XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Bandwidth
Reply
Old 03-06-2008, 03:59 AM   #1
Darkstormz
Corsair Dominator 2x2GB PC8500 DDR2
I wanted a thread for these babies. Corsair Dominator PC8500 2x2GB DDR2.
Got 2 kits of them about 3 days ago.
Here is my 24/7 result so far with 4x2GB
533MHz DDR1066 - CL 5-5-3-13 tRFC 52 - 1.89v
Feel free to post your results.
__________________
ASUS Rampage Formula :: Intel Q9550 - 4000MHz@1.22v :: 4 x 2GB Corsair PC8500 :: EVGA GTX 295 :: Creative X-Fi Fatal1ty :: 1 x Intel X25-M G2 80GB :: 2 x Velociraptor 150gb :: Corsair HX620
Darkstormz is online now   Reply With Quote
Old 03-06-2008, 04:42 AM   #2
Spyrus
Set 5-5-4-13 tRRD = 3 tWR = 6 and not 4 and you could go further with more vdimm
__________________
My Rig:
E8400 TRUE120@Asus Maximus Formula@2x2GB Geil Evo One PC6400 4-4-4@Corsair HX 620W
Connect3D HD4850 512MB@Intel X25-M G2 80GB@Casetek 1022-5@LG 19"1970HQ TFT
Creative Inspire 5.1 5100@Samsung SH-S203B SA@Microsoft Business Hardware Pack
Spyrus is offline   Reply With Quote
Old 03-06-2008, 01:31 PM   #3
techguy2k5
What about clocks? I could care less about tighter timings TBH. tRD, CAS, and command rate are the only really important ones anyway.
techguy2k5 is offline   Reply With Quote
Old 03-06-2008, 07:09 PM   #4
fireice2
fireice2's Avatar
what chips are used in these?
__________________
Rig Specs
Intel Core 2 Extreme QX9650 4.0ghz 1.37v - DFI Lanparty UT P35 TR2 - 4x1GB Team Xtreem DDR2-1066 - Palit 8800GT Sonic 512MB GDDR3 256-bit
160GB Seagate Barracuda 7200RPM SATA II 8MB Cache - 320GB Western Digital Caviar 7200RPM SATA II 16MB Cache - Liteon 18X DVD-Writer /w LS
640GB Western Digital SE16 7200RPM SATA II 16MB Cache - Corsair HX 620W Modular PSU - Cooler Master Stacker 832
Auzen 7.1 X-Plosion - Zalman ZM-DS4F - Sennheiser HD212 Pro - Edifier M2600
Custom Water Cooling
Dtek Fusion Extreme CPU Block - Swiftech MCR-220 - Swiftech MCP655-B - Swiftech MCRES-MICRO Reservior - 7/16" ID x 5/8" OD Tubings
Dual Thermaltake A2018s 120mm Blue LED Smart fans.
www.mni-photography.site88.net
fireice2 is offline   Reply With Quote
Old 03-06-2008, 07:16 PM   #5
3lfk1ng
3lfk1ng's Avatar
Impressive speed for 8gigs. Nice to see the Maximus handle it.
__________________
e3110 @ 4.25 GHz Q746A545 | Asus x48 Rampage Formula | 8GB G.Skill F2-8500CL5D | Sapphire 4870 512mb| OCZ GameXstream 850W | Thermalright Ultra-120 Extreme |
Auzen X-FI Prelude | Custom Thermaltake Kandalf | Crystalfontz-635 | Gateway FPD2485W 24" | Klipsch Promedia 2.1 | G7 | G15 | Black Icemat | Dual Boot XP Pro & Ultimate x64
3lfk1ng is offline   Reply With Quote
Old 03-06-2008, 11:38 PM   #6
Desert Igel
Send a message via ICQ to Desert Igel
Because of that low voltage they could have Powerchips. Elpida would have needed more VDIMM and I don't know any other cheap 1 Gb chip with overclocking headroom.
Desert Igel is offline   Reply With Quote
Old 03-06-2008, 11:45 PM   #7
Cronos
Have you tried Memtest86+ ? Will it pass test 5, several times at least?
It's strange i can't run any of my eight sets of G.Skill PC8000 at anything lower 5-5-5 yet many people report 5-5-3. I find it hard to believe.
Cronos is offline   Reply With Quote
Old 03-07-2008, 01:04 AM   #8
Spyrus
5-5-3 is possible at 533 MHz. But to past 540 5-5-4 at least and 570@5-5-5 at least
with powerchips and stable.
__________________
My Rig:
Old 03-07-2008, 04:11 AM   #9
Darkstormz
Yeah my 24/7 clock is 8h Memtest86+ stable also. Thats the first thing I try.
And here is an update for ya
552MHz - DDR1104 - CL 5-5-3-13 :: tRFC 52 :: tRRD 1 - 1.95v - 4x2GB
__________________
Old 03-07-2008, 04:25 AM   #10
Spyrus
Wow very tight secondary for those sticks.
tWR = 4 is also tight for them this is good not only tRRD=1!
But i am not sure if you can keep that to reach 570+
__________________
My Rig:
Old 03-07-2008, 04:54 AM   #11
Darkstormz
Testing now. But I cant run 570MHz with 2v or less. CRAAP!
__________________
Old 03-07-2008, 05:55 AM   #12
TinyRK
TinyRK's Avatar
Indeed, they use Powerchips.
They are the only ones which have 2GB strips.
__________________
  • E6750 with Scythe Infinity- 120mm PWM
  • 2x2GB ReaperX HPC PC2-8000
  • Seagate 7200.10 500GB & 320GB
  • Asus Maximus Formula S/E
  • MSI NX8800GT-T2D512E-OC
  • X-Fi Fatal1ty Platinum FPS
  • Antec Quattro 850W
  • Logitech DiNovo Edge & MX1000
  • in a LianLi
TinyRK is offline   Reply With Quote
Old 03-07-2008, 06:23 AM   #13
Spyrus
Strips?
570 with 2.0V do they boot?
__________________
My Rig:
Old 03-07-2008, 08:04 AM   #14
zfactor
zfactor's Avatar
aren't these rated for 2.1 - 2.2v anyway..??
__________________
upgrading...cooler master cm690 case, corsair hx850, samsung 1tb x 3, optiarc burners x2, gskill 4gb ripjaws, working on the rest again
zfactor is offline   Reply With Quote
Old 03-07-2008, 08:42 AM   #15
Darkstormz
Strips?
yeah they boot into windows. But not stable. P95 crash after 2min
Quick test update. Will let them run 12h later tonight and see if they´re stable.
560MHz - DDR1120 - CL 5-5-3-13 :: tRFC 50 :: tRRD 1 - 1.98v - 4x2GB
__________________
Old 03-07-2008, 08:49 AM   #16
zfactor
zfactor's Avatar
do you think with maybe 2.1 or so they could go any higher or have you tried that?? just curious
__________________
Old 03-07-2008, 09:01 AM   #17
Darkstormz
Well with the timings above I might be able to get 5-10 more MHz.
__________________
Old 03-07-2008, 09:29 AM   #18
zfactor
zfactor's Avatar
any idea if you went to 5-5-5-15 as rated..
__________________
Old 03-07-2008, 09:50 AM   #19
Darkstormz
575MHz DDR1150 with 2.1v using 4x2GB is no problem at all with those timings.
Just tried 600MHz DDR1200 using 2.1v = no go...
__________________
Old 03-07-2008, 10:22 AM   #20
zfactor
zfactor's Avatar
^^^ awesome thanks
__________________
Old 03-07-2008, 11:13 AM   #21
ChaosMinionX
Xtreme New Yorker
ChaosMinionX's Avatar
Send a message via ICQ to ChaosMinionX Send a message via AIM to ChaosMinionX Send a message via MSN to ChaosMinionX
So what NB voltage, and of the various memory settings available are you guys using for your kits?
My current...
NB Voltage - 1.61v
DRAM Static Read - Enabled
AI Clock Twister - Strong
Transaction Booster - Disabled (1)
Also what subtimings for your sticks?
__________________
===Under Construction===
[HeatWare]
ChaosMinionX is offline   Reply With Quote
Old 03-07-2008, 12:54 PM   #22
Spyrus
With which memory divider?
They are all good but twister strong needs more nb voltage.
And disable 1 if on 5:6 you have pl = 8.
I am using pl=7 and twister moderate on fsb=450@5:6@540-5-5-4-13
__________________
My Rig:
Old 03-08-2008, 08:26 AM   #23
clon22
clon22's Avatar
I have a pair of Corsair 6400c5dhx 2gb x 2 ver.4.1.
They say is Qimonda.
http://futron.sg/forum/viewtopic.php?t=321
My results are very similar to yours.
__________________
clon22 is offline   Reply With Quote
Old 03-08-2008, 08:59 AM   #24
zfactor
zfactor's Avatar
well i ordered these up ... ill report when i get them. i may end up getting 8gb though as they have extended the rebates on them.. hmmmmm
__________________
Old 03-08-2008, 09:15 AM   #25
mu||et
mu||et's Avatar
Please some one try 4-4-4-12 1:1 @ 450 2.1v. I cant stand 5-5-5-15.
__________________
http://img51.imageshack.us/img51/6522/newsigi.png
mu||et is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
