playing back some old school products, sooo crazy.
STT 800C5 2G*2 with Silver HS(85$).
J&W IP35-Pro (110$)
E8400es
Vista Ultimate SP1
1.95v DDR2-1090 5-5-5-18 ROCK STABLE![]()
single channel even better.
link: http://www.unihw.com/html/70/t-570.html
J&W IP35-Pro (110$)
E8400es
Vista Ultimate SP1
Very interesting.
Any chance you can do some extensive testing in 4x2GB configuration? I may consider to swap my G.Skill PC8000 for this. I am having real problem in stabilizing it at 2.0V 1000Mhz in 4x2GB configuration on P5K-Pro.
P.S.
By extensive testing, i mean Linpack 64bit - the most demanding CPU&Memory test ever known.
crazy low volts for those clocks, very nice![]()
Good chance this memory uses Power chips like G.Skill F2-8000CL5D-4GBPQ or something similar. So the results are the same as for those G.Skills on IP35 Pro, as reviewed by EnJoY.
This may also suggest that IP35-Pro has some feature which lets this memory pass some tests at high speed at low voltage (notice, i didn't say BE STABLE at high speed, as actual stability testing was not done). The most obvious "feature" is vdimm overvolting or some very relaxed sub timings set by motherboard on auto setting.
Or it's just some good design work. Who knows? Why do you more or less say the board has got to be of somehow bad quality just because noone has ever tested it before?I don't really get it. The board does look really good. The layout is clean and the parts look like high quality (sanyo oscon caps for example).
So why is it that you think it can't be that good? It could really overvolt vdimm or set some loose subtimings, but how do you know?![]()
And the RAM was never tested before either, so what's the point in saying "it's got to be like the one already tested, so the results can't be for real"?![]()
All i am trying to say we need more extensive testing, thats all. Not just Win boot or SPI 1m, but real stability testing. There may be a really HUGE gap between Win boot speed and actually stable speed.
are these available in the US?
WOW very nice!
Could have bought them :@
Anybody else tested this memory?
i have this modules but my msi p965 i think it don't support it it's why i wait for a P5K
i dont know how to put off the thing on the omdule... (i'm noob)
Great mem!
Going to buy them soon!
Now i´ve got 2 x 1Gb ST 800Mhz CAS5-5-5-15 Silver HS too...they do 1100 with 1.9.
i've heard it can get 1300i si excited for my p5k
nice volts!
24/7 Setup: Asus maximus x38 / E8500 E0 (500x8) Dtek Fuzion / Ballistix old rev 4-4-4-4 @ 1000MHz / 2900XT Ek fullcover cf / Silverstone TJ-07
Bench: Commando / Tpower i45 / P5K / E8500 E0 @ http://valid.x86-secret.com/show_oc.php?id=433935 / modded mach2 r507 / Old rev ballistix /
A friend of mine bought them today and couldnt pass 900Mhz with 5-5-5-15..
Nice clocks dude![]()
Well itīs a "value ram overclocking" topic so I will ask here, anyone knows if G.SKILL F2-6400CL5D-4GBPQ can do 510 with no problems?
Have you tried max mhz on 2.2V ?
my p5k is here
P5K Pro
E6300 with TT Blue Orb II ( vendetta)
8800GTS 320
Cooler Master Praetorien 731
Maxtor 200 and 80 go
WD 160 (OS)
Xp SP2
mine got 1000mhznot test more im afraid
P5K Pro
8800GTS 320
WD 160 (OS)
Xp SP2
