Page 1 of 3 123 LastLast
Results 1 to 25 of 60
Thread: My E8400 - 4950Mhz ALL AIR
    Champion
    Jan 2007
    Romania, lab501.ro
    Well....I couldn't get any Dice to play with this week-end, so, beeing very upset and bored I thought it wouldn't be a very bad ideea to try and see what I could do with this little chip on air. That beeing said, I opened the window, I put the sistem out in the cold (~0 oC outside), I dressed up in my ski outfit and started pumping in volts
    System
    E8400 Q746A+ Cooler Master Gemini II + 2x100 CFM Sunon + 2x120mm Antec Tricool + 1x 120mm Evercool
    Asus Maximus Formula
    Evga 8800GTS 512Mb
    2x1Gb Crucial Ballistix 8500
    Antec EA500W
    Results
    1. Max clocks- 4954Mhz @ 1.72v
    2. SuperPi - 9.437s @ 4900Mhz
    3. 3D
    3DMark 2001 - 85663
    3DMark 2003 - 51689
    3DMark 2005 - 28148
    Spi 1M stable at 4900, and 3D stable at 4700Mhz... For a little air cooled session (and not even a sub zero air cooled session) I would say that is pretty sweet
    Now it's time to put it under some real cold and see what it can do, and as soon as I have the time that wiil also happen.
ID:	71677   Click image for larger version.
ID:	71678   Click image for larger version.
ID:	71679   Click image for larger version.
Name:	Resize of All Air3.JPG
ID:	71682   Click image for larger version.
Name:	Resize of All Air5.JPG
    Weissbier - breakfast of champions
    The Blue Dolphin
    Nov 2004
    The Netherlands
    Very xtreme
    You do realize that with air cooling at this voltage there's a good chance of degrading if not killing the chip?
    Blue Dolphin Reviews & Guides
    Blue Reviews:
    Gigabyte G-Power PRO CPU cooler
    Vantec Nexstar 3.5" external HDD enclosure
    Gigabyte Poseidon 310 case
    Blue Guides:
    Fixing a GFX BIOS checksum yourself
    98% of the internet population has a Myspace. If you're part of the 2% that isn't an emo bastard, copy and paste this into your sig.
    Champion
    Jan 2007
    Romania, lab501.ro
    Of course
    Keeping it at 1.62v for 3DM runs for a few hours, plus the volts I pumped in to get the max clocks certainly doesn't do him no good. BUT.....that what it's all about in the end, going as high as you can, not keeping it safe
    For instance, my champ E6600 used to do Orthos @ 3600Mhz with 1.275v in his good days, but after lots of experiments (including Dry Ice runs) he needs 1.35v to do that now. Now he is having a well deserved rest, with 1.25v @ 3Ghz in my silent daily use system. That's also going to happen with this E8400 when a new CPU will come on the market (if he doesn't pass out until then). You can't expect to do extreme things with them, and then have them working like they just popped out of the box...I think no one expects that
    Nov 2007
    This is a good one
    If only temps are just as cold here.
    Intel Inside
    Banned
    Aug 2007
    C:\Philippines\TPC
    how about doin some Prime runs
    Apr 2007
    That's awesome! Great chip + great board = clocks like the old P4 days!
    Mar 2005
    Imladris
    Nice chip you got there. You got a pair of big ones too......
    The little air system that could.
    Mar 2005
    Indonesia
    awesome clock on air
    what temp with those cooling, especially on 1.7v vcore?
    Team ODOC
    Jan 2006
    Copenhagen - Denmark
    Wicked 4,9 Ghz on air .. looks like a nice chip
    The trouble with doing something right the first time is that nobody appreciates how difficult it was
    Champion
    Jan 2007
    Romania, lab501.ro
    Thx guys
    emoners:
    I was more interested at hitting a max on air, rather than Prime runs. It does Orthos @ 4Ghz with 1.28v and 4,15Ghz with 1.33v, with normal air temps, as you can see here. Last night I was too concerned with breaking 5Ghz on air (which I didn't manage to do) and getting some nice air 3DMark runs, so I didn't have time for any stability tests.
    wedfighter I really don't trust the readings on the chip's sensor, they are totally off. CoreTemp 0.96.1 was not able to show below 34/28 in idle, which is a joke, it probably had something like 5-10 degrees
    HousERAT
    You like my big'uns, huh? Those are small 100cfm Sunons, you should see my 200CFM Minebea Matsua
    Aug 2006
    Romania-Timisoara
    eXtreme my friend.Very nice.Time for dice,right?
    Super fain arata Gemini ala cu 2 Sunoane pe el.Da-mi un pm pe crazy daca poti sa imi aduci unul si mie.Ms
    A64 3400+ | Asus A8V-VM SE | 1Gb DDR400 | wait for video | WD 320+500 | Chieftec 450W
    Jun 2006
    Great AIRCOOLING better water
    My Computer: CPU Intel i7 920@4 ghz 1.35 volt. MAINBOARD Asus P6t dlx. RAM CSX 2000. VIDEOCARD EVGA GTX 295 . H.DISK 2 x WD VelociRaptor 74 GB @ Win XP SP3 . POWER Zalmann 1000 Watt. CASE LIAN-Li A70 . INTEGRATED WATERCOOLING CPU Couplex + Rad V3 + MP655 + Vaschetta dual 5,25 . SK VIDEO EK + Rad V2 + MP655 + vaschetta 5,25
    Xtreme Guru
    Dec 2002
    salutarii! crazy oc
    lol @ books cine stie.. overclocks!
    Xtreme Legend
    Oct 2005
    Austria
    like i said in the other forums, awesome result bro, keep pushing it.
    Dec 2006
    Denmark, Horsens
    wow, Thatīs high voltage Well, great resultīs
    OCTeamDenmark Crew - Cooled and sponsored by CoolerKit.dk
    Feb 2006
    La La Land.
    Nice.
    I hope you dont mind my intrusion in this thread, didnt really felt like making another thread for this as even mine is same stepping CPU.
    You should have got better Spi time though.
    I have managed to push mine at 4815Mhz on air ( TrU120E ) @ 1.67v.
    Due to insane vdrop and vdroop I cant go above this on my Abit IP35 Pro.
    Managed to get 9.391s SPi run and a 3Dmark 2005/2006 runs. Sorry no screenie of 3dmark with me now. Will post them later.
    Here is my SPi score. and setup.
    Stepping is Q746A482.
    Its not this chilly here. 25°C ambient. Pretty much standard case config nothing special. Looks like a good batch.
    Primary Rig
    Intel Xeon W3520 @4200Mhz 24x7, 1.200v load (3845A935)
    Gigabyte X58A-UD7
    Patriot Viper II DDR3 2000 CL8
    Tagan BZ1300
    DeepCool Gamer Storm with 2x120mm DeepCool fans.
    MSI GTX 470 Twin Frozr II
    Zotac GTX 470 AMP edition.
    GPU collection : http://www.xtremesystems.org/forums/...5&postcount=64
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    2GBx2 Corsair DDR3 1333
    Tagan tg500-u37
    Arctic Cooling Freezer 7 Pro Rev.2
    XFX 9600GT
    Banned
    Aug 2007
    C:\Philippines\TPC
    Quote Originally Posted by Monstru View Post
    Thx guys
    emoners:
    ya i remember that post... i was just kidding
    we actually have the same chip but i can't seem to get those clocks at low voltages. what's your bios settings on your 4ghz at 1.28v run?
  18. #18
    Champion
    Jan 2007
    Romania, lab501.ro
    catalanu: Thx mate.
    Se gasesc ventilatoare din astea, o sa iti spun eu ce si cum.
    lukas69 Better Dice man
    NapalmV5: Salutare!
    Turrican & Giraffen: Thx guys!
    Funky: Well done bro! I know I could have had a way better Spi time, but I was more interested to get the highest clock possible on air. That's why, I didn't tweak, I used low mem clocks, I didn't even open memset to put some 4-3-3-3 at those clocks, an so on. Anyway, you've got nice results there , a little bit of cold would have helped you a lot
    emoners:
    Well....it depends on the mobo you are using. For the 4Ghz, if I remember well, on Maximus, I had very low volts on the NB, PLL and VTT, can't remember the exact numbers, but they were normal daily volts.
  19. #19
    Feb 2006
    La La Land.
    catalanu: Thx mate.
    NapalmV5: Salutare!
    emoners:
    hehe, we dont get cold here as such. I am from Mumbai in india. Costal area. We never get too cold here. This winter is coldest one in 40 years here and still the minimum temp was 10.4°C. This is as low as it has been in my life :P
    Usually even minimum temp dont go below 25 here. high to low 30s all time of the year except 1-2 winter months :P
    Primary Rig
    Gigabyte X58A-UD7
    Tagan BZ1300
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    Tagan tg500-u37
    XFX 9600GT
  20. #20
    Champion
    Jan 2007
    Romania, lab501.ro
    I know, I saw that you are from India. Maybe the only solution to get very cold on air is air conditioning (that is what I was thinking about).
  21. #21
    Dec 2005
    Athens,Greece
    Funky did you use setfsb or something like that?
    Because Abit from bios or uguru cannot set odd fsb only even like 534-536
    E8400 TRUE120@Asus Maximus Formula@2x2GB Geil Evo One 800MHz 4-4-4@Corsair HX 620W
    Sapphire HD6850 1GB@Samsung 830 128GB@Casetek 1022-5@LG 19" 1970HQ
    Creative Inspire 5.1 5100@Samsung SH-S203B SA@CM Quickfire Pro Red@Logitech G-600
  22. #22
    Feb 2006
    La La Land.
    nope, i dont use setfsb or any other windows based tool for that matter.
    My Ram chips are not great anyway so i have left them on 5-5-5-8.
    All is done from bios. 1.6 beta 04.
    Primary Rig
    Gigabyte X58A-UD7
    Tagan BZ1300
    Rig2
    Phenom II x4 965
    MSI 790GX-GD65
    Tagan tg500-u37
    XFX 9600GT
  23. #23
    Oct 2004
    Crazypc.ro
    c'mon monster get that 5gi on air!!! ooooo god plsssssssss make the weather colllllllllllllld as artic winter
    next weekend dry ice?
    bafta!
  24. #24
    Champion
    Jan 2007
    Romania, lab501.ro
    Thx man!
    No...I don't think that I will get that 5Ghz all air, I won't redo that set-up again. It's been nice to play like this, but there comes a moment in every man's life when he has to grab the dice pot and start to do some serious business
  25. #25
    Feb 2007
    italy ...Sasso Marconi (BO)
    System
    Evga 8800GTS 512Mb
    Antec EA500W
    Results
    3. 3D
    3DMark 2001 - 85663
    3DMark 2003 - 51689
    3DMark 2005 - 28148
    Excellent results Which bios you have used for Maximus Formula ?
