To keep from thread jacking the stacker case thread I'm just gonna start a build log here lol.
Main Rig
Corsair 620HX - Standby
DFIs LP UT P35 T2R - Standby
C2Q 9450 - Standby, awaiting release
G.skill DDR2 800 HZs - Standby
EVGA 8800 GT - Standby
2 x Seagate (PRT) 250GB sata 3.0s in RAID 0 - Standby
CM Stacker 830 Evo - On hand
WCing Rig
Pump: Swiftech MCP 655 - On hand
Thermochill PA120.3 - On hand
EK High flow barbs 3/8" thread 1/2" OD - In route
Fans (Yate 88CFM) - On hand
CPU Block: D-tek Fuzion - On hand
Dtek Fuzion Pro Mount set - On hand
Dtek Fuzion Accelerator Nozzle Kit - On hand
GPU Block: Swiftech MC@60 - On hand
GPU Ram: Swiftech MC8800 SMC Kit - In route
NB Block: Swiftech MCW30 - On hand
Res: Swiftech Micro - On hand
Swiftech high flow barbs - On hand
10 feet Tygon 7/16" ID 5/8" OD clear chemical tubing - On hand
Adding wire extensions to the fan wiring as I'm mounting the RAD outside of the case.
Testing to make sure I did not get my wires crossed.
All done with that, did not turn out as well as I had hoped due to the large bump where I soldered the extensions in at. I guess if I planned it a little better I could have offset where I soldered them in at so I could have fit the same size heat shrink tubing over it all, but o well.
Now I'm working on the mounts for the RAD but i'll do more of that tomorrow.
I'll add more as I get more done.
