-5-18 2.2v
very nice. Although your resolution bugs me :P
hummmm
sorry for the threadcrap, but why do you guys want 8gb?
what for?
For the same reason that I wanted 2GB's back in 2003, cause at some point it will be nice to have, and also, why NOT? with the price of ram falling, grabbing 8GB's now for just over $200 is a nice scoreAlso, Vista is a MEMORY HOG, so that is my exact reason for going 8GB's as opposed to 4GB's.
Nothing anymore
In response to whether or not you'll be able to run 8GB at those speeds, I quote Harry Callahan.
"...you've got to ask yourself a question: Do I feel lucky? Well, do ya, punk?"
No harm intended.
Less is more.
I run 8 gigs of G-Skill in my Maximus Formula at 1066 every day. It was OCCT stable and Memtest stable for 1000+% coverage on all 8 gigs. It is possible.
Asus Maximus Formula (Rampage Conversion Bios 0403)
Q6600 G0 stepping@4.05 Ghz
8GB G. Skill 1066 @ 1081 Mhz
EVGA 280 GTX
Auzentech Prelude
2X 74 GB WD Raptors in Raid 0 Windows 7 Ultimate 64
2X 1 TB WD Caviar Blacks in Raid 0 Vista Ultimate x64
Thermaltake Toughpower 1200W
DTek Fuzion V2 in a custom CPU only water loop
Coolermaster Stacker 830
Hanns-G 28" widescreen
Klipsh Pro-Media 2.1
G15 Keyboard and G9 Laser Mouse
Asus 780i Stirker II Formula is ok to run 1066 8GB too
Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
Check out our items on NewEgg
XP Pro x64 8gb's disabled pagefile,
prefetch disabled also,
correct me if wrong,
it's probably a good idea to allocate 2mb(min and max fixed) to a pagefile on another disk in system in case of problem so you can read dump file, other than that what other purpose when using 8gb?
