Do you want candy?
Official specs and marketing:
BL2KIT25664AR804
• Module Size: 4GB kit (2GBx2)
• Package: Ballistix Tracer 240-pin DIMM (with LEDs)
• Feature: DDR2 PC2-6400
• Specs:
• DDR2 PC2-6400 4-4-4-12
• Unbuffered
• NON-ECC
• DDR2-800
• 2.2V
• 256Meg x 64
Are you ready to blow the hinges off your modules? Outfit your system with the new clipless, candy-apple red Ballistix™ Tracer™ modules from Crucial.
Our highest density Ballistix module yet, the Ballistix Tracer Red modules feature 2GB of 800MHz DDR2 goodness. Add to it the bright red heat spreaders, red PCB, red LED lights, plus a raised and diamond-cut logo and clipless design—our Crucial Ballistix Red 2GB DDR2-800 module or 4FG kit delivers outstanding results for PC performance enthusiasts everywhere.
For systems with dual-channel DDR2-based motherboards, Ballistix Tracer Red is ideal for users craving faster response time and improved reliability. It's a high-performance, low-latency memory option that's the perfect blend of sugar and spice—sweet looks on the outside, red-hot performance on the inside
_________________________________
The package and the contents:
Crucial continue their no-frills packaging with the Tracer Reds. These are also more minimalist than previous shipping boxes, being half the depth. Will good things come to those who don’t judge books by the cover?
[CENTER]
The no-frills packaging is in complete contrast to the contents which are a LOT more bling: Bright red PCB, bright red heatspreaders with polished aluminium-edges and raised logos.
The bling doesn’t stop there- heres some pictures of the RAM installed and powered up:
Pics of RAM installed and powered up
I suppose the visual aspect of RAM like this is fairly cut and dried- there it is. Beauty is in the eye of the beholder, so I will not comment. I do not think many people will buy this for chasing the highest possible RAM clocks or for aggressive benchmarking.
It should be popular with case modders and gamers, who expect excellent stability and reliability, which I associate with lower voltages. Because of this, most of the testing will be at voltages at which Crucial will honour warranties.
Going into detail.
The ICs are made using a 78nm process, which allows a higher density of cells to be packed into the same space whilst staying within an acceptable power consumption and heat envelope. The 64MB chip density of 2x1GB modules has doubled to 128MB to allow 2GB to be placed onto one stick.
Seeing as the numbers of cells that can be addressed has doubled, one would expect the maximum performance of these sticks to be slightly lower than older 1GB sticks. This theory has been hinted at by several members of assorted enthusiast forums (including this one.) I am entering this review with a fairly open mind. I believe that there is excellent performance to be had from these sticks if they are approached in the right way.
Test setup- notes, drawbacks and assumptions
All tests will be carried out on an Asus P5K-E motherboard, BIOS 1004. Two generic low-speed 80mm fans were positioned over the RAM at all times.
No VDIMM values lower than 1.95V were possible (board limitation.)
All voltages were measured using a Digital Multimeter which was placed across the relevant pins of a DIMM slot to provide the most accurate possible readings.
4GB kits of RAM need slacker tRAS and tRFC timings than 2GB kits. This was made apparently as testing progressed. I associate these timings with stability, not performance so I do not think that changing these timings will have a negative effect on performance.
tRRD, Write to Precharge and Write to Read delays were also considered “irrelevant” for the RAM. They have been tested and considered stable at 3,9,9 respectively to 693MHz using 2x1GB kits. I will assume for this review that IC density will not have an effect on this.
There appear to be few applications currently available that can make full use of 4GB of RAM. SuperPi 32M only uses around 600MB, so cannot be considered a full-blown stress test. I used Windows Memtest v3.6 as the primary test, using 4 instances of either 740MB or 750MB each (as other background apps would allow) and took 2 full passes of each instance as stable (partly due to time constraints.) SuperPi 32M was also used however.
I am limited to a 32-bit O.S. currently (Windows XP Pro,) so only 3.4GB was available for use. I appreciate this is not ideal, but it is still a popular O.S. and I believe several people will have a 4GB RAM setup in place before moving to a 64-bit O.S. so these tests should still carry some real-world parallels.
