Page 1 of 4 1234 LastLast
Results 1 to 25 of 86
Thread: kris 4851MHz X2 5000+ BE <- own up?
    Xtreme Mentor
    May 2007
    http://valid.x86-secret.com/show_oc.php?id=309749
    Click image for larger version.
    It's fully valid according to Franck but no email addy etc.
    So, who are you kris, how did you achieve it, specs, details, pics, any benches, coldbug, etc?
    We're talking C2D MHz here.
    Official hunt declared.
    May 2007
    There's no place like 127.0.0.1, Brazil
    I already post in the x2 overclocking and discussion, but no1 goes there
    I have doubts about this clock...thats a stunning 587,4 MHz clock difference to the second place. And its done on a AN-M2HD with IGP If thats real im very impressed.
    May 2004
    Hmmm... I'd say bug
    Dec 2007
    Dallas, Tx
    yea we need a setup and volts ASAP. Nice work. Looks like I need to order another 5000 BE, mine is walled at 3300
    Current Rig: Broke i7
    Lian Li 1200 -- Foxconn Bloodrage -- Intel i7 920 @ 3.2Ghz -- Corsair Dominator GT 6GB @ 1925Mhz -- 9800GX2 -- Corsair HX1000 PSU -- Patriot Inferno 100GB SSD -- EK350 block Swiftech 220 S-Flex's all around
    Xtreme Mentor
    Feb 2004
    The Netherlands
    uh, K8 just can't clock that high :x
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
    Dec 2007
    Dallas, Tx
    Quote Originally Posted by biohead View Post
    Obviously it can. Only question is how did he do it?
    Jun 2002
    Ontario, Canada
    Probably a suicide run and likely no benches at that speed. Great overclock though!
    As quoted by LowRun......"So, we are one week past AMD's worst case scenario for BD's availability but they don't feel like communicating about the delay, I suppose AMD must be removed from the reliable sources list for AMD's products launch dates"
    Mar 2005
    Pennsylvania
    I was thinking the same thing, 1 run wonder!
    Daily Desktop Custom Built - Modified Data General Server Case
    Asus M4A79T Deluxe | 955BE C2 Rev | 4GB OCZ DDR 2000 @ 1600 6 5 6 1T | 4850x2 + 4850 w/MCW60 | CPU on H20 w/ Enzo Sapphire l Custom Built Pump and Res Combo 1/2 Gallon! | 4 Swiftech 320mm Rads with 6 All Aluminum Delta Fans with their own PSU - Finger Loppers - for real!
    Literally, CPU&GPUs are almost always at ambient therefore heat ain't limiting sh|t.
    Xtreme Guru
    Jan 2005
    waukegan
    ^^ his name is chris too. omg1?!?!?!
    mobo: strix b350f
    gpu: rx580 1366/2000
    cpu: ryzen 1700 @ 3.8ghz
    ram: 32 gb gskill 2400 @ 3000
    psu: coarsair 1kw
    hdd's: samsung 500gb ssd 1tb & 3tb hdd
    Dec 2007
    Dallas, Tx
    Quote Originally Posted by freeloader View Post
    Yea I figured that too.
    The highest I can get right now is 34xxmhz @ 1.45v load into Windows but then it BSODs. It sucks. I'm thinking about ordering another BE and see if I can get a bit further. I really think I can hit 4Ghz on water and make it stable.
    Wanna look under my kilt?
    Jun 2005
    Glasgow-ish U.K.
    vote bug/generally BS.
    Arent there only a handful of people to even get AM2 over 4GHz, now all of a sudden we have 4.8GHz? Yea, right.
    you sigged that?
    why?
    ______
    Apr 2007
    Some 2.5V vCore and some crippled Windows boot, fast validation and crash. That, or fake. Go figure.
    Dec 2007
    Dallas, Tx
    2.5v on the cpu would be nuts. I'd expect mine to start smoking or something.
    Xtreme Mentor
    May 2007
    Well, bug vs. no bug is a tricky one. There's no CPU-Z bug according to the man who verified it and verifies all of our CVF files; Franck deems there's no difference in this validation and any other X2 genuine one. But I'm still thinking how and also, the guy who did it must have known what he did was a one off...
    In which case he would've boasted about it somewhere at least.. if it was for real, since the cooling and setup required had to be LN2 aswell
    Not sure what happened here, time should tell.
    It's either or or just
    Aug 2006
    wow...on a crappy mobo to boot...and both cores are enabled either someone got lucky and found the wonderchip or cpuz has a flaw!
    Xtreme X.I.P.
    Oct 2006
    CPUz shows wrong frequency very rarely, but it happens. This is (obviously) not a real score. First of all, it's just too good compared to other scores (like a 7GHz Yorkfield). 2nd reason: AMD chips have a different coldbug than Intel chips. Lower temps = lower FSB limit (not a wall, like in Intel chips). 300mhz++ fsb on AM2 can't be achieved on dice or ln2 because of this, and it's not possible to get that score on something like a chiller, no way.
    And can that mobo even do that high FSB??
    Master of nebulah frost
    Dec 2004
    Dolomites(Italy)
    4850mhz on AMD it's actually hard to belive
    Battlefield 3: Nachthymnen666
  18. #18
    Aug 2004
    Scotland
    Quote Originally Posted by cdawall View Post
    AN-M2HD isn't that crappy especially if you don't use the IGP & improve the chipset cooling.
    It's certainly capable of doing 323fsb.
    abit IP35 Pro, E6600, HD3870, FSP FX700-GLN
    abit AB9 QuadGT, E6400, 7900GTO, FSP FX600-GLN
    abit AX78 x2
    Asus P5N-E SLI, E6600, 8800GTS, Tagan 530W
  19. #19
    Oct 2005
    Melbourne, Australia
    I think I read somewhere on these forums that it's possible to fake 3dmark scores, and high frequencies.
    found the thread:
    http://www.xtremesystems.org/forums/...ad.php?t=46926
  20. #20
    Sep 2006
    If it's real, even just a suicide run, it's still impressive.
  21. #21
    Jan 2008
    Vancouver,British Columbia, Canada
    "Rated FSB"
    I have seen this in the X2 thread btw
    World Community Grid's mission is to create the world's largest public computing grid to tackle projects that benefit humanity.
    Our success depends upon individuals collectively contributing their unused computer time to change the world for the better.
  22. #22
    Oct 2005
    EvE-Online, Tranquility
    Maybe he got past the cold bug? Dont know if it's possible, but if you make sure the CPU stays around lets say -10 and just increase the cooling every Volt/Mhz bump so it stays at -10?
    So not a -200 run right away, start slowly and adjust the cooling to target temp?
    Synaptic Overflow
    CPU:
    -Intel Core i7 920 3841A522
    --CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
    ---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
    Motherboard:
    -Foxconn Bloodrage P06
    --Blck: 200Mhz| QPI: 3600Mhz
    Graphics:
    -Sapphire Radeon HD 4870X2
    --GPU: 750Mhz| GDDR: 900Mhz
    RAM:
    -3x 2GB Mushkin XP3-12800
    --Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
    Storage:
    -3Ware 9650SE-2LP RAID controller
    --2x Western Digital 74GB Raptor RAID 0
    PSU:
    -Enermax Revolution 85+ 1250W
    OS:
    -Windows Vista Business x64
    ORDERED: Sapphire HD 5970 OC
    LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
  23. #23
    May 2005
    [EU] Latvia, Jelgava
    With voltage needed to achieve 4.8Ghz this boards pwm would blown up. G2 Brisby have awfull coldbugs, so this is totally faked result, there is no way to reach 4.8Ghz on this chip. Even 3.8Ghz on this board would be hard to believe.
  24. #24
    Apr 2005
    wow............it's the highest oc to amd cpu i saw !
    kewl and great news !
    Gaming: SaberThooth X79,3930k,Asus6970DCII_Xfire,32gb,120OCZV3MaxIOPS, ThermaTake Chaser MK1
    HTPC:AMD630,ATI5750,4gb,3TB,ThermalTake DH103
    Server: E4500,4GB,5TB
    Netbook: Dell Vostro 1440
  25. #25
    Apr 2007
    Quote Originally Posted by gillll View Post
    Not so great when it is fake.
