A little more clear shot of the inside:
Shots with flash:
And finally, my masterpiece, the 8 ziptie gpu block mount:
I never bothered to take pictures of my blocks, sorry to disappoint ya all. They're really ugly on the outside and the inside anyways :P
I also am aware that the tubes have green stuff on them. This is not algae. This is what happened after the minerals from the tap water I used the first time collected on the tubes, then the zinc on the screws that I didn't mean to have touching the water corroded and turned everything pink, then I cleaned it with lysol toilet bowl cleaner which is BLUE so it turned green![]()
