Results 1 to 25 of 56
Thread: Phenom TLB Disable Tool and Phenom MSR tweaking tool
Threaded View
    Feb 2008
    Phenom TLB Disable Tool [Update Version 1.04]
    Finally finished the GUI version of TLB disabling program. It is useful when you mobo BIOS doesn't has option to disable the TLB walkaround. And it is also useful if you are using Vista SP1 which enabled the TLB after boot up even if you disable the TLB in the BIOS. Added GUI interface, and user can choose to automatically close the window after successful applying of patch. The default time for closing the window is 8 seconds. You can also change the default in the INI file.
    You will need to put the program in the same directory as CrystalCPUID (x86 version, NOT the x64 version) to run the program. In Vista, you also need to run as administrator. For how to setup the program so that it starts automatically with Vista see here. You can also use that link for older versions of the program and how to use the program and how to do the benchmarking.
    Works for XP, Vista32/64
    USE AT YOUR OWN RISK!!!
    Download
    TLB ver 1.04.RAR
    If you are experiencing VCL.bpl dynamic library problem trying using the following download. It has all the required dynamic library built in but slightly large in size (260KB download).
    TLB_ver1.04.RAR with Built in Dynamic Libraries
    [Update v1.05]
    Fixed icons, and updated the TLB patch enable tool.
    TLB ver 1.05.RAR
