Results 1 to 11 of 11
Thread: 2 Very Different E8400s
    Jan 2008
    United States
    My first E8400 (Q748A116) needed a lot more vCore for sigged 4.23GHz than others were reporting (1.45v), so I got another one to see what's going on.
    The new chip (Q745A731) doesn't need as much vCore (only 1.40v) for the same OC, but it runs 10(c) hotter.
    To confirm it wasn't the AS5 breaking-in, I remounted the first chip and it was still running 10(c) cooler.
    Q748A116 @ 4.32 35 / 55 / 1.45v
    Q745A731 @ 4.32 45 / 65 / 1.40v
    Your opinions are appreciated:
    1) Which chip should I keep?
    2) Is it safe to go beyond 1.45v if the chip is running cooler?
    3) Is it safe to go beyond 65(c) if the vCore is lower?
    Vista Ultimate x64 SP1 3DMark: 2006 18,426 Vantage P13,913
    E8400 4.23GHz (470x9, 1.40v, Tuniq 120, lapped + Silverstone 121)
    EVGA GTX280 (670/2430/1458) EVGA 9600GT (675/1800/1674)
    ASUS Rampage Formula X38 0407 (Hacked Maximus 1.03G)
    4x1GB Ballistix PC2-8500 (1128MHz, 5-4-4-12-2T, 2.20v)
    Tagan 1.1kW, 2xRaptor 150 (RAID-0), Fatal1ty Platinum
    System Gallery
    Jan 2008
    I've read that Intel botched the temp sensors on these processors. Given that you can't trust the temp data for either of your processors, perhaps it's best to keep the one that overclocks at the lower vcore. This means it may have more headroom, and is likely actually cooler than your first one to begin with. Just my theory.
    DFI LP LT X38, Q9550 @ 400X8.5 (3.4GHZ), 8GB G.Skill PC2 8500 @2.0V, Powercolor 5870 @950/1250 GHZ with factory installed EK waterblock
    Windows 7 64bit
    Lian-Li 343B case
    Water cooling components in one loop: Thermochill 120.3 to cool CPU and NB,Thermochill 120.2 to cool GPU, DDC3.2 + Petras top for above pumps.
    Sometimes I feel like 2/3rds Rice Krispies. Past Snap and Crackle, but just shy of Pop
    Feb 2006
    La La Land.
    Whats the vid on both chips? I bet the VID of the hotter chip is much lower.
    Primary Rig
    Intel Xeon W3520 @4200Mhz 24x7, 1.200v load (3845A935)
    Gigabyte X58A-UD7
    Patriot Viper II DDR3 2000 CL8
    Tagan BZ1300
    DeepCool Gamer Storm with 2x120mm DeepCool fans.
    MSI GTX 470 Twin Frozr II
    Zotac GTX 470 AMP edition.
    GPU collection : http://www.xtremesystems.org/forums/...5&postcount=64
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    2GBx2 Corsair DDR3 1333
    Tagan tg500-u37
    Arctic Cooling Freezer 7 Pro Rev.2
    XFX 9600GT
    Oct 2006
    I wouldent personaly go beyond 1.45v not when the temp readings are faulty.
    Intel is like Egypt in Rome:total war
    Oct 2005
    Milton Keynes, UK
    Quote Originally Posted by Funky View Post
    +1
    Please report back with the VIDs of the two CPUs. Use latest CoreTemp to detect it.
    My work and bench rig:
    i7 920 D0 3939B303 @ 4.2Ghz + ASUS P6T Deluxe V2 w/ 0006 BIOS + 6GB Corsair Dominators CL7 @ DDR3-1600 7-7-7-20-1T + Intel X25-M 80GB SSD G2 + Powercolor HD5870 1GB @ 900/1300 + Dell U2410 H-IPS 24" Screen (pics and more)
    My review site: Erodov
    Dec 2005
    Athens,Greece
    Q745A731 keep that. Low vcore for same speeds. Temp is not a problem as far
    as you touch the hsf and feeling it just warm.
    E8400 TRUE120@Asus Maximus Formula@2x2GB Geil Evo One 800MHz 4-4-4@Corsair HX 620W
    Sapphire HD6850 1GB@Samsung 830 128GB@Casetek 1022-5@LG 19" 1970HQ
    Creative Inspire 5.1 5100@Samsung SH-S203B SA@CM Quickfire Pro Red@Logitech G-600
    May 2007
    As we cant "trust" on those temp sensors, for sure I would pick the one with low vcore requirement, this could also explain they run hotter, maybe also that one got a lower VID?
    DFI Lanparty LT X48-T2R
    Intel Q6600 L737B242 ~ VID 1.2125 ~ 4000mhZ @ 1.48 vcore {lapped}
    eVGA 8800GTS (G92) 512MB {stock}
    Crucial Ballistix PC8500 Tracer ~ 1200mhZ 5-5-5-12 @ 2.05v
    Lian Li PC-V1000 {modded}
    Corsair HX 620W
    Creative X-FI ExtremeMusic
    Western Digital Raptor X 150GB
    Thermalright-Ultra120 Xtreme {lapped} ft. Scythe S-Flex SFF21F S-FDB ~ Push & Pull
    Jan 2008
    United States
    Ack, sorry. VID is identical on both. 1.125v, IIRC (at work ATM).
    I will go with consensus. It just makes me sad to have bungled temperature reporting (hoping that's what it is). I felt a lot better when 4.23 meant nothing hotter than 55(c).
    Thanks so much for your opinions so far!
    System Gallery
    May 2007
    I see that u are using a lapped Tuniq, with such cooling I dont think U need to worry about the temps at all, as long u use "safe volts" and as long you are stable, your are totally fine, mine is even worse. I got a fixed 38c on both cores, but as soon I use 1.368vcore during prime core0: goes 45c and core1: 43, no way it could be that "cool" but on the other hand the air comming from the back of my TRUE is way cooler then my Q6600 dissipated, and that was 52-55c during prime.
    Corsair HX 620W
    Oct 2007
    Michigan
    Just got Q748A116 E8400 from a friend. Still need to test it out. Don't have a board for it right now, just couldn,t pass up an e8400 for $100.
    On the topic side. when placing 1.45V, or more with a 45nm die, one will have to start worrying about an electron breaking through a potenial well and jumping between transistors...which could then ruin the whole core. I am not expereinced in OCing like most here, but that is the greatest threat when you reduce the size of a manufacturing die for a cpu, Slow 1.45V may have been perfectly safe with 65nm, but now with 45nm, the possible extra potential could cause a case like that to happen.
    System - Everyday Settings
    CPU: Q6600 G0 @ 3200MHz (Lapped / Air)
    GFX: 1x EVGA 8800GTX @ 630/1600/1000MHz (Air)
    RAM: OCZ Reaper 2GB DDR2 @ 800MHz -- 4-4-4-9 1T (1:1)
    MB: EVGA 680i A1 (Bios: P32 / vdroop mod)
    PSU: PC Power & Cooling 750W
    OS: Windows XP SP3 (RC2)
    Benchmarking - Different Setup
    3DMark06 (No OC) - 10400
    3DMark06 (OC no SLI) - 15413
    SuperPi (1M) - 14.156
    Load Temps @ 3.2GHz - 52/46/52/46C
    Jan 2008
    United States
    Yes, agreed. Let me know how your experience is with that chip!
    System Gallery
