Results 1 to 5 of 5
Thread: Asus Express Gate + ATI Radeon 3870x2 = Black screen :S
    barfastic
    Guest
    Well i isntalled my new 3870x2 card and i boot it up, and get nothing... :S ends up p5e3 deluxe mobos arent compatible with this card if ur running express gate... I dont get it...
    Knowledge Base
    AMD Customer Care Site Map > Radeon Support - PC > Radeon HD 3870 X2 > Knowledge base > Installation >
    737-31811: Radeon™ HD3870 X2 series: The computer boots up with a black screen if an ATI Radeon™ HD3870 X2 series is installed into a system with ASUS P5E3 Deluxe motherboard before disabling the Express Gate feature in the CMOS
    The information in this article applies to the following configuration(s):
    * ASUS P5E3 Deluxe System
    * Radeon™ HD3870 X2 series
    * Windows Vista 32-bit Edition
    * Windows Vista 64-bit Edition
    * Windows XP Professional
    * Windows XP Home Edition
    * Windows XP Media Center Edition
    * Windows XP Professional x64 Edition
    Symptoms:
    Solution:
    To workaround this compatibility issue, either the feature needs to be disabled in the CMOS setup before installing an ATI Radeon™ HD3870 X2 card or, if this is not an option and only an R680 card is available, the following sequence will allow the user to disable the feature and give full functional capability for the R680.
    Workaround with R680 Installed
    1) Clearing the CMOS [ this temporarily disables the Express Gate feature ] :
    * Remove CMOS battery on the motherboard and wait for 2 minutes before replacing the battery.
    * Power the system.
    2) Setting up Date and Time:
    * When the system boots up the following message will appear at the bottom of the screen: “Please enter Setup to recover BIOS setting” “F1 to run setup”
    * Press F1 to enter Setup
    * In the Setup / BIOS Setup Utility:
    o In the tab labeled “ Main” set the appropriate system date and time.
    o Press F1 to obtain general help on how to change the system date and time.
    o Move over to the tab labeled “Exit” using the -> (directional left) button
    o Go down to the option “load setup defaults”, using the directional down key and press ENTER.
    + A message asking to “Load Setup Defaults” will appear with the OK option highlighted. Press ENTER.
    o Press F10 to Save the settings and exit
    + A message asking “Save configuration changes and exit now” will appear with the OK option highlighted. Press ENTER.
    o The system will now restart.
    3) Disabling Express Gate:
    * As the system is beginning to start up again press the DELETE to start the Setup/ BIOS Setup Utility again.
    o Using the left/right directional keys move over to the "Tools" tab.
    o Using the down directional key, choose “Asus Express Gate [Enabled]”
    o Press enter to pull up an option menu. Once in the menu, using the directional keys to choose “Disabled” and press Enter.
    o Press F10 and then Enter
    4) The system will now restart and boot into your operating system.
    Question is, after i isntall it (Drivers software etc) can i re-enable the express gate? or will i ahve to do this all over again?
    *Cant they make computers like they used to? plujg and play, end of story...*
    Xtreme 3D Team Member
    Jun 2006
    small town in Indiana
    I am guessing here but i would say no. the program uses linux and it appears that the card isn't recognized natively by the Express Gate program. that would be something asus would need to fix as ATI most likely will not bother. you may however be able to use a pci card to use the utility then swap cables when using the o.s. I would just disable and use windows myself.
    QX 9650 5ghz with 1.55v 4.8ghz with 1.5v 24/7 in a VAPOLI V-2000B+ Single stage phase cooling.
    DFI LP LT X-38 T2R
    2X HD4850's water cooled , volt modded
    Thermaltake 1KW Psu
    4x Seagate 250GB in RAID 0
    8GB crucial ballistix ram
    barfastic
    Guest
    as i did... i mean, ok, 5 second load up to be in a linux os to use what? skype and firefox... GZ! and thats considering your computer is turned off, mine has gone 2-3 months on constantly. cant live without downloading...
    Jul 2007
    TA770 and 3870x2 has same problem,,but it dosnt have that feature to disable...Youd think the 3870x2 would fire right up with the 780rx//790x//790fx ...This has me so mad...Biostar support there pretty much isnt any!
    "AMD...Like the perfect Storm,...Everything needs to be just right"
    X555x4SuperCore@4450mhz@1.64v..........
    RYZEN 7 1800x/ ASUS ROG STRIX VEGA64/ =EK NICKEL WB, Feser THC 2x360 1x480
    X470 Gigabyte Aorus7, Patriot 3400mhz 16gb dual2x8
    SSD Samsung 970pro,,860EVO
    Jul 2007
    Just discovered if you use The Anolog to DVI connector on the LCD/CRT it should post
    Its a issue with the Card and Mobo but instead of Disabling Express you can try.... Using Anolog cable instead of the DVI cable ..
    Even a DVI Adapter should work.
    Wierd card indeed.
Members who have read this thread: 0
There are no members to list at the moment.
