Results 1 to 25 of 25
Thread: [ComputerBase] ATI Radeon HD38xx (X2) BIOS-Editor
    May 2006
    over the rainbow
    Thumbs up [ComputerBase] ATI Radeon HD38xx (X2) BIOS-Editor
    ComputerBase released a Bios-Editor which allows to modify the bios of all HD38xx cards. You can edit BootUp Clocks, 2D Clocks, Low Power 3D Clocks, High Power 3D Clocks, UVD Clocks & of cause the VCores.
    DLoad: http://www.computerbase.de/downloads...i_bios-editor/
    original thread (german): http://www.computerbase.de/forum/sho...d.php?t=372893
    AMD Phenom II X6 1055T@3.5GHz@Scythe Mugen 2 <-> ASRock 970 Extreme4 <-> 8GB DDR3-1333 <-> Sapphire HD7870@1100/1300 <-> Samsung F3 <-> Win8.1 x64 <-> Acer Slim Line S243HL <-> BQT E9-CM 480W
    Aug 2006
    The Netherlands, Friesland
    That's one heck of an editor. To bad i don't have an hd38xx.
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
    Nov 2005
    UK
    i7| EX58-EXTREME | SSD M225 | Radbox | 5870CF + 9600GT
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    dose it do the checksum as well, and is there anything on fan controll
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Oct 2007
    Rochester, MN
    I have to say, even though this was already posted, this is a great editor. And I wouldn't have known about it from the other thread.
    Thermaltake Armor Series Black
    GIGABYTE GA-P35-DS3R
    Q6600 3.6 GHZ Thermalright Ultra 120 eXtreme
    4 GB Corsair XMS2 w/ OCZ XTX Ram Cooler 2 x 60mm
    9800GT 512MB
    18X Pioneer DVD-RW Burner
    720 Watt Enermax Infiniti
    4x640GB RAID 10
    Windows 7
    Turkey Man
    Mar 2005
    Jakarta (ex-Australia)
    WHat is UVD clocks?
    Xtreme Mentor
    Oct 2005
    It does not do checksum it appears, and looks like no memory voltage adjustment. Will it work on the 2900 cards? If not, they should make it so it does. The bios layouts are almost identical.
    Asus Rampage II Gene | Core i7 920 | 6*2GB Mushkin 998729 | BFG GTX280 OCX | Auzentech X-Fi Forte | Corsair VX550
    —Life is too short to be bound by the moral, ethical and legal constraints imposed on us by modern day society.
    Mar 2004
    Toronto, Ontario Canada
    no checksum = pain in the ass, you still have to edit it manually with some hex editor to get it working.
    I wonder how many n00bs are gonna RMA their cards thinking it's dead after flashing an edited BIOS without the correct checksum
    Apr 2006
    Quote Originally Posted by HKPolice View Post
    Quote Originally Posted by linked thread
    Die erforderliche Checksummenkorrektur f&#252;hrt das Programm automatisch beim Speichervorgang durch. Somit entf&#228;llt das l&#228;stige &#196;ndern entsprechender Bytes mit dem Hex-Editor.
    Quote Originally Posted by Translation
    The necessary correction of the checksum is done automatically while saving. Therefore there is no need to change the bytes via a Hex-Editor
    interesting program! too bad I don't have a HD-3870 hopefully it'll support future AMD-cards as well
    Notice any grammar or spelling mistakes? Feel free to correct me! Thanks
    Xtreme X.I.P.
    Nov 2002
    Shipai
    is there a windows bios flash tool as well now or do we have to use our floppy drives or boot from cd into dos again?
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    WHat is UVD clocks?
    universal video decoder.
    atiwinflash
    Aug 2006
    Looks easy to use
    http://www.1cup1coffee.com - Play flash games in school
    Nov 2005
    UK
    Its does the checksum and the X2 flashes fine.
    Quote Originally Posted by saaya View Post
    I'd personally stick to DOS. And try a USB flash drive as a boot drive, works no problem.
    Xtreme X.I.P.
    Nov 2002
    Shipai
    Quote Originally Posted by Kunaak View Post
    atiwinflash
    it doesnt work with rv670, at least the last time i checked... :/
    Xtreme Mentor
    Nov 2006
    Spain, EU
    I can confirm it works like a charm with HD3870, with corrected checksum and Overdrive enabled
    Friends shouldn't let friends use Windows 7 until Microsoft fixes Windows Explorer (link)
    Quote Originally Posted by PerryR, on John Fruehe (JF-AMD) View Post
    Pretty much. Plus, he's here voluntarily.
    May 2007
    Quote Originally Posted by fornowagain View Post
    Teach me how to make my USB flash drive bootable.
    My motherboard supports it, don't worry about that.
    I guess this means I should work harder to get the full BIOS Editor out.
    Gigabyte P35-DQ6 | Intel Core 2 Quad Q6700 | 2x1GB Crucial Ballistix DDR2-1066 5-5-5-15 | MSI nVIDIA GeForce 7300LE
  18. #18
    Nov 2005
    UK
    Quote Originally Posted by MuffinFlavored View Post
    I used the info from here.
    http://files.extremeoverclocking.com/file.php?f=197
  19. #19
    May 2007
    Thank
    you.
    I tried the HP method once before, and I didn't have much luck, but I am sure it was my fault.
    Here is a screen shot of my current BIOS Editor. (Depressingly, no core or memory clock editing yet).
  20. #20
    Dec 2007
    Is this a good substitute for pencil vmods?
    For instance, can we push the vcore for higher values than default safely?
    Can we push 3870s to 1Ghz with proper cooling using just a modified bios?
  21. #21
    Nov 2002
    Juneau Alaska
    Quote Originally Posted by ToTTenTranz View Post
    nope.
    1.324 is the highest the bioses go.
    I havent seen any that go any higher.
  22. #22
    Jul 2005
    London, UK
    My 3870 does 850Mhz at 1.214V:
    http://www.techpowerup.com/vgabios/5...12.071205.html
    I am hoping that with an unlocked and edited BIOS for 1.3V, and an Accelero S1 Rev 2 I can reach over 900Mhz. I will need this editor to make the changes needed.
    I MSI P67A-GD65 I Intel i5 2500K I 8Gb Samsung I
    I Corsair F3 60Gb I AMD 6850 I Dell SP2208WFP I Windows 7 x64 I
    I Current Speed: 4.5Ghz I RAM 1866Mhz @ 9-9-9-27 1T I
    I Laptop I Acer 1830T I Intel i5-470UM I Crucial M225 I 4Gb DDR3 I
  23. #23
    Xtreme Mentor
    Feb 2004
    The Netherlands
    nope.
    the PWM of the cards aren't built to deliver more than 1.3v juice, iirc. so only hard mod / pencil mod will get you higher.
    Ryzen 9 3900X w/ NH-U14s on MSI X570 Unify
    32 GB Patriot Viper Steel 3733 CL14 (1.51v)
    RX 5700 XT w/ 2x 120mm fan mod (2 GHz)
    Tons of NVMe & SATA SSDs
    LG 27GL850 + Asus MG279Q
    Meshify C white
  24. #24
    Feb 2005
    Czech Republic
    Quote Originally Posted by biohead View Post
    author of ati tool w1zzard said its possible to manage voltage for 3870X2 by software way, even more then on 3870.
    ASUS P8Z68-V PRO B3 + Intel i5-2500k @ 5.0 GHz + Noctua NH-D14
    8GB DDR3 Corsair Vengeance XMP (kit 2x 4GB) 1866MHz / Gainward Geforce GTX470 SLI watercooled
    120GB SSD Kingston HyperX (games) / 1x 30GB SSD OCZ Vertex Turbo (system)
    22" LG IPS226V-PN / PSU Fortron AURUM GOLD 700(W) / Cooler Master HAF Tower RC-932
  25. #25
    Xtreme Guru
    Jul 2004
    lets see some x2 results
