Feser is getting ready to release their line of X-CHANGER radiators. I don't know anything reliable about this company but looking around many forums and this one, I see they have quality consistency problems and generally high prices. So I don't know what to make of them; a real WC performance company or one that is trying to get a cut of the growing demand with colourful (yes thats a u) marketing that offers features such as individual serial numbers and holographic seals of authenticity.
This rad is going to cost $145.80CAD, about $20 higher than a PA.3 at $123.17CAD, these prices are from Direct Canada (NCIX). It will have a bleeding screw like the Thermochill rads and be available in 1, 2, 3 fan variants.
From the overclock3d.net forums:
5c? Thats alot; which probably isn't gonna happen, unless its very restrictive and they are talking strictly about water temp. But could we have a new potential champion?They will cost more than the Thermochill Radiators across the whole range by more than 30% in most cases.. I was talking to Mario at The Feser Company last night and they are are staying confident these should reduce temperatures by more than 5c compared to the Thermochill Range in an average loop.
_______________________________
Official teaser site: http://www.tfc-xchanger.com/ (nothing there at the moment)
Manufacturers description:
The Feser X-Changer Triple 120mm Xtreme Performance Radiator is finally here after a very long development time, many patterns productions and dozens of test runs. Feser has developed a radiator that has no peers!
Feser only uses the best materials for their radiators. The fins and water channels consist of high-grade copper (e-Cu). The water chambers consist of a brass alloy. Feser paid very close attention to each detail, like ensuring that the layer of the black finish remains very thin, thus the heat-air transfer is optimized to a maximum. The G1/4" thread for the inlet and outlet of the radiator offers the highest compatibility for a wide variety of fittings. The radiators can be installed horizontally or vertically. For a vertical mounting the air can escape entirely from the radiator by using the bleeder screw.
The radiators have a distinctive "TFC - Xchanger" logo and after each radiator has been checked by the factory for impermeability and function, it it gets a hologram label with an individual serial number. This way you know that you have an original Feser Radiator.* Water Channels and Fins made out of ECu Copper Material
* Brass Water Chambers
* Black Finish (5µm)
* G1/4" Threads
* Mounting Screws for Case (4/8/12)
* Mounting Screws for Fan (4/8/12)
* Silicon Pads (1/2/3)
* Bleed Valve Screw
* Stamped TFC – Xchanger Logo
* ColorBox Packaging
* Warranty Card
* Serial Number with Holographic Sticker
* Sealed in VCI Bag - 5 Years Corrosion Protection
* 3 Years Warranty
* Compatible with all available Waterooling Sytsems
