Page 1 of 3 123 LastLast
Results 1 to 25 of 55
Thread: New Controller - Adaptec - Better then Areca?
    Apr 2006
    Canada, BC
    Thumbs up New Controller - Adaptec - Better then Areca?
    http://www.adaptec.com/en-US/product...ance/SAS-5805/
    Next-generation Unified Serial controllers deliver performance for high-capacity SATA drives and high-end SAS drives
    8 internal-port low-profile Unified Serial RAID controller delivers exceptional performance and scalability, along with advanced data protection for bandwidth-intensive high-density server applications.
    Supported Operating Systems
    Windows XP
    Windows Vista
    Windows Server 2003
    Windows Server 2008
    Red Hat Enterprise Linux (RHEL) 4.0, 5.0
    SUSE Linux Enterprise Server (SLES) 9.0, 10.0
    SCO OpenServer 6.0
    SCO UnixWare 7.1.4
    Sun Solaris 10
    FreeBSD 5.4, 6.1, 6.2
    VMware ESX Server 3.0.1, 3.0.2
    Benefits
    Performance Unified Serial RAID controller supports both SATA and SAS devices. Ideal for bandwidth intensive storage applications; NAS, OLTP servers, web servers, digital surveillance and stream applications.
    Customer Needs
    High I/O transaction and high bandwidth processing.
    Form Factor
    MD2 Low-Profile
    Cache Memory
    512MB of DDR2 memory
    RAID Levels
    RAID levels 0, 1, 1E, 5, 5EE, 6, 10, 50 and 60
    Key RAID Features
    • Supports 8 direct-attached or up to 256 SATA or SAS disk drives
    using SAS expanders
    • RAID levels 0, 1, 1E, 5, 5EE, 6, 10, 50 and 60
    • Quick initialization
    • Supports multiple RAID LUNs
    • Online Capacity Expansion
    • Copyback Hot Spare
    • Dynamic caching algorithm
    • Native Command Queuing (NCQ)
    • Background initialization
    • Hot-plug drive support
    • RAID Level Migration
    • Hot spares – global, dedicated, and pooled
    • Automatic/manual rebuild of hot spares
    • SAF-TE enclosure management
    • Configurable stripe size
    • S.M.A.R.T. support
    • Multiple arrays per disk drive
    • Open stripe table
    • Dynamic sector repair
    • Staggered drive spin-up
    • Bootable array support
    • Optimized Disk Utilization
    Bus System Interface Type
    8-lane PCIe
    Internal Connectors
    2 internal (SFF-8087) MiniSAS connectors
    Package Contents
    • Adaptec RAID 5805 Controller
    • Additional low profile vented bracket
    • Quick Installation Guide (English/French/German/Italian/Spanish)
    • Software and documentation CDs
    • Cables: two internal Mini SAS x4 to (4x) SATA fanout cables w/ sideband (2247100-R), 1 meter
    Warranty
    3 years
    Management Utilities
    Adaptec Storage Manager™ (ASM)
    • Java-based GUI Management Utility
    • Remote configuration, monitoring & notification
    • ASM OS Support: Windows, Linux, SCO, Solaris
    • Microsoft VDS Support
    • SNMP, SMTP
    • Remote firmware updates
    ARCCONF
    • Command Line Interface
    Adaptec BIOS Utility (ACU)
    • BIOS level configuration utility
    • Flashable BIOS support
    Physical Size
    2.5" H x 6.6" L (64mm x 167mm)
    Operating Temperature (excl. battery)
    0°C to 45°C (without airflow)
    0°C to 55°C (with airflow)
    Note: with battery the temperature should not exceed 40°C
    Operating Voltage
    1 amp @ 3.3V
    Regulatory Certification
    CE, FCC, UL, C-tick, VCCI
    Mean Time Before Failure (MTBF)
    873,402 hours at 40 degree C.
    Accessories
    Adaptec Battery Module 800 (2248000-R)
    For those confused about the SAS/SATA thing this controller can do both
    Adaptec decided to call this UNIFIED SERIAL ARCHITECTURE
    One Storage Architecture for SATA & SAS: Endless Possibilities
    Choose an Adaptec Unified Serial™ controller to leverage cost-effective, high-capacity
    Serial ATA (SATA) disk drives or high-performance Serial Attached SCSI (SAS) drives, or both, in a single storage system. Now, it’s possible to create solutions that are closely tailored to business needs today and also make upgrading or reallocating storage as simple as swapping disks.
    For expanding a SCSI infrastructure, simply install an Adaptec Unified Serial controller in your server and as your data grows, take advantage of massive scalability up to 128 devices, or up to 60TB (using 500 GB drives).
    http://www.adaptec.com/en-US/_common/unified_serial/
    Apr 2006
    Canada, BC
    Adaptec RAID 5405 (4PORT) 425USD
    Adaptec RAID 5805 (8PORT) 650USD
    Adaptec RAID 51245 16 port (12 internal/4 external) 1075 USD
    I highly Doubt many of you would go above 8 ports, but some of us are quite Xtreme
    Highlights
    1.2GHz Dual Core RAID on Chip (ROC)
    - High-performance RAID 5 and 6
    - Up to 512MB DDR2 cache
    Supports up to 256 SATA or SAS drives using SAS expanders
    3Gbs/ throughput at each drive port
    x8 PCI Express host interface
    Enclosure management support via LED header and SES2/SGPIO
    RoHS compliant
    Jul 2006
    Yes, that card caught my eye as well, and now it looks like Areca also has the 1.2Ghz procs on their newer line of ARC-1680ix cards which is sweet. I'm going to be dumping my ARC-1280ML card here as soon as they hit the channel and if it's a drop-in replacement (should be but need to check w/ areca on that). I'm constantly hitting the processor limit on the 800Mhz version.
    Both the Areca and the Adaptec should perform similar as they're both based on the same chip and when comparing same speed to same speed. I like the ability for the areca to have 4GB of cache though. We'll see when more people pick them up.
    |.Server/Storage System.............|.Gaming/Work System..............................|.Sundry...... ............|
    |.Supermico X8DTH-6f................|.Asus Z9PE-D8 WS.................................|.HP LP3065 30"LCD Monitor.|
    |.(2) Xeon X5690....................|.2xE5-2643 v2....................................|.Mino lta magicolor 7450..|
    |.(192GB) Samsung PC10600 ECC.......|.2xEVGA nVidia GTX670 4GB........................|.Nikon coolscan 9000......|
    |.800W Redundant PSU................|.(8x8GB) Kingston DDR3-1600 ECC..................|.Quantum LTO-4HH..........|
    |.NEC Slimline DVD RW DL............|.Corsair AX1200..................................|........ .................|
    |.(..6) LSI 9200-8e HBAs............|.Lite-On iHBS112.................................|.Dell D820 Laptop.........|
    |.(..8) ST9300653SS (300GB) (RAID0).|.PA120.3, Apogee, MCW N&S bridge.................|...2.33Ghz; 8GB Ram;......|
    |.(112) ST2000DL003 (2TB) (RAIDZ2)..|.(1) Areca ARC1880ix-8 512MiB Cache..............|...DVDRW; 128GB SSD.......|
    |.(..2) ST9146803SS (146GB) (RAID-1)|.(8) Intel SSD 520 240GB (RAID6).................|...Ubuntu 12.04 64bit.....|
    |.Ubuntu 12.04 64bit Server.........|.Windows 7 x64 Pro...............................|............... ..........|
    Apr 2006
    Canada, BC
    hmm... Dual core raid? for the areca?
    Here quote from site
    http://www.areca.us/news/2008/n030408_01.htm
    The SAS RAID controllers raise the standard to higher performance levels with several enhancements including Intel new high-performance 1200MHz IOP348 I/O Processor, a DDR2-533 memory architecture and PCIe x8 Link host interface bus interconnection.
    There might be differences between the adaptec and the areca...areca didn't state if it was dual core or not :\
    Apr 2006
    Canada, BC
    the Areca in Canada here is selling for 853$
    Areca ARC1680LP 8-Port Low Profile PCI-E SAS 256MB RAID Controller
    http://www.ncix.com/products/index.p...ufacture=ARECA
    Adaptec is significantly cheaper, it is much cheaper if you look here:
    http://www.atic.ca/index.php?search=...+5805&x=24&y=6
    555$ for a 8 port adaptec!
    Jul 2006
    Yes, the IOP348 is a dual cpu design (one for SAS the other for the raid function). it's the same principle as the Adaptec so both should have the same layout, firmware and other coding would be different but I don't really see that being more than a percentage point or two from each other.
    Apr 2006
    Canada, BC
    hmm i wonder what would be different
    Oct 2006
    Quote Originally Posted by stevecs View Post
    hi Steve,
    I'm running a 3805, how much of a difference would I possibly experience upgrading to the 5805?
    2x320 raid1, 4x320 raid10
    mind you I'd have to change mboard to take advantage of the 8x lanes.
    thanks
    Jul 2006
    You're not doing any parity raid with those arrays. You won't really see much of a difference in performance. Perhaps a little for small/burst transactions as you are increasing your cache (128 -> 512MB) but that's rather small as well and depends on your workload.
    As alfaunits & myself have 'bantered' in another thread the 8x lanes is not something you'll actually use with the cards (it's going to have the same max cap speeds when writing out to the drives, only going to the cache would have some benefit of anything over 4x pcie.
    In your case I would say increasing the size of your array would give you more bang for the buck than getting the card/changing your MB.
    Oct 2006
    So, probably increasing the raid10 to 6 drives would be best for me.
    Greatly appreciated, Thanks!
    Oct 2002
    Techspot.com
    Just noticed that Adaptec don't actually list support for the 64bit versions of Windows XP x64, Windows Server 2003 x64, Windows Vista x64 and Windows Server 2008 x64 for these new cards
    Has anyone been able to find some confirmation on this somewhere?
    Oct 2006
    Actually, now 6x320gb and switched to raid 50 - this seems to work well for me.
    It's amazing how quickly you can use up the space.
    Stevecs, quick question please;
    I have little experience in this area, what would be a simple set-up (cost effective) for 12 disks? - prefer external to keep case cool.
    Thank You in advance.
    Adaptec 3805 - 128 cache (using x4 lane only 1 available) - XP Pro x32 - Q6600
    Jul 2006
    FYI, if you were looking for redundancy/availability a raid-6 array would have higher availability than the raid-50 you have and use the same # of drives for parity.
    Well, I've seen some external SATA chassis on the web where you can get a 12-channel (areca/3ware/adaptec) card and run the cables externally to the drives. That's probably the cheapest. Otherwise, if you are looking for a SAS external chassis then the price goes up. You can find some without expanders (you'll have to run an multi-lane cable for each 4 drives yourself) cheaper probably < $800 range. If you want ones with a built-in expander (one cable and the chassis usually using the lsi chipsets expand it up to 28 drives. basically combines the mini sas-4i cables into a single 12Gbps link and then breaks it out to the drives). These are more expensive for single-path probably <$1800 or so, for dual-path $1800+
    If you have some room in the case and you're using 2.5" drives there are some 8-bay internal enclosures (supermicro and a couple others make them) that you can daisy chain. The problem is that not man of them have more than 2 channels for uplink to the drives when you daisy chain them (so only 6Gbps). But they take up only 2 slots which is nice.
    Here are some links at least ones that caught my eye:
    External w/ sas expanders:
    http://www.rackmountpro.com/product....2023&catid=247
    http://www.rackmountnet.com/SASSATA-...J-SA24-316R-B/
    http://www.pcicase.co.uk/rackmount.ihtml?pid=746&step=4
    Or for internal 8 in 2:
    http://www.pcicase.co.uk/rackmount.ihtml?pid=743&step=4
    http://www.supermicro.com/products/a.../CSE-M28E2.cfm
    Oct 2006
    Thank you,
    ok what about this?
    http://www.ewiz.com/detail.php?name=CA-6DRV3GE
    there is the same 6- bay cage without expander, both about the same price;
    My strategy is to find the most cost effective workable solutions until I develop a better understanding.
    also, with Diskmon for the short time I monitored activity, I find most of my write activity is 8 - 128k
    Jul 2006
    Don't know that's for the intel SC5xxx series computer. Looks like the sas version may have that but with only two sas ports if you have the hs backplane, but that's only 6Gbps, assuming that they can both be tied to the controller and one is not used for linking to another chassis. There is hardly any tech docs on the unit itself as it does not appear to be something that is sold for aftermarket sales just as an accessory for the specified intel servers.
    I would probably steer clear of it unless you have one of the intel boxes as even if you could get it to work you won't have any support for it.
    Oct 2006
    Stevecs,
    You have been extremely helpful,
    What I was thinking; just use the 6 bay cage non expanded - mini sas to 4xsata fanout 1 meter cables
    You mentioned raid6 versus raid50 (better availability), what about raid-5 with a hot space?(maybe better performance?) taking into consideration most of my writes are 8 - 128k, you still recommend that? Also using default Adaptec stripe 256k - should I change this?
    Jul 2006
    Depends on what you goal is. If write performance is what you are looking for than the raid-50 would have slightly better write performance over the raid-6 array. (and raid-10 would have more over the raid-50). However if you are looking for availability of the array than it would be raid-6, then raid-10, then raid-50, then raid-5. As for raid5+hot spare. Hot spares help if you have a long rebuild or discovery window. Personally I would use a raid-6 over a raid-5+hot spare due to the higher availability. (if a drive dies you still have another parity, whereas if a drive dies in a raid-5 you are non-redundant now until you complete the rebuild).
    It really comes down to what your goal is and what your workload type is (not just write size (request size) but queue depth, amount of writes in relation to the amount of reads, and availability requirements. There is no 'silver bullet', everything is a compromise of some sort.
    Honestly, stripe size is much over-rated and mis-understood. Unless you really know your workload to the 'T' I would suggest you keep your stripe size to 64K. The main 'idea' behind stripe size is to help in the parralism of requests to the drives. For generic home use and even most server uses you will be hard pressed to see a request size > 64K (most are around 16K). And the concepts around keeping your stripe width (stipe size * # drives) >= to your average file size only really helps if you have enough commands in the queue to keep the drives fed. Otherwise it will be no more than single access requests and you won't see much benefit, if any at all.
    As for your cage, yes you can put up to 8 drives that way non-expanded and that's good, plus much cheaper than any other solution. When you start going into sas expanders et al (basically where I am due to the sizes of arrays) it gets very pricey, but also, at least for me, I am willing to pay more for a more enterprise (lower maint) approach. Just don't have the time/desire to play that much with it at home & at work.
  18. #18
    Oct 2006
    Thats super,
    I appreciate the time and effort.
    I'm not looking to break any records so I think for comfort I can sacrifice performance.
    The reality is that data integrity is all important. Also, any real world performance hit will be negligible for most of my purposes.
    The trick is to find a good balance between form and function; and, your responses have greatly helped to define my needs, as well as, being aware to monitor my specific work habits in order to determine the best compromises specifically for me.
    So, at this juncture raid-6 - 64k stripe. I will monitor work habits and the only adjustment I can foresee will be the stripe size.
    Thank you gentlemen!
  19. #19
    Jul 2006
    Remember that RAID does not provide _any_ data integrity, it's function is to provide hardware AVAILABILITY. completely different. From a raid point of view your filesystem & files are nothing but data blocks and no real clue what is right or wrong, just that if block X is requested then whatever happens to be in that block is presented to the OS (does not check the contents).
    Which is why backups and other data verification schemes are needed (ie, like I do backups of the data and do md5 hash checks on all the files on the system every two weeks, plus at the availability/raid level I do a full raid consistency check every week).
  20. #20
    Oct 2006
    Thanks for the correction, I think what I meant with "availability I have a better chance to maintain my backups".
    The other interesting point you mentioned;
    "(ie, like I do backups of the data and do md5 hash checks on all the files on the system every two weeks, plus at the availability/raid level I do a full raid consistency check every week)"
    Other than backups I never took into consideration those other factors you mentioned.
    That I will have to work on and better understand.
    Thanks!
  21. #21
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Anyone know when these will be out ?
    Edit: Found it at pc-pitstop $589 USD
  22. #22
    Jul 2006
    Probably have to wait a couple more weeks. Would say mid april at the earliest assuming there are no delays. Main benefit of them would be for small writes (the faster processor won't help with max cap speed on these cards so for streaming they will have the same max of about 800MiB/s. It's the small request IOPS where the cpu helps out with raid 5/6.
  23. #23
    Nov 2006
    A great place again
    I found it and edited my previous post.
  24. #24
    Oct 2002
    Techspot.com
    There are quite a few sites in Sweden that have it up for preorder;
    5405;
    http://www.prisjakt.nu/produkt.php?p=286624
    5805;
    http://www.prisjakt.nu/produkt.php?p=286627
  25. #25
    Back from the Dead
    Oct 2007
    Stuttgart, Germany
    They are available now, I think I'll get a 5405 even though it's overkill... but at only 240€ I can't resist
    World Community Grid - come join a great team and help us fight for a better tomorrow![size=1]
