Hello XS folks,
Here are a few pics of my main rig that I recently transported into a Coolermaste Cosmos. Be warned that this mod is not as extreme as many on this site (or as extreme as many would like for that matter) but it is very functional which is what I was going for. Anyhow, enough of this useless banter.
The external appearance is unchanged so here is the link to the CM product page (they have a way better camera than I do):
http://www.coolermaster.com/products...te=168&id=2684
Here is a shot of the front with my nifty XSPC dual bay res (and buttonless DVD burner but that is neither here nor there):
Here is a shot of the internals:
A closeup of the pumps and lower radiator, removed all of the HDD bays to keep everything nice and uncluttered:
Finally, a shot of the top radiator plate I made:
The pair of fans on the top of the cosmos are not quite ajacent, therefore many folks simply hang their rad from the screw holes for either fan. I decided to go a bit farther as the thought of a box of water hanging semi-precariously over my MB was unsettling. Moreover, when you take the easy way out, on of your fans has it's flow blocked if you mount the 2nd fan to the radiator, or is not in the optimal location for the radiator if you mount the 2nd fan to the case. Well, that and I was looking for an excuse to cut up some aluminum since I didn't do anything to the externals.![]()
All in all, the loop keeps my C2D and 8800GT nice and cool with a moderate overclock on the CPU (CPU/GPU 25c/35c idle, about 40c on both under 100% load). There is a lot of headroom for more overclocking, but the main reason I went water (other than the intrinsic fun of it) is that I run a lot of mathematical simulations some of which can take days to complete. Many a processor has been killed by the UCI econ department by a weekend-long Matlab/Gauss run; I do not intend to join this club.
