Results 1 to 25 of 44
Thread: The Un-Official Q6600 Chest Pounding Proves Nothing Water Cooled Temp Thread!
Threaded View
    Xtreme Mentor
    Sep 2007
    Ohio
    I wanted to start a thread to give us water cooled members a place to brag about our low Q6600 temps.
    Please report your ambient temp at the time of your testing.
    My ASUS Maximus SE. My build thread for all the gory details is located here: http://www.xtremesystems.org/forums/...d.php?t=160606
    System cooled on: WaterKegIII Xtreme, D-TEK FuZion CPU water block, D-TEK FuZion Nozzle Kit, D-TEK FuZion Pro Mount, EK-NB S-MAX Acetal Waterblock, Lapped CPU, SB heat sink Enzotech CNB-S1L, MX-2 used for my TIM on blocks, and AS Adhesive on the SB!
    Ambient Temp at time of testing was 60°F or 15.5°C for all tests +/- 4°F.
    My bone stock 2.4GHz Q6600 for a baseline set of numbers. Run time 35min.
    3.6GHz, 35 minutes into OCCT.
    One shot at 3.7GHz , only minutes away from successfully finishing 1 hour of hard labor.
    My normal old every day 3.8GHz temps, 1 full hour into Prime95:
    My 3.9GHz temps only 20 skinny minutes into a short Barn Burner Run! ....
    Note: I did do a 3.9GHz run for 45 minutes, and cores went up to 53°C.
    Asus Maximus SE X38 / Lapped Q6600 G0 @ 3.8GHz (L726B397 stock VID=1.224) / 7 Ultimate x64 /EVGA GTX 295 C=650 S=1512 M=1188 (Graphics)/ EVGA GTX 280 C=756 S=1512 M=1296 (PhysX)/ G.SKILL 8GB (4 x 2GB) SDRAM DDR2 1000 (PC2 8000) / Gateway FPD2485W (1920 x 1200 res) / Toughpower 1,000-Watt modular PSU / SilverStone TJ-09 BW / (2) 150 GB Raptor's RAID-0 / (1) Western Digital Caviar 750 GB / LG GGC-H20L (CD, DVD, HD-DVD, and BlueRay Drive) / WaterKegIII Xtreme / D-TEK FuZion CPU, EVGA Hydro Copper 16 GPU, and EK NB S-MAX Acetal Waterblocks / Enzotech Forged Copper CNB-S1L (South Bridge heat sink)
