Page 1 of 3 123 LastLast
Results 1 to 25 of 58
Thread: OCZ Platinum 1600@1091 cas 8-8-8-25-1T.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    Thumbs up OCZ Platinum 1600@1091 cas 8-8-8-25-1T.
    I am exceptionally impressed with this ram.
    I posted this ram in the online deals section a few days ago, cause its only $249.99 at newegg.
    for DDR3 at 1600 mhz, thats a super good deal.
    I also read about 10 different reviews on the ram and saw some good results, and saw 1 persons results here on XS, showing 1000 at cas 7-6-6.
    so after all that, I took the plunge.
    while cheap for DDR3, spending $250 on only 2 gigs of ram, is still alittle nerve racking to me. I always worry my cheapness, will get me cheap hardware.
    this is one time where I am glad to say, being cheap, payed off nicely.
    Hardware.
    Vista 32 Ultimate.
    Maximus Extreme - Bios 0905.
    8800 GTS 320.
    1000 watt Silverstone PSU.
    CPU Cooled with a chilly1 single stage.
    chipset cooled with regular maximus block + koolance exos.
    Hijackers.
    first off, before anyone starts in with the whole "my set ups faster then yours", I just wanna say "go start your own thread".
    if its not about OCZ, or wanting to know something about my settings or whatever, dont post.
    last time I posted my thread was hijacked by 10 different people.
    some posting like 12 screenshots, to prove how fast thier PC was, saying "you should tweak yours better".
    I am not here to compete with you.
    I dont tweak for pi.
    I tweak the bios.
    I need to keep this OS usable for daily stuff, so I dont bother with all the pi tweaks and such. I am just showing what can be done with this ram - if you get a good set.
    Testing.
    Booting into windows, at 9 x 500. voltages all set high for "SetFSB" use.
    Cas 8-8-8-25-1T, all other settings at Auto.
    Transaction Booster always enabled at 3. (performance level 7)
    get into windows, set FSB up by 5 mhz increments, have CPUZ running, validate every 5 mhz. run 1M if I can. if 1M ran easy, try 8M, or 32M.
    Quick Overview.
    Cas 8-7-7-20-1T top was 1070.
    Cas 8-8-8-25-1T top was 1091.
    Top 1M was 1070 cas 8-8-8.
    did pass 1080 once, but it froze.
    did take a pic of it however, if anyones curious to see it.
    at 1091, TRFC was taken from 60 to 72.
    Transaction booster was always at enabled - 3, and 1T.
    I tried 2T, didnt help.
    1080 cas 8-8-8 Validation.
    http://valid.x86-secret.com/show_oc.php?id=313644
    1070 cas 8-7-7 Validation.
    http://valid.x86-secret.com/show_oc.php?id=313653
    Sorry these first few pics are gonna suck.
    given the size of the pics, its hard for me to edit them down to under 200k to be able to post them, while keeping them readable.
    I might have to post them on my Imageshack account, to keep the pics readable.
ID:	72388   Click image for larger version.
ID:	72389   Click image for larger version.
    Memory Addict
    Aug 2002
    Brisbane, Australia
    nice looking forward to seeing max mem clocks for 6-5-5-x, 6-6-6-x, 7-6-6-x and 7-7-7-x
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by eva2000 View Post
    your trying to wear me out huh?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    no pressure
    Mar 2007
    Ontario, Canada
    Good to hear!
    I got some of this ram, but no mobo yet
    But should be soon hopefully!
    CPU: Lapped QX6700 @ 4000MHz, bench @ 4250MHz
    RAM: Teamgroup DDRII PC6400 @ 1066 cas5
    MOBO: eVGA 680i SLI
    VID: eVGA 8800GTX + Zotac 8800GTX SLI...GPU voltmodded....Memory voltmodded (both cards)
    BOOT Drive: Seagate 320GB 7200.10 RAID 0
    Storage Drive: Seagate 640GB 7200.11 RAID 1
    Samsung Super Write Master
    Coolermaster Real Power Pro 850W
    Custom Bench Table
    LaCie 19inch CRT
    Single Stage Phase Change - CPU
    Water - VGA's
    Banned
    Oct 2006
    Smile
    lol @ eva2000...
    @ Kunaak..
    first off i think what you said about the thread hijacking was spot on...
    you try to post info for people to learn from and appreciate and then a minority , who have a combined mental age of 15 completely miss the point and post a load of uninformative dribble...
    so good for you for saying what most of us already think....
    thanks for the info on this ram...
    i'll definatly be coming back to all the threads of this nature when i make the jump to ddr3...
    now get overclocking lol jk!
    Jul 2004
    denmark
    nice info ,seems good compaired to other ddr3 and prices out there.
    Gigabyte X38T-DQ6/2x1gb xtreme/2x2900xt
    E6850@ 4500
    1000w psu/vapo Ls/2x74gb raptor raid.
    the jedi master
    Jun 2002
    Manchester uk/Sunnyvale CA
    use memset to push tRFC higher (over 72) and clock in windows, I bet you see higher.
    tRFC being limited to 72 is killing the higher clock IMO
    Got a problem with your OCZ product....?
    Have a look over here
    Tony AKA BigToe
    Tuning PC's for speed...Run whats fast, not what you think is fast
    Nov 2002
    Juneau Alaska
    tony,
    what TRFC range do you suggest?
    SSD faster than your HDD
    Feb 2005
    Kalamazoo, MI
    72 - 100+ maybe.
    There will be some performance affect...but you may be able to outclock the hit because it is small.
    Set to 80, see if it improves any stability at your 1080 1m settings, then just work it higher and you should see some more clocks.
    It may not work at all either At almost 2200 MHz, that is really fast. Voltage may come down just a bit with Trfc a bit looser as well. Again, maybe not at these clocks, but down lower for 24/7
    Nov 2002
    Juneau Alaska
    the lowest memset goes is 80.
    i'll try again later.
    todays been a insanely good hardware day.
    new ram goes crazy on this board.
    new 3870X2 does 930/1070.
    took 2 hours to figure out how to OC it properly, but once I got rivatuner to finally show the clocks changing in real time... that was a good feeling.
    great ram, great videocard.
    Nov 2002
    Juneau Alaska
    this the last of the screenshots.
    And 32M at 1000 and 1T.
    Nov 2002
    Juneau Alaska
    thats all shes got captain, I dont think she can take any more.
    even 2T doesnt get me above 1093.
    1080 at 1T, and 1M.
    thats the last I can pull outta this thing.
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Very nice clocks from some "budget" DDR3. I just need the prices to drop a little bit more before I make the leap, X48 might do it for me though. The voltages being pushed through these DIMMs are nuts though, I'd be afraid of toasting my new chips but apparently this DDR3 is rather resilient.
    OCTeamDenmark Founder Nosfer@tu's Avatar
    May 2004
    Denmark, Copenhagen
    Great work like always Kunaak.
    And spot on with Thread hijacking.
    I think that asking for settings is cool. As long as you dont think the thread is a helping forum.
    You should try out Flicker.
    You need a Yahoo email for it, Only part that sux.
    Then via their webpage or the downloadable program you can upload pictures in a sek.
    Former owner of OCTeamDenmark.com
    MSI MOTHERBOARD!!!!!!
    Linkedin
    Jan 2006
    New Hampshire (USA)
    This makes me cringe for paying $500 for my Corsairs PC3-14400, luckily I've still got a few days left for refund! Pretty amazing RAM you got there Kunaak especially for only $249! I suppose it doesn't really matter but I assume these are GTR's?
    Asus Maximus III Formula (2001)
    Intel i7 860 (L924B516)
    Noctua D14
    Corsairs CMG4GX3M2A2000C2 (2 x 2GB) RAM
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    Creative X-Fi Titanium PCI-e
    LG GGC-H20L Blu-Ray
    Toughpower 850w Modular
    GSkill Phoenix Pro SSD 120GB
    HEAT
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by Roger_D25 View Post
    yes, D9GTR.
    check out the online deals and sales area for my post there from last week.
    its got a few review links to see whats on the chips.
  18. #18
    Jan 2006
    New Hampshire (USA)
    Great, thanks for the advice as I'm now in the market for a new kit! Fortunetly for us the price of decent DDR3 seems to already be dropping!
    Noctua D14
    eVGA GTX480
    DD-H20
    BIX GTX360
    MCP35X PWM
    LG GGC-H20L Blu-Ray
    HEAT
  19. #19
    silver wall jumper X
    Apr 2005
    Las Vegas
    Quote Originally Posted by Kunaak View Post
    I tweak the bios.
    Testing.
    Thanks for the great find and report - just ordered a pair as well
    I think I need you to steal that quote in the future!
  20. #20
    Dec 2004
    what would the mem bandwidth be like?
    Lenovo W510
    i7-820QM 4x2GB Intel X25M
    Multi-Touch
  21. #21
    Jan 2005
    KAPVT MVNDI Rome, Italy
    what ocz are those sticks? 76624..the enhanced badnwith version?
  22. #22
    Nov 2002
    Juneau Alaska
    the everest screenshots should show that.
    no, plain 777 version.
  23. #23
    Nov 2005
    I missed the shot too...
    ... 12885 MB/s with 41.7 latency.
    Quite suprising considering the massive FSB there. I guess the combination of CAS 8 and Perf lvl 7 is to blame here.
    [ Q6600 @ 3.6GHz | 2x2Gb Patriot Viper DDR3| Asus Maximus Extreme | BFG GTX260 @ 700/1100 | FSP Epsilon 700W ]
    [ D-Tek FuZion | Swiftech MCP650 | PA120.3 & PA120.2]
  24. #24
    Aint No Real Gangster
    Jun 2004
    Port Credit/GTA, Ontario, Canada
    Hmmm....
    How much does DDR3 really increase performance?
    That mem speed isn't much better than DDR2 on a nvidia intel board.
    And lower than DDR2 on an AM2 board.
    Do you have a DDR2 board to test same chip clocks, but highest mem oc?
    Specs
    Asus 780i Striker II Formula
    Intel E8400 Wolfdale @ 4050Mhz
    2x2GB OCZ Platinum @ 1200Mhz 5-4-3-18
    MSI 5850 1000Mhz/5000Mhz
    Wester Digital Black 2TB
    Antec Quatro 850W
    Cooling
    Swiftech Apogee
    Swiftech MCP-600
    HardwareLabes Black Ice Extreme 2
    Audio Setup
    X-fi w/AD8066, Clock mod, & polymer caps > PPAV2 > Grado SR60 & Grado SR325i & Beyerdynamic DT770 Pro & Beyerdynamic DT990 & AKG K701 & Denon D2000
  25. #25
    Oct 2006
    Rome, Italy
    Nice scores!
    Wich voltage are you using to make:
    superPI 32M DDR3-2000 MHz 8-7-7-20 1T?
    Thanks a lot!
