Results 1 to 25 of 39
Thread: P965StrapTweaker
Threaded View
    Jan 2006
    P965StrapTweaker
    With relation to the JP PMem Strap Tweaking solution :
    http://www.i4memory.com/showthread.php?t=4268
    I program a little utility to set Strap values automatically.
    If you start the Application without Parameter the default Values for the
    five Bytes will be as follows :
    R1, FED14030h => 06
    R2, FED14034h => 10
    R3, FED1403Eh => 03
    R4, FED1403Fh => 24
    R5, FED14040h => 09
    On my Asus Commando works very well , also on FSB above 600MHz.
    To set custom values for the R1-R5 Adresses use this Command Syntax:
    P965StrapTweaker.exe R1 R2 R3 R4 R5
    Example:
    P965StrapTweaker.exe 06 10 03 23 09
    If you want to run it each time Windows starts , you can put this custom Parameter start also in a Batch file and copy it in the Autostart Folder.
    Use at your own risk!
    Attached Files Attached Files
