Page 1 of 3 123 LastLast
Results 1 to 25 of 62
Thread: Asus 8400GS vmod
    Jun 2005
    Denmark
    Asus 8400GS vmod
    Hey XS.org
    I need your help on the soldering points on this card asus 8400gs I have added a picture, could not get a better picture. but hope you can help me.
    the chip uses this IC on the card:
    APW7068
    AJ5CM
    /Grau
ID:	72034   Click image for larger version.
    67744 - 30150 - 13273 - 7504
    Life is like a beer, the longer its open, the worse it gets
    Jun 2005
    Denmark
    Got a better picture, alittlebit better.
    Any help would be great
    /Grau
    I am Xtreme
    Feb 2003
    Netherlands
    I reckon pin 4 is feedback (FB) and pin 7 is ground.
    Measure ressistance between pin 4 an pin 7, multiply by 20 and put a VR of this value onto pin 4 and pin 7.
    For example, if resistance between pin 4 and pin 7 is 500 ohm, multiply this value by 20, 500x20=10.000 so use a 10K VR.
    Don't quote me on this as i'm not 100% sure FB actually means feed back but i have a strong feeling it does.
    For Voltage reading point, put the card in your system, turn system on and measure at the resistors that are close to the thumbscrew that hold the cooler or at the pins of the caps that poke through the pcb, you should be able to measure Vgpu there somewhere. (do this prior to the Vmod)
    Done at your own risk.
    Asus Crosshair V Formula-Z | FX 8350 | 2x4GB Trident-X 2600 C10 | 2x ATI HD5870 Crossfire | Enermax Revo 1050watt | OCZ Vertex 3 60GB | Samsung F1 1TB
    Watercooling: XSPC Raystorm | EK 5870 Delrin fullcover | TFC X-changer 480 w/ 4x Gentle Typhoon | DDC2+ Delrin top | EK 200mm res | Primochill LRT 3/8 tubing
    Case: Murdermodded TJ-07
    sub 9 sec. SPi1M 940BE 955BE 965BE 1090T
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    Can't really use those pics for anything...
    Anyways, the mod is:
    Pin 4 of APW7068 to ground via a VR with a maximum resistance of ~20× the measured resistance from pin 4 to ground. Lower resistance to increase voltage.
    edit:
    Zeus was faster.
    edit2:
    GOESA,
    I bet there's a macro-mode (marked with a flower symbol) in you Powershot A60...
    edit3:
    What comes to the vGPU measuring point...
    These appear to be the legs of a copper coil ->
    Both of those red spots are good vGPU measuring points.
    You were not supposed to see this.
    Jun 2005
    Denmark
    Thx found the flower
    Took one without flash and one with, does this help any or just say where to take the picture,
    would like to get for the vmem aswell.
    /Grau
ID:	72046   Click image for larger version.
    Jun 2005
    Denmark
    So can you point out where to mod exactly?
    /Grau
    c[_]
    Nov 2002
    Alberta, Canada
    Here's a macro from my Canon SX100IS... dont really need it now but whatever helps.. in case we need overcurrent fixed as well I guess
    The pin with the dot by it will be pin 1. Go left counter-clockwise to count.. so 4 is the center pin and 7 is far left, all along the "top" of the IC in my picture.
    Check that 7 is actually ground before doing the mod though just in case they printed the IC's upside down or something rediculous.
    All along the watchtower the watchmen watch the eternal return.
    c[_]
    Nov 2002
    Alberta, Canada
    I measured 600 ohms from pin 4 to 7. Gonna see if I can find where I stashed all my VR's...
    edit - 10K VR is what you will want to start with.
    Aug 2005
    Melbourne, Australia
    Are there any other vreg chips on the front of the card? If not, pin 6 - pin 7 could be a point for Vmem.
    Q9550 || DFI P45 Jr || 4x 2G generic ram || 4870X2 || Aerocool M40 case || 3TB storage
    c[_]
    Nov 2002
    Alberta, Canada
    I can confirm a 10K VR from 4 to 7 is vGPU... running 1.4v now
    c[_]
    Nov 2002
    Alberta, Canada
    6-7 doesnt seem to be vmem, took a vr down to 3K on it with no change in vmem, circuit resistance was 780 ohms with no VR in it.
    That other IC labeled "74D7KHK / ACT08" might control vmem....
    edit - Dont think its the ACT08 IC... hmm.
    Aug 2005
    Quote Originally Posted by STEvil View Post
    No thats a quad input AND gate. We need some more photos methinks
    c[_]
    Nov 2002
    Alberta, Canada
    The only other IC is an 8-legged one on the front which hides under the heatsink and looks more like a driver IC like what you'd see paired with some mosfets.. i'm too lazy to take the vf700-cu off right now lol (midnight).
    edit
    We might be looking in the completely wrong spot:
    c[_]
    Nov 2002
    Alberta, Canada
    ok, you win... here's the front IC.
    Looks like it could control vmem I guess.
    edit
    here's another on the back..... need to get a better shot so the text can be read
ID:	72082   Click image for larger version.
    Aug 2005
    That first one is the bios chip and the second one is a chip related to HDCP output.
    It could be something like what the xfx card uses, but they are a pain in the ass to locate because there is a lot of multimeter probing involved
    I am Xtreme
    Feb 2003
    Netherlands
    I hope this helps:
Name:	voltmod 8400GS.JPG
    Jun 2005
    Denmark
    Thx guys! really nice,
    how about the vmem mod?
    /Grau
  18. #18
    Jun 2005
    Denmark
    Hi found something
    http://forums.vr-zone.com/showpost.p...0&postcount=17
    According to this thread the one that controls the vmem is a chip called 431L which has 3 legs, I found that one on my card, but on the front of the card instead? has this anything to do with the vmem mod?
    /Grau
ID:	72096   Click image for larger version.
  19. #19
    all outta gum
    Dec 2006
    Poland
    This IC is "1.24V Adjustable Shunt Regulator"
    when you look at it so that two legs are on the bottom, left leg is Vref. Decrease resistance between Vref and ground to increase output voltage.
    www.teampclab.pl
    MOA 2009 Poland #2, AMD Black Ops 2010, MOA 2011 Poland #1, MOA 2011 EMEA #12
    Test bench: empty
  20. #20
    Jun 2005
    Denmark
    okay but is it for the vmem you think?
    /Grau
  21. #21
    all outta gum
    Dec 2006
    Poland
    Well it's definitely not for GPU Of all things on vid card that might need a voltage regulator like that, only memory comes to my mind.
    www.teampclab.pl
    Test bench: empty
  22. #22
    Jun 2005
    Denmark
    thx man only one way to find out now
    /Grau
  23. #23
    c[_]
    Nov 2002
    Alberta, Canada
    I think its 431L, 10k to ground from the leg closest to the wires that go to the VGA connector should do the trick.
    I wont be able to test tonight. Will try to do it tomarrow.
    EDIT
    I went and tested anyways lol.....
    Yup, 431L to ground with 10K VR = VMEM mod. Quick test at 2.15v then I gotta run 'cause i'm late now lol
    edit
    486mhz @ 2.2v so far. 493 caused a crash.
    Gotta find a datasheet for the Qiumonda 2.5ns chips..
  24. #24
    Jun 2005
    Denmark
    Good for you STEvil! Damn, then they scale well enough with volts! Yes!
    So could you point out where exactly you soldered? the leg closest to the VGA connector, to ground? which one is ground?
    /Grau
  25. #25
    c[_]
    Nov 2002
    Alberta, Canada
    Just used a ground on the back of the card that holds the backplate bracket thing on.
    Edit
    added vGPU just so its all finalized.
ID:	72134   Click image for larger version.
