Results 1 to 3 of 3
Thread: Radeon 3870 Component Question
    Jan 2008
    Arrow Radeon 3870 Component Question
    I'm getting into hardmodding Radeon 3870s. I have 5 of them, 4 are in a rig for CrossfireX. One spare.
    I will be upgrading capacitors that fit in the same place as the existing ones. I am:
    Upgrading the 180uf 16V to 330uf 16V
    Upgrading the 820uf 2.5V to 2200uf 2.5V (and filling in one empty one near the top of the board)
    Installing the "missing" 6.5mm x 6.5mm SMT with 16V 220uf
    Also installing trimmers for Vgpu and Vmem.
    I'm curious about the four large square items on the board. They are labeled R47 738 M3K. I might want to replace these with something a little larger and more stable if it makes sense to do so. I have about 1.5mm to 2mm of clearance under my Koolance water blocks for these. What are these and what are the specs?
    Thanks...
    Work in progress... Koolance PC4-1026SL Case, ASUS M3A79-T Deluxe BIOS 0602 - Video, CPU, Memory - Water Cooled
    Phenom II X4 940 @ 3.6GHz with Koolance CPU-340 (o/c limited by 4 memory sticks maybe?)
    4x mushkin 2gb 991593 in OCZ FlexXLC Water Blocks at 5-5-5-12-2T 2.2V DDR2-960
    3x ATI Radeon HD 3870 @ 960/1250 @ 1.675V, custom capacitor mods, with Koolance VID-387, Catalyst 8.10
    2x WD VelociRaptor SATA 10k 300GB RAID 0 on SB750(200MB/s throughput!)
    Silverstone Zeus 1200W (single rail mode) Power Supply
    Dell 3007WFP-HC, LG DVD, Razer Keyboard + Mouse, Vista Ultimate 64-Bit
    FSB 240, CPU 1.4V 15x, Mem 2.2V, NB 1.3V 10x
    System Showcase - Koolance PC4-1026SL Case, MSI K9A2 Platinum with 1.6B3 BIOS
    Northbridge, Southbridge, VRM, CPU, Video, Memory - Water Cooled (picture)
    Phenom 9850 CPU @ 2888MHz with Koolance CPU-340
    4x mushkin 2gb 991593 in OCZ FlexXLC Water Blocks at 5-5-5-12-2T 2.1V DDR2-960 (Sandra XII SP2c Mem Bandwidth 11.68GB/s)
    4x ATI Radeon HD 3870 @ 975/1250 @ 1.675V, custom capacitor mods, with Koolance VID-387, Catalyst 8.6 HF1 | 16156 3dMark06 | screenshot
    2x Fujitsu MAX3147RC SAS 15k 146GB RAID 0 (156MB/s throughput!)
    SilverStone OP1200 (90A Single Rail) Power Supply
    FSB 240, CPU 1.45V, Mem 2.1V, NB 1.3V, HT 1.3V
    all outta gum
    Dec 2006
    Poland
    Those are inductors (coils), replace for higher inductance to get less ripple. I dont know the specs though.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
    Jan 2008
    Arrow
    Well on my test subject card, stock cooling, I have trimmers on it now and got it at 1.5V / 2.05V and 910/1210 speeds. It gets damn hot though, at idle it is at 1.2Vgpu and 300MHz and seems to be reasonable there. I haven't heard the fan kick into full speed yet though. This was a starting step for what I'm eventually going to do on my 4x 3870s in K9A2 Platinum water cooling. I'd like to get 4x running at 1000/1200 at a minimum. Then my Phenom 9600 at 2.75GHz can choke the system into posting a mediocre score. :>
