Page 1 of 2 12 LastLast
Results 1 to 25 of 37
Thread: Water cooling Asus Striker II Formula . with Tri - Sli
    Mar 2008
    Hi guys …
    Have just finished an upgrade to a striker 2 board ….no chipset blocks were available when I started so I made my own…..
    Here`s how it turned out….
    I wanted the Tri sli because I use a 30”monitor and to date have never been able to use it to it`s full capability…
    My preference is for smaller 8-10 mm pipework with compression fittings and the system was designed to use them ….
    The temps are good….with watercooling the Northbridge has been brought under control at last
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Nice rig, how is the temps on the third card? one pump?
    You might want to put a fan or two on the back of those cards near the power.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Xtreme Cruncher
    Feb 2008
    C:\WINDOWS\system32\
    Amazing job on creating your own waterblocks. Those look as good as the ones you can buy. What are your temps with everything in one loops (preferably load temps)? Are those 8800GTX cards or 8800Ultra cards?
    Mar 2008
    Quote Originally Posted by FUGGER View Post
    Here`s a few temperatures
    At Idle
    With Load (Crysis) but no overclock…
    Here`s the temps on the 3 GPU`s…
    Interesting to note here that even though a single loop is used with 8 mm ID pipe work the temperature rise across the 3 units is only 2 C …..this is with a water temp of around 36 C ...though I can lower that by speeding up the fans....at the moment they are at about 1200 revs...I can go up to 1800..
    The cards are 8800 GTX`s
    still experimenting.
    Jan 2008
    Nice clean 1 pc block. Can you send me one ? My Striker II still in the box waiting for the WB to be available.
    BTW, what GPU WB is that? Koolance or DD Ion?
    FS: MM UFO Horizon Black + Clear Side/Top
    I am Xtreme
    Dec 2003
    Omaha, NE
    He mentioned it was koolance just a couple of inches above your post.
    Thermaltake Xaser VI Case
    ASUS P7P55 Motherboard
    Intel i7 870
    AMD 4870X2
    8 gigs of OCZ Fatal1ty DDR3
    CoolIt Boreas 12 TEC CPU cooler
    Coolermaster UCP-1100W PSU
    Quote Originally Posted by {GOD}Raptor22
    I find it exceedingly humorous how you sit here and continue to play keyboard warrior even though you know you are wrong.
    Aug 2007
    Arlington VA
    Very nice, I've been waiting on some blocks for the Striker II before I take the plunge.
    AMD Phenom II BE, ASUS Crosshair II formula, 8gb ddr2 800, 470 SLI, PC P&C 750, arcera RAID, 4x OCZ Vertex2, 2x samsung 7200 1tb, HT Omega Clario +
    Jan 2008
    Quote Originally Posted by biglipzit View Post
    Where? Please point that out. I just can't see it and im not on drug.
    Mar 2008
    Quote Originally Posted by QuadSLI View Post
    My fault Quad ....I edited it so I can give you the full spec...
    I am Xtreme
    Jul 2007
    The Sacred birth place of Watercooling
    very nice work on those blocks and a great overall system
    Quote Originally Posted by skinnee View Post
    No, I think he had a date tonight...
    He and his EK Supreme are out for a night on the town!
    Xtreme Cruncher
    Oct 2004
    Germany, near Stuttgart
    nice system
    E2160 @ 360x9, max 390x9 watercooled
    GA-P35-DS3
    Cellshock D9GMH @ 545mhz cl5-5-5-5-15
    Palit 7300gt 500/1000 @ 780/1600 watercooled
    Mar 2008
    Yep…. Koolance ….as I already had 2 8800 GTX`s with the Koolance blocks on that I had on an Evga 680i for awhile I purchased another 8800 GTX (non retail in a bag) and then went looking for another Koolance water block…….everyone was out of stock here in the UK so I ended up getting it from Denmark….
    By cutting the vent off the bottom card I was then able to fit my SB card.
    Matter of interest…….I know the one about not mixing copper with alum so I split one of the Koolance blocks that had been in use for nearly a year to check for corrosion….it was clean as a whistle….
    Sorry Quad ….but I used up to many favours getting it made (use of band saw…milling machine ect)….So it is strictly a one off….
    Banned
    Apr 2006
    Portishead, Bristol, England
    Do you have a drawing or photo of the internals of the blocks you made at all? Very very nice i like it.
    I personly would of used 2 PA120.2's, get some better temps then
    Jan 2008
    Very impressive on that one full coverage waterblock......can you post the what the inside layout of the water block looks like, is it safe to say it's set up in a maze like configuration?
    Also what kind of tools did you use to create the waterblocks.
    And finally, I have been thinking of using Koolance GPU blocks myself and I really like the clean set up that you have going on there. Are the GPU blocks that you have have Copper with an aluminum plate touching the coolant or is there acrillic (sp?) in between? I am only asking because of I i'm interested in galvanic corrosion.
    Jan 2008
    If that's not ALU, 1000% i will get these Koolance Blocks
    Anyone think that 3 EK FC will fit in there? EK one kind of thicker that the koolance.
    Jan 2008
    Quote Originally Posted by Sammo View Post
    O , NP, thx man.
    I guess i had to wait a bit more
    Aug 2006
    The Netherlands, Friesland
    You have great skills Sammo, i would i could make my own waterblocks.
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
  18. #18
    Xtreme Cruncher
    Feb 2008
    How much did the temps rise when you added the 3rd 8800GTX?
  19. #19
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    It is alu.
    I did however notice that Koolance is not using any alu in their new ATi blocks for 3850, 3870 and 3870x2. It's just gold(nickel for X2) plated copper, a thin piece of acrylic and a piece of steel to support/seal the acrylic.
    Circles SucQ!
  20. #20
    Mar 2008
    Quote Originally Posted by mcoffey View Post
    great work man, very nice.
    How much improvment did you see when adding the 3rd GPU in Crysis? I have a 30in also with 2 GTX's.
    again, very nice work.
    andyc
    Difficult to say as another double radiator was added to accommodate the Tri setup and the temp of the Cards fell by 14 C .
    The material in the Koolance is alum and gold (plated) copper …there is no reaction between gold and Aluminium ……Any copper is a long way away and earthed…..I think they are the best ….as I said I have been using one for over a year now and so far there is no sign of any corrosion…should be alright for a bit longer…
    Pete,,,,
    I`m doing a drawing and description of the waterways …will post it soon.
  21. #21
    Banned
    Apr 2006
    Pete,,,,
    Cheers dude, looking forward to it!
  22. #22
    Oct 2007
    socal
    wow you much have some high ambient my NB is at a lower temp then yours. but the idea is awesome. im sure some company is going to steal it from you now lol
  23. #23
    Dec 2007
    Wow, thats awesome, im suprised that a single pump can power this lot with over a GPM though, your custom NB block looks pretty restrictive too, but sexy, good job !
    Customized water cooling my e2160 @ 3.618GHz
    Submit yours now http://www.extreme-showcase.com
    Professional & affordable website design, development, SEO, CMS & more | PM for details
  24. #24
    Banned
    Apr 2006
    Quote Originally Posted by evil-98 View Post
    It's cold in the UK at mo and i for one as most other probs do have the central heating on to keep warm
  25. #25
    Mar 2008
    andyc
    Basically the resolutions all became more stable ….but then that might have been in some part due to the new patch……
    When I hit the default button the game loaded everything `Very High` …
    2560 x 1600 ran but only with NO antialiasing …..jerky
    2048 x 1536 ran Ok but again with NO antialiasing …..ran smoothly
    1920 x 1400 ran Ok with 4x antialiasing but it was jerky ….with 2x it was acceptable
    1920 x 1200 ran Ok with full 16x antialiasing ….…..but could slow during intense action….
    My personal preference is 1920 x 1200 … with 8x antialiasing….clear precise mouse action ……awesome graphics…..
