Results 1 to 25 of 34
Thread: A Simple tweak make fsb 1333 into 1600 on 45 nm
Threaded View
    Mar 2007
    Buenos Aires,Argentina
    So is read as a simple tweak, converts fsb 1333 @ 1600 on processors from Intel 45 nm out so far.
    Coolaler the site shows images in the following
    QX9650 as you know has multiplier free, but comes manufactures in default to 333 x 9
    Tweak the purpose of this is to make the mobo to take micro and 400 x 9
    So we should just plug this contact that marks the red circle for the mobo we take fsb as 400 x 9
    Here we have the result, remember that the QX9770 brings fsb 1600 and its speed is 3.2 GHz being manufactured for now the only micro FSB 1600 put up for sale by intel ... until today, thanks to this we managed to tweak our motherboard to take our QX9650 of 3.0 ghz @ 3.6 Ghz (400 x 9)
    As seen in the image, particularly in the bios this Order, so no traps or anything, actually believes that the motherboard has a micro FSB 1600
    We saw in windows with the cpu - z to check once more that tweak is effective
    After having checked and confirmed spend about 30 minutes orthos to verify stability (if there was a mistake or contacts problem before 30 minutes error is inevitable) as it is completely normal
    45 nm others
    E8200
    Repeating the same process we see as our previous bios believes that our E8200
    (8 X) gives us 400 FSB, from an original speed of 2.66 @ 3.2 Ghz
    It is found again with CPU - Z that the change is real.
    E8500
    You know the same procedure that all previous micros and ready, we believe that our bios E8500 has fsb 400
    Again it is found with CPU - Z that the change be effective and that's all
    Ladies and gentlemen, we have seen a reason to die more to buy a motherboard with more new chipset "that our P35 ".
    hersounds powered by 121 % overclocking Machine http://valid.x86-secret.com/show_oc.php?id=220390 - http://valid.canardpc.com/show_oc.php?id=1917405
    facebook.com/hersounds
    Intel Core i5 4670K @ 4,5 Ghz 24/7 - Galaxy HOF GTX 780 - 8 GB Team Group Xtreem 2666 Cas 11 - 8Gb Avexir Core series 2800 Blue Led - Maximus VI Formula Armor TUF - Corsair Force GT 120 GB SATA 3 - Galaxy Hall of fame 1200 hersounds Limited edition Modular - Antec 620 dual fan mod
