03-01-2008, 10:11 PM
#1
Real Temp - New temp program for Intel Core processors
Version 3.00 - Released February 4, 2009
RealTemp is a temperature monitoring program designed for all Intel single Core, dual Core and quad Core processors. It's compatible with Windows 2000, XP, Vista or Windows 7, 32 or 64 bit. In Vista or if you are in a limited account, you will need to right click on the icon and run RealTemp as an Administrator so that the driver will be properly installed.
New features include an updated user interface, a high temperature alarm, reporting of minimum and maximum VID, Quad Core ordering based on APIC ID, log file in CSV format for better Excel compatibility, Up Time counter as well as long term stability improvements.
RealTemp is available for download at TechPowerUp.
http://www.techpowerup.com/realtemp/
When using UAC in Vista or Windows 7, use the Task Scheduler to get RealTemp to start up with Windows. This method allows you to give RealTemp the necessary privileges so it can read your sensors.
http://www.xtremesystems.org/forums/...postcount=3657
With XP or if you are not using UAC, just drag a link to RealTemp.exe into your StartUp folder.
I prefer this method so nothing needs to be added to your registry and you can drag the RealTemp folder anywhere you like and anytime you like.
RealTemp 3.39 is a work in progress:
http://www.fileden.com/files/2008/3/...alTempBeta.zip
03-01-2008, 10:28 PM
#2
thanks man, downloading now and testing with my E8400 am sure that you do a great work!
congratulations!
03-01-2008, 10:32 PM
#3
Xtreme Guru
thanks it does work
i like new toys
its 4c lower in temps compared to everest n HMWmonitor
03-01-2008, 10:35 PM
#4
so i guess this wont be working in vista 64.
its 4c lower in temps than hwmonitor? which temps (in hwmonitor), cputin temp or core #0/core #1 temps?
__________________
I7 920 @ 4400 TRUE......Q9550 @ 4000
evga X58.....................DFI LP UT P45 T2R
Patriot ddr3 1600..........Super Talent 4gb
HD4890 CF...................9800GX2
Zalman 1KW.................Corsair 750
Lian LI V1000B Plus 2.....Lian LI A05b
Boot Drives are 80gb Velociraptors
all os vista64 ultimate
03-01-2008, 10:36 PM
#5
Last time I checked, Everest was using the same TjMax=105C that CoreTemp has been using for the E8000 processors.
03-01-2008, 10:37 PM
#6
At the moment I'd be happy just to hear that it works in Vista32!
03-01-2008, 10:56 PM
#7
nice soft!
if realtemp is right(hopefully) i'm doing 44-46c on load @ 1.2vcore which makes more sense than coretemp/everest @ 54-56c and speedfan is right in the middle @ 49-51c.
you can see the pattern of exactly 5 and 10 degree difference between the softs
suggestion, makes it go to tray please :P
03-01-2008, 11:12 PM
#8
well,testing the full load and works!
now stop orthos and check iddle and yes the software run excellent
real time bench
real temp highly recommended!
03-01-2008, 11:17 PM
#9
10 degrees lower than everest and coretemp and 5 than speedfan...but when i test idle temp calibration it say that core 1 is bad (core0 ok) so its poss to make correct the core 1 too?nice job...congratulation
__________________
Asus P5q Deluxe - Intel C2Q 9550@4.1 Ghz 1.28V -ATI HD 5850 -Patriot EL 8500(2X2Gb)-Zalman 9700 NT-monitor 24" Full hd-Enermax Noisetaker 600 w
03-01-2008, 11:25 PM
#10
Anyone test in Vista32 yet? I can try it when I get home in 6+ hours...
__________________
Giga EP45-UD3P
Q9650 @ 4.05Ghz 1.28v (4.6+ benchable @ 1.4v)
RaptorX, 640GB Caviar Black
GTX260 216 55nm @ 810/1656/1215 (max benchable @ 1.12v)
4GB OCZ Platinum @ 5-4-4-12 950Mhz PL9
X-Fi Extreme Gamer
Corsair 620HX / Antec 1200
HP 2207 22" 1680x1050
MCP655 - 120.3 - Fusion v1 - MCW60
03-01-2008, 11:38 PM
#11
Its great!
Thanxs Hersounds for the recommendation!
03-02-2008, 12:06 AM
#12
I've tried doing this in Vista and it doesn't work
__________________
Intel Inside
03-02-2008, 12:08 AM
#13
what if you dont know any C++ programming?
__________________
Signature removed due to failure to follow Policies & Guidelines.
Please read them, located at the top of the forums.
Unapproved/Unaffiliated link.
03-02-2008, 12:30 AM
#14
eye get a run time error ..... maybe cause eye all clocked up to 4.0
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG.. http://www.xtremesystems.org/forums/...d.php?t=197660
03-02-2008, 12:39 AM
#15
Niiiice!!
Under Small FFT's test, now real temp shows 10C lower temps than coretemp, is that right?
I am happy now!
__________________
ASUS P6T Deluxe V2
INTEL74 CORE I7 920 D0 (3924A346) 20*180MHz ~ 1.176V @ SCYTHE MUGEN2
3*1GB MUSHKIN XP3 @ 1440MHz CL7-7-7-21 ~ 1.60V
ZOTAC GeForce GTX260 @ 650/1300/2400MHz ~ ARCTIC COOLING ACCELERO GTX280
CORSAIR VX-550W
>>Micron D9 based RAMs and Electromigration<<
HUNGARY
03-02-2008, 12:48 AM
#16
Diablo 3! Who's Excited?
Reads sub-zero? Would be wicked sweet if it did
__________________
Team PURE is about kickass pirates and unicorns defeating ninjas.
03-02-2008, 12:51 AM
#17
Xtreme Mentor
many thanks
http://myfreefilehosting.com/f/2244b24a85_0.05MB
what type of file is this? how to extract?
__________________
ASUS P5K-E // E8400 Q746A519
G.Skill F2-8000CL5D-4GBPQ
LC 550W GP// XPERTVISION 9600GT
03-02-2008, 01:04 AM
#18
Wow! Nice post.
__________________
".. an ounce of honest data is worth a pound of marketing hype." - Spec.Org
03-02-2008, 01:12 AM
#19
ok downclocked and still get a runtime error
__________________
FOXCONN MARS
Quattro 1000W
*REAL TEMP*
03-02-2008, 01:15 AM
#20
Thanks for the software. The core temp reading is same as speedfan. Only bug I found is my E6320 is detected as Xeon 6320.
__________________
Core i7 920
Scythe Mugen 2
Silicon Power DDR3-1333 2GBx3
Gigabyte EX58-UD4
Palit GTX 260 Sonic 896MB
Samsung Spinpoint F1 640GBx2 Matrix RAID
Samsung Spinpoint F2 1TB
Creative Audigy 2 ZS
Winfast TV2000 XP Expert
Antec Earthwatts 650W
Coolermaster CM 690
LG W2442PA
Win 7 RC x64
03-02-2008, 01:26 AM
#21
Xtreme Mentor
how to run this program?
__________________
03-02-2008, 01:28 AM
#22
It is all written down in the very first post....
__________________
ASUS P6T Deluxe V2
CORSAIR VX-550W
HUNGARY
03-02-2008, 01:29 AM
#23
tedy download the software then when extract the.rar, search the folder sys,ia32.inf...this is the file that you have install like a new device, and then simple use the .exe and that is all!
03-02-2008, 01:32 AM
#24
Xtreme Mentor
i did installed inf....but where is .exe? :P
__________________
03-02-2008, 01:38 AM
#25
in the same folder that the folder sys!!
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
