Results 1 to 1 of 1
Thread: e8400 with MSI p35 Neo2-FR 4.3ghz Achieved, but not 4.5ghz! Help?
    Nov 2007
    Canada
    Exclamation e8400 with MSI p35 Neo2-FR 4.3ghz Achieved, but not 4.5ghz! Help?
    I got an e8400 with my neo2-fr board.
    I achieved 4.3ghz stable, but I cannot seem to get 4.5ghz no matter what I try.
    I have a picture of my Cell menu
    Here are my Specs:
    Case: Antec Nine Hundred
    RAM: OCZ 6400 Platinum 800mhz@2.2v
    PSU: OCZ Powerstream 520w 12v@12.40
    This attachment is my cell menu for stable 4.3ghz achieved.
    Has anyone reached 4.5ghz with this board? If so, What cell menu options did you use?
    THANKS.
    ALSO:
    I'm noticing a massive vdroop from 1.52 down to 1.48 on cpu load. Does this have anything to do with the bios? I'm using version 1.8
    Because when i used this board with my allendale e6300 b2 revision, I kept the bios at 1.1 because any other version resulted in mad vdroop...
    What do you guys think?
    UPDATE: Changed FSB overclocking jumpers from default 200mhz to 333mhz with no result.
    q9550 e0 4.1ghz
    Corsair H100 Mx-3 + TriCool
    Asus Rampage Formula R4 BIOS
    Sapphire 7970 3gb Dual x OC 1200/1700 (reference) re-pasted MX-3
    CM Cosmos S RC-1100 w/6 TriCools
    4xOCZ2G10662G (8gb DDR2 RAM)
    Corsair AX1200 PSU
    SB X-Fi Extreme Audio PCIE w/Z-5500's +Corsair Vengeance 2000
    G15 rev2 + G13 + G9x
    GOT RAMPAGE?
    CHECK FOR MEMORY ISSUES
