As usual, XtremeSystems and OCForums is always the first place to get my review when it goes live. Instead of converting html to vb code I am going to simply quote the intro and link to the article. Hope you guys like...
UPDATE 1/18/08Seagate Barracuda 7200.11
1/17/2008
Author: Dominick V. Strippoli
"The Raptor Says to the Barracuda: I challenge you to a duel!"
Reviews of Seagate's latest SATA Barracuda iteration, dubbed the 7200.11 have been floating all over the internet claiming that the drive gives a Western Digital Raptor 150 a run for its money and than some. The new Seagate drive is offered in capacities of up to 1 TB, using the SATAII standard, and using a 7200 RPM rotational speed. A major difference in the latest iteration of the Barracuda is the upgrade to a 32MB cache/buffer. The onboard HDD cache upgrade to this size was unheard of in the SATA industry until Seagate and Samsung brought out these newer drives. The manufacturer is claiming a drive that seeks comparably to other top of the line large capacity drives. Seagate also claims sustained throughput higher than any other SATA drive we have seen so far. The drive specs are top notch on paper, and it seems to be a perfect candidate to put up directly against the infamous Western Digital Raptor 150. And so the Raptor says to the Barracuda: "I challenge you to a duel!"
Read the full review here: http://www.nextlevelhardware.com/storage/barracuda/
Just finished a small review on the 7200.11 Raid 0 Setup I completed:
Seagate 7200.11 (Raid 0 Results)
1/18/2008
We recently reviewed the latest drive from Seagate's arsenal: Known as the 7200.11 Barracuda. This drive proved to be an excellent competitor for the well known Western Digital Raptor 150. General performance of the drive was very comparable to the Raptor and ended up about 7% to 15% slower in every day tasks. On the other hand, when working with video/photo editing and larger file operations the Seagate 7200.11 had a very sizable 25% to 30% advantage. As highly requested by our readers, we have put together a very simple review article of the same 7200.11 drive used in a Raid 0 array. We will use the same testing methodology as our previous review and simply add one additional Barracuda to create a Raid 0 array. Once again, we will be using the Western Digital Raptor 150 as a comparison drive. In order to obtain the maximum possible sustained transfer rates on the drives, and the quickest possible access time we have limited our Raid 0 volume to a 50GB size and 128k stripe. This in turn will only use the first 25GB's (and fastest portions) of each drive. The remaining 440GB's or so, for the purpose of taking advantage of the Matrix Storage Controller we have chosen to create a mirrored Raid 1 setup. Since we have already reviewed the single Seagate 7200.11 in a full scale in-depth review, we are simply going to provide this introduction, a small conclusion, and solely hard results from our testing.
Read the rest of the article here:
http://www.nextlevelhardware.com/storage/barracudaraid/
