Results 1 to 19 of 19
Thread: I think I have broken the 780G record again...
    Jan 2006
    Hong Kong Island
    Sep 2007
    wow that's nasty 1ghz clock for an IGP! congrats!
    AMD Phenom 9850 Black Edition @ 3.15Ghz 1.4v
    Stock Cooler with Silverstone 121 Fan
    ASUS M2A-VM 690G (225Mhz FSB) BIOS 1803
    Sapphire Radeon HD 3850 256MB (750/1900)
    2 x 1GB OCZ GOLD Reaper HPC DDR800 (450Mhz 5-5-5-10)
    600W Silverstone Strider Modular
    Xtreme X.I.P.
    Apr 2005
    J&W
    nice boards
    BTW are you using one with dedicated on-board memory chip?
    Jan 2006
    Hong Kong Island
    Quote Originally Posted by Cooper View Post
    J&W
    nice boards
    yes, with on-board memory chip
    Jan 2006
    Hong Kong Island
    a small update here:
    to help you guys knowing more about the performance difference between a board with / without local frame buffer, here is a simple, yet informative illustration based on identical CPU & memory config, running at defaults:
    with onboard local frame buffer:
    without onboard local frame buffer:
    onboard local frame buffer has a 17% advantage, which is matched with the AMD's 15-20% claim.
    Xtreme News & Reviews
    Apr 2005
    Atlanta, GA
    Though thats nice, you have to go by the SM 2.0 & 3.0 scores, since the CPU score alone can raise the total score quite abit.
    Desktop
    AMD Phenom II X2 550 (Quad Unlocked @ 3.4Ghz / 2200Mhz NB)
    Gigabyte GA-MA790X-UD4P (F9 Bios)
    8GB (4x2GB) @ DDR2-800
    ASUS GeForce GTX 560 Ti DirectCUII (920/1840/2200)
    Corsair Force GT 120GB
    LSI MegaRAID 8408E (3x750 R5)
    Windows 7 x64 SP1
    Cisco E2000 with DD-WRT kernel 2.6
    Xtreme Mentor
    Nov 2005
    Devon
    Very nice improvement with onboard memory .
    I only wish more manufacturers would make use of this feature.
    Hopefully Puma platform will require this on the laptops due to energy savings this solution provides.
    PS. Can you try same scenario with Phenom CPU? I'm wondering how HT3.0 and independent memory controllers helping mitigating lack of local FB.
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Jan 2007
    Brisbane, Australia
    After setting up some chilled water on this beast, it appears the chipset is cold-bugged.
    Nevermind.
    Best so far with only a 955 IGP clock and 2.6ghz PHenom ( but a hefty 667 sideport mem clock) is 2500+ 3d06 marks, I'm working on improving that before posting anything .. it appeas my igp is a bit of a lousy clocker 1000Mhz seems out of the question for it.
    Cheers
    May 2005
    [EU] Latvia, Jelgava
    Overclock CPU, get high memory frequency along with high HT bus speed, and you'll break 3k in 06. IGP's loves extra bandwidth.
    Fused
    Dec 2003
    Malaysia
    Wow... great result... congrats. Anyway J&W 780G still no available in Malaysia.
    Nov 2004
    how can u tell if a 780g has onboard vram?
    Jan 2006
    Hong Kong Island
    Quote Originally Posted by KoHaN69 View Post
    "320MB" (256+64) is the sign
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    Quote Originally Posted by mAJORD View Post
    Nevermind.
    Cheers
    How low did you go ? I have problems at -25 room temp in my chilled case for the board..
    And just air/ normal water on the CPU ?
    Quote Originally Posted by Kasparz View Post
    How to OC it ?
    Via Rivatuner ?
    Ati tools dosent work...
    Quote Originally Posted by kenofstephen View Post
    Or maybe 512+64
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
    Jan 2006
    Hong Kong Island
    Nevermind.
    Cheers
    chilled!
    i was on air
    Jan 2007
    Brisbane, Australia
    I ran into problems at 10-15c water temp, i.e GPU overclock became worse.. (no probs at low clocks)
    -edit, yes chilled. The ambient temps around here are still in the high 20c in my garage!. I sued an ati gpu block on the chipset.
    May 2004
    Denmark, Copenhagen
    How to OC it ?
    Via Rivatuner ?
    Linkedin
    Jan 2006
    Hong Kong Island
    let me try with some CPU oc when I have time to do so.
  18. #18
    Jan 2006
    Hong Kong Island
    a little bit more overclocking on AIR:
  19. #19
    Jan 2006
    Hong Kong Island
    on the top of the ORB again,
    just behind the Hybrid score.
    well, I haven't run hybrid yet :P
