Received my E3110 Xeon 45nm Wolfdale (E8400 equivalent) from PCManiacs.com.au :thumb:
E3110 SLAPM 2V7***** / ***414
FPO/Batch: Q750A158
Version: E27970-001
Pack Date: 02/06/08
System
- Intel Xeon E3110 Q750a158 2V7**** / ***414
- CPU Cooling: Dtek Fuzion Rad Tower Box
- Asus Blitz Formula 1402 bios
- 128MB Gainward FX5200 PCI
- 2x1GB Corsair 10000C5D Dominator dual channel kit
- Memory cooling: 120x25mm Thermaltake 81cfm fan
- 80GB Hitachi 7K80 SATAII
- Pioneer DVD-RW
- 1200W Silverstone OP1200
- WinXP Pro SP2 Nlite Fully Updated.
Nice low AUTO vcore at 1.152v in bios with Coretemp VID = 1.0875v. So I set bios vcore to lowest available option = 1.1v for 1.056v idle/1.048v load with Loadline Calibration disabled.
E3110 Coretemp VID = 1.0875v
Bios set AUTO vcore = 1.152v compared to my 2x E8500 AUTO vcore of 1.184v and 1.192v both with 1.1125v Coretemp VID
Since my last setting in bios for my E8500 was testing Real Temp idle calibration tests http://i4memory.com/showpost.php?p=86728&postcount=3, I thought I'd do the same for E3110 to compare with my E8500.
Realtemp v1.1 Idle & Load test
Seems Coretemp v0.96.1 over reports idle temps by 7-10C
E3110 @ stock 9x333FSB at 1.1v bios set vcore
Seems the E3110 receives 0.08v less vcore than my E8500 at same bios set 1.1v vcore. Maybe slightly more amperage used on E3110 than E8500 ???
CPUZ reported vcore = 1.056v idle and 1.048v load.
Idle
Load
Very promising cpu as the low vcore end
3207Mhz at 1.048v load
3300Mhz at 1.048v load
