Results 1 to 21 of 21
Thread: Making 2x2GB PC8000+ DDR2 Compatible
    Dec 2005
    Athens,Greece
    Thumbs up Making 2x2GB PC8000+ DDR2 Compatible
    Since many users and myself amongst them, bought some G.Skill or Mushkin PC8000+ 2x2GB Kits,
    we cannot have them posted beyond 980+ MHz especially in motherboards
    with no manual adjusting of tRFC > 42 for example my Maximus Formula
    What i did?
    I downloaded the old favor spdtool found here http://www.xtremesystems.org/forums/...d.php?t=123624.
    For those having Muskin Redline 8000 @ 5-5-5-15 @ 2.1 Volts like me
    this is the screenshot from default spd.
    As you can see the tRFC value = 42 and in order to make them compatible
    must be set at least at value = 52.
    Just use the tool and locate tRFC and put there 128.33ns.
    That's it you can flash your modules with new spd.
    Do not forget to fix checksum first.
    New spd is like that:
    My memories running now with moded spd:
    Try at your own risk. I have no responsibility if something goes wrong
    E8400 TRUE120@Asus Maximus Formula@2x2GB Geil Evo One 800MHz 4-4-4@Corsair HX 620W
    Sapphire HD6850 1GB@Samsung 830 128GB@Casetek 1022-5@LG 19" 1970HQ
    Creative Inspire 5.1 5100@Samsung SH-S203B SA@CM Quickfire Pro Red@Logitech G-600
    G.Skill USA Tech
    Sep 2005
    our trfc value at spd is on 52 already
    use auto on x38 and p35 will give you 52 or 68 depends on motherboard bios
    Feel free to contact ustech@gskillusa.com or use our G.Skill Q&A Sub-Forum, if having any questions about G.Skill products
    Check out our items on NewEgg
    Feb 2006
    Potosi, Missouri
    The G.Skill PC2 8000 sticks I have tested in P35/X38 boards have all defaulted to a tRFC of 52. That should be plenty for 2x2GB at PC2 8000 speeds.
    Dec 2005
    Athens,Greece
    Quote Originally Posted by G.S Technician View Post
    In fact is 51 according to an spd dumb from a friend of mine on G.Skill PC8000
    and it will do it as you said with auto.
    But for whatever memory has that problem someone can do the trick
    Also someone can set higher tRFC than 52 if that helps him in overclocking
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    Quote Originally Posted by Spyrus View Post
    Just set it higher manually as you wish.
    Formerly XIP, now just P.
    Dec 2005
    Athens,Greece
    Maximus Formula cannot set higher than 42 and maybe other Asus motherboards as well.
    X.I.P
    Mar 2005
    leave it at auto will give you 52
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    anyone know the value of a TRFC at 72?
    Dec 2005
    Athens,Greece
    Quote Originally Posted by guess2098 View Post
    I do not want to triple post but no matter what i did on Formula with
    default spd auto gives me 42. End of story.
    There are many users with same problem i am not the only one.
    @Kunaak playing with spd tool will give you the value since it will show it at the
    bottom (nsec rephrased)
    G.Skill USA Tech
    Sep 2005
    because Asus doesn't have option trfc 52 but it should auto set at 52 or higher.
    i tested it on asus x38 maximus formula with latest bios. as long as memory timing at auto, it is ok at 52.
    it is really weird. let me know
    Mar 2005
    Pennsylvania
    Hey guys, I'm having a similar problem with OCZ Flex PC9600 on an AM2 board... See my thread..
    http://www.xtremesystems.org/forums/...=1#post2788213
    Can anyone help?
    Daily Desktop Custom Built - Modified Data General Server Case
    Asus M4A79T Deluxe | 955BE C2 Rev | 4GB OCZ DDR 2000 @ 1600 6 5 6 1T | 4850x2 + 4850 w/MCW60 | CPU on H20 w/ Enzo Sapphire l Custom Built Pump and Res Combo 1/2 Gallon! | 4 Swiftech 320mm Rads with 6 All Aluminum Delta Fans with their own PSU - Finger Loppers - for real!
    Literally, CPU&GPUs are almost always at ambient therefore heat ain't limiting sh|t.
    Dec 2005
    Athens,Greece
    You can do the trick also.
    Better go over ocz forums they will give you the spd with higher tRFC.
    Contact Tony.
    I am Xtreme
    Mar 2005
    Edmonton, Alberta
    Quote Originally Posted by Kunaak View Post
    Mutliply bios setting by 2.5.
    Oct 2006
    35n28, 97w31
    Brown delivered my G.Skill PC2-8000 memory this afternoon and this is my first try to see what tRFC would be.
    Click image for larger version.
Name:	GSKILL PC8000 MEMSET.jpg
    I was surprised that it was 64. tRFC can't be set in the BIOS. I set the 5-5-5-15-2T in my EVGA 780i BIOS and left the the other setting on Auto. Are there version of this memory that have different tRFC values?
    Just after I ordered this memory I started seeing all these message that 'I can't set tRFC > 42'. For several days I was wondering if I had made a mistake but if what I see in MemSet is correct then all my worrying was for not.
    | Intel Core i7-2600K | ASRock P67 EXTREME4 GEN3 | G.SKILL Sniper Series 8GB (2 x 4GB) DDR3 1866 | EVGA GTS 450 |
    | Swiftech APOGEE Drive II CPU Waterblock with Integrated Pump | XSPC RX360 | Swiftech MCP655-B Pump | XSPC Dual 5.25in. Bay Reservoir |
    | Thermaltake 850W PSU | NZXT SWITCH 810 | Windows 7 64-bit |
    [SIGPIC][/SIGPIC]
    Dec 2005
    Athens,Greece
    You have also tRC too big should be around 25.
    I think the mobo put them this way or memset is not reading well.
    Everest should show the same. You should put them on X38/P35 motherboard
    to be sure.
    Oct 2006
    35n28, 97w31
    tRC is set to Auto and shows [Auto(45)]. I could set it to 25 and see what happens. Look at the SPD tab above for EPP#1. At 500MHz it has tRC set to 45.
    [SIGPIC][/SIGPIC]
    Dec 2005
    Athens,Greece
    tRC is not tRFC usually by jedec is half of tRFC
  18. #18
    Banned
    Oct 2005
    25 with 2*2gb non-micron chips ...SHOW us
    Edit:Never mind, sorry tRC .... misread tRFC was thinking
  19. #19
    Xtreme Guru
    Aug 2005
    Burbank, CA
    This can can be useful for the evga 780i, no control over trfc
  20. #20
    May 2007
    Very nice. Will this work with the P5B-D to run 8GB at DDR2 1000 speeds?
  21. #21
    Dec 2005
    Athens,Greece
    The only reason for that to not work is if by putting tRFC to 52
    the mobo itself cannot set that value (is not supported in bios - is range limited).
    In that case i am assuming that it will put the highest value it can support, for example if highest auto value is 50 no matter what.
    For example in my laptop the tRFC value is fixed to 43 for 2x2GB modules and i have changed many values
    greater or less that 43.
