Results 1 to 14 of 14
Thread: P5E3 Deluxe & System won't boot?
    Dec 2007
    Hi there!
    I've got a little problem with my mobo... it works pretty well except for the thing that, sometimes, it just won't boot!
    I hear the noise of the fans and nothing else, the screen is black and no beep come from the mobo.
    Shutting it down 1 or 2 times it "beeps" and after a pair of seconds of post, it gives the error:
    Overclocking Failed! Press F1 to reconfigure your PC settings!
    However, i have this problem even with everything @ default!
    Is there some BIOS setting on wich i could blame this?
    Thank you =)
    Jan 2007
    Crete,Hellas
    Press F1 ..go to bios and load F5 defaults > F10 saved...then again go step by step and set it up ...in every change you make then F10...beep.. and continue..the same style..
    It makes me the same but she is stable after all...
    When she beeps and doesnt load...reset it...and wait ...will bring you to this...Overclocking Failed! Press F1 to reconfigure your PC settings!..
    Workstation
    P5E3 Deluxe
    Q9650 @4.0GHz (L826A974)
    Intel X25-M 80Gb(Win7 x64)-Samsung MLC64 -WD500
    8Gb Crucial Value D9JNM
    GTX 260& Eizo L768
    CobaNitrox 600w
    WC (Laing DDC1T-Enzotech cpublock-B/Ice Stealth 360)
    TT Armor
    Dec 2007
    Quote Originally Posted by nick2crete View Post
    Exactly... this isn't a "small" problem...
    Sometimes, it just doesn't load and i have to reboot 4, 5 times...
    Somebody told me this could depend from the RAM: i am using two 1800 Corsair modules, but i had to change my system fans and, waiting for the two new Noctua, i lowered the cpu to default and the RAM to 1333... but this sounds crazy to me
    What could we do?
    Jan 2007
    Crete,Hellas
    I dont know...try play with your ram...my ram runs stable at 450x8 @ 1800...test timings voltage etc ...
    Thats my stable settings with 0903 bios..
    Attached Files Attached Files
    Workstation
    P5E3 Deluxe
    GTX 260& Eizo L768
    CobaNitrox 600w
    TT Armor
    Dec 2007
    Thank you, really
    However, it doesn't sounds good the mobo shows the same problem even with the "nominal" ram frequency... i hope this is just a little bios bug and it will be solved... a mobo that shows "Overclocking failed" even at default is so strange =)
    CPU: Intel Core 2 Extreme QX9650 || Motherboard: Asus P5E3 Deluxe/WiFi-Ap@n || RAM: Corsair Dominator DDR3 2GB || VGA: Asus Nvidia GeForce 8800 Ultra || [bPSU:[/b] Enermax Galaxy DXX 1000W || Hard Disk: Seagate Barracuda 500GB || Audio board: Creative X-Fi Platinum Fatal1ty Champion Edition || OS: Windows Vista Ultimate & Linux Mint 4.0 Daryna
    Jan 2007
    Crete,Hellas
    It has happend me in every bios update...from 0804 to 0903 took me 1 hour to load windows...then the same from 0903 to 1001...i think your mobo is fine..spend some time with it...go step by step..and try..
    Workstation
    P5E3 Deluxe
    GTX 260& Eizo L768
    CobaNitrox 600w
    TT Armor
    Dec 2007
    Now i'm running the memory at 1800Mhz...
    Strange to say, the problem didn't happen.
    I mean, what's the problem with a mobo that claims "Overclock Failed!" on every boot with a system at default and doesn't say anything with the system overclocked?
    Looks like it's just a RAM issue, those Corsair Dominator don't like to be downlocked (at least, i hope so)
    Nov 2007
    Alameda, Ca
    Quote Originally Posted by Trivia89 View Post
    Thank you, really
    Mine does the same, only I have Corsair ram in my sig, running bios 901, had a lot of problems with usb devices, so I had a usb 2.0 pci card laying around so I put in and now no problems at all, boots right up, stable no more dropped usb devices, really strange...
    Asus P8Z68 Deluxe Gen 3, Intel I7 2700K Cooled by Corsair H100, 16 Gigs Corsair Vengeance CMZ16GX3M4A1600C9B, Asus GTX570 DCII/2DIS/1280MD5, Crucial 256GB m4 SSD W7 Ultimate, 1 TB WD Black data, Corsair 650D case with Corsair AX750 PS, , Corsair Vengeance K90 Mechanical keyboard, Corsair M60 mouse
    Asus P5E3 Deluxe Wi-Fi - Intel QX9650 - CORSAIR TWIN3X2048-1600C7DHXIN 6GB PC3-12800 - Gigabyte GTX 470 SOC - 160GB Intel X25-M SSD W7 Pro 64 bit - 300 gig VelociRaptor Data and Games - WD Caviar Black WD1002FAEX 1TB Sata 6 on Asus U36S PCI-E - Corsair HX 620 watt PS - Creative X-Fi Titanium PCI-Express - Altec Lansing ADA885 THX 4.1 Speakers - Silverstone Temjin TJ03B case with side window - 2 x Dell 2405FPW lcd monitors!
    Jan 2007
    Crete,Hellas
    I have seen in a local forum power users talking about DDR3 and they said that there are some sticks which dont work in specks and they run fine overclocked...that was my case..since then they run only o/c.. and they run fine..
    Workstation
    P5E3 Deluxe
    GTX 260& Eizo L768
    CobaNitrox 600w
    TT Armor
    Nov 2007
    Alameda, Ca
    The funny thing if I leave everything default in bios my rig runs at 1600 fsb the cpu is running at 3.2 ghz, so the ram at default in bios sets fsb to 400 and cpu multiplier to 8 (I can only tell its 8 by cpuz because everything is on auto)....I thought I would have to enable xmp to get those settings or do it manually...
    Jan 2007
    Crete,Hellas
    With the XMP you can choose between 2 profiles again at default..maybe with different timings..
    Go manually better ..look the .txt file above (4th post) as an example..
    Workstation
    P5E3 Deluxe
    GTX 260& Eizo L768
    CobaNitrox 600w
    TT Armor
    Dec 2007
    The "2 profiles" are just a bluff
    With 1001 bios the settings for every XMP profile is shown when selected...
    ...well, the second profile is shown as "Invalid profile"
    However, system is just NOT stable when running XMP, my mobo first booted @450*8, then 450*11, then tried 450*31 (O__O) when using XMP, you REALLY have to tune it manually!
    Nov 2007
    Alameda, Ca
    That's what i found, Corsair has some work to do....
    Jan 2008
    Australia
    Question Is this a problem just with Corsair RAM?
    Hi all,
    I am thinking of buying the pro version of this board. That is, the P5E3 WS Pro, as it has a PCI-X slot to run a separate dedicated RAID card.
    I can hold out to approximately the end of March 2008. By then the X48 version may be out.
    In OZ, the best value, but still not cheap, DDR3 RAM is G.Skill [AU$472.30] (1Gb x 2) DDR3-1600 (F3-12800CL7D-2GBHZ). I am thinking of using 2 of these sticks.
    Has anyone got any good or bad experiences with G.Skill DDR3 RAM and ASUS motherboards?
    Will I have the same issues as has been reported above.
    Thank you,
    David
