Results 1 to 25 of 54
Thread: [dinos22-Team.AU] Bench session with E8500 > W.R. Superpi 32M, wPrime 32M & 1024M
Threaded View
    Xtreme Legend
    Mar 2005
    Australia
    Talking [dinos22-Team.AU] Bench session with E8500 > W.R. Superpi 32M, wPrime 32M & 1024M
    Team.AU strikes again!!!
    First of all big thanks to k|ngp|n for making such an awesome LN2 pot >> namely F1 Extreme Edition. If you guys haven't got one go buy it cause it kicks ass
    Had a fun benching session today and it seems i nailed some dual core world records here (correct me if i'm wrong pls )
    Thanks to Kosta for lending me his board and RAM sticks
    Note: both air and LN2 max benchable FSB was 596-600MHz
    i've tried everything except LN2 on NB which will probably help a little but it's just very very odd
    Test Configuration:
    Asus P5B DLX DDR2 Motherboard (1226 bios) FULLY VMODDED
    **1.8vcore, 2.44vdimm, 1.80vMCH, 1.8vSB, vdroop/drop pencil mod**
    Intel Core2 Duo E8500 Q745A703
    2GB DDR2 Corsair Dominators
    2GB DDR2 Crucial Ballistix
    PCI Express Nvidia 8400GS
    620W Corsair PSU
    Swiftech copper heatsink on NB
    kingpin F1 Extreme Edition Solid copper CPU LN2 Pot
    Big mamma 35L LN2 Dewar
    80GB SATA Hard Drive + 160GB PATA
    Windows XP Pro 32bit + PATA Dual boot XP Pro/Vista Ultimate 32-bit
    YOUTUBE VIDEO: http://www.youtube.com/watch?v=ZDPrXMep6u4
    i mentioned screen not refreshing in the second part >> changed to PATA drive and it went away
    W.R. for dual cores for both 32M & 1024M wPrime
    32M time: 13.479s
    1024M time: 7m 04.585s
    W.R. for dual cores for 32M SuperPi
    32M time: 8m 31.047s
    ............some of you guys say Windows Vista is slow for SuperPi
    hehehe ARE YOU SURE
    didn't use maxmem no wazza here
    normal Vista services all running
    I ran into some stability problems, changed the drive and benched wPrime but forgot to redo this test at higher speed >> would have had the record on this as well
    I ran into some stability problems, changed the drive and benched wPrime but forgot to redo this test at higher speed >>> sub 8s on the next session i think
    LN2 PREPARATION
    AIR COOLED TESTING
    596MHz 8M SuperPi stable
    NO CHANGE IN FSB on LN2
    with the right board this CPU will benchmark at 6GHz
    QUICK RAM TESTING 2.44-2.48vdimm (tried 2.5/2.54v at 650MHz 8M to see how it responds to volts bumps >> basically all good )
    Team.AU
    Got tube?
    GIGABYTE Australia
