Q9450's shipping the 17th!
http://www.shopblt.com/cgi-bin/shop/...er_id=!ORDERID!
You could get the 9450, see how far it'll take you, if that is unsatisfactory, sell it.
"Language cuts the grooves in which our thoughts must move" | Frank Herbert, The Santaroga Barrier
2600K | GTX 580 SLI | Asus MIV Gene-Z | 16GB @ 1600 | Silverstone Strider 1200W Gold | Crucial C300 64 | Crucial M4 64 | Intel X25-M 160 G2 | OCZ Vertex 60 | Hitachi 2TB | WD 320
I did get it to post at 500x8 but for some reasons I had USB issues so wouldn't load windows. That was on a P35 mobo.
Have a look here for what someone else had tested....
http://www.xtremesystems.org/forums/...highlight=9450
Well thanks for the inputs guys. The thing is I think I will go ahead and get the Q9450 and see where can it go in the DFI LP X38-TR2.
I always like less volts and cool compared to the hot Q6600.
I feel like if I buy a q6600 with a 1.20v Vid for 300 I could get a q9450 for $49 more...
And as I said my Quad wont go above 450Mhz x 9 in this board thats disappointing. Probably I will have better luck with the new 45nm cpu's and as you got it into 500fsb mark thats not impossible.
i really think the quad core is a niche product right now...
you've already heard more than a handful of people say its a lot more (aggregate) processing power than the majority of applications require.
i myself am trading to a dual core wolfie, losing 2 cores for a large increase in clock, which for me and my gaming scene is more important...
WoW and crysis suck pondwater with a 2.4ghz clock on a 24" monitor powered even by an OC'ed 8800gtx
for the glory of bardob!
I dont think the Q9450 is a worthwhile upgrade from the Q6600 unless the FSB ceiling is raised a LOT.
lower clocks for more money. The cache wont make up for the MHz grunt, not for most multi-threaded apps anyway.
The Q9550 is worse- will equal or slightly surpass the Q6600 in terms of MHz but will cost twice as much![]()
I am telling most people to avoid the common Yorkfields unless they run at stock speeds. I'm saying this as the Kentsfields will easily do 500FSB in a P35 board and respond incredibly well to voltages and cooling. Yorkfields with the low multiplier will max out the chip before you max out the voltage and cooling. With proper cooling you can get a Q6600 up to 4300+Mhz 24/7, that's what mine ran under my single-stage with 1.55v. Sure a Q9450 might do 4GHz on air, but for me, the need for speed is insatiable.
I ordered the Q9450 myself....but it cost €308, is that good or bad??
Gigabyte EP45-DQ6 - rev 1.0, F13a bios | Intel Q9450 Yorkfield 413x8=3.3GHz | OCZ ProXStream 1000W PSU | Azuen X-Fi Prelude 64MB X-RAM| WD VelociRaptor 74HLFS-01G6U0 16MB cache 74GB - 2 drive RAID 0 64k stripe | ASUS 9800GT Ultimate 512MB RAM (128 SP!!) | G.SKILL PC2-8800 4GB kit @ 1100MHz | OCZ ATV Turbo 4GB USB flash | Scythe Ninja Copper + Scythe 120mm fan | BenQ M2400HD 24" 16:9 LCD | Plextor 716SA 0308; firmware 1.11 | Microsoft Wireless Entertainment Desktop 8000 | Netgear RangeMax DG834PN 108mbps; firmware 1.03.39 + HAWKING HWUG1 108mbps USB dongle | Digital Doc 5+ | 7 CoolerMaster 80mm blue LED fans | Aopen H700A tower case | Vista Home Premium - 32bit, SP1
I really wish the Q9450 had a 9x multi.
450x8=3.6GHz...i'd be happy with that.
Anyone know when the other Yorkfields will be coming out? It looks like there is some disagreement amongst the elite in here as to what the Q9450 and Q9550 can do ...![]()
I reallyreallyreally want the Yorkfields to be able to reach 500 FSB fairly easily. But it's really not looking like they'll do it for now, so if you have a Q6600 that reaches 4.0Ghz, I'd keep that.
Maybe in 6 months or so, Intel will release a new stepping of the Q9450's which will get 500+ FSB.
Eller
Desktop: Q6600 G0 @ 3.6 Ghz | P5E | 2x2 Gb G.Skill PC8000 | GTX 560 Ti | CM690 | TT TP 750 watt | Win 7 Pro x64 | Water Cooling
Server: i3 530 (Stock) | CM Vortex Low-Profile | Zotac H55-ITX WIFI | 2x2Gb Corsair 1333Mhz | IGP | VX450 | Server 2008 R2 x64
I will be going straight from my conroe to yorkfield, but only in the summer when I get a clearer picture of the OC abilities of retail chips in general.
Perhaps, by then, some cherry picked ones will be for sale too![]()
http://www.tgdaily.com/content/view/36367/118/
but still none to be foundIntel churning out 100,000 45 nm processors every day
Q3'08 crossover
i7 3610QM 1.2-3.2GHz
Where is everyone pre-ordering from?
All from the site listed? Or do other sites have them as pre-order?
Cooler Master Stacker 830
Enermax Galaxy 1000w
Asus P6T Deluxe
Core i7 920 @ 4.0 Ghz.
6gb G.Skill PI Black @ 1600 mhz
2x EVGA GTX280 SLI @ 700/1500/2400
There are some other sites as well, most of the sites ive been seeing are over 350, so i went with these guys.
