Page 1 of 6 1234 ... LastLast
Results 1 to 25 of 141
Thread: My retail 45nm Wolfdales - E8200 + E8400
    Banned
    Dec 2005
    Everywhere
    Chips are Retail, but OEM ...
    FPO: 750A, 745A ...
    ... on default voltage is max OC on Maximus Extreme only 3300MHz for both chips ...
    Maximum oc with safe voltage (max 1.45V in BIOS) real 1.38V is for both is about 3800MHz ...
    E8400 is not stable at 4GHz at any voltage ... this first 45nm chips are OCers like first Conroes ... nothing special!
    Xtreme Member godsfist's Avatar
    Nov 2007
    Yep I've had 2 E8400's and both will do 4GHz but I wouldn't call it stable
    And they both run much hotter than my E6750 at 3.6GHz
    INTEL CORE i7-10700K
    ASUS ROG STRIX Z490-E
    CORSAIR DDR4 3200 32GB
    MSI RTX 3070 VENTUS 8GB
    SAMSUNG QA65Q7FN 65 TV
    DARK BASE PRO 900 REV2
    DARK ROCK 4 HEATSINK
    SEASONIC PRIME 750W
    SAMSUNG 970 PRO 1TB
    CRUCIAL X8 SSD 1TB
    ADATA HD770G 1TB
    SENNHEISER HD598
    LOGITECH Z-5500
    LOGITECH K800
    ASUS RT-AC88U
    DEATHADDER
    Nov 2006
    ah sh*t. im nervous now.
    Multimedia:
    __________________
    CPU: E6600@3705MHZ : / Idle 40C / Load 62C / Zalman 9700
    MOBO: P5W DH Deluxe / Bios v1707 / Idle 39C / Load 45C
    GPU: ATI Radeon X1950Pro / (574 Core|688 Mem) Idle 48C @ 36% Fan
    RAM: 2GB OCZ XTC Gold 6400 OCZ2G8002GK 5-6-6-18 1GB OCZ Platnum 6400 OCZ1G8002PK
    Sound: Creative X-Fi Xtreme Gamer / Logitech Z5300E
    Keyboard: G15 | Mouse: G7 + MX518 | Display: Sceptre 20"
    Case: Silverstone TJ06 Sloppy Modshttp://www.xtremesystems.org/forums/...d.php?t=142817.
    HDD: WD160SATA / WD5000KSRTL SATA / WD 5000AAKB PATA
    DVD: Samsung SH-S183L (SATA) / Sony DRU-720A
    PSU: Thermaltake ToughPower 700W
    Laptop:
    __________________
    TravelMate 8204WLMi
    Intel Core Duo T2500, 2.0GHz ,667MHz FSB
    2 GB DDR2 667 RAM
    ATI Mobility Radeon X1600 51MB HyperMemory, 256MB dedicated GDDR3 VRAM
    120 GB 5400 RPM SATA HDD internal
    120 GB 5400 RPM PATA HDD external
    Game Machine:
    QX6700@ 3.74Ghz, GTX or HD2900XT?
    All the usual other crap.
    Nov 2007
    I'm going out tomorrow to see if 3rd time is a charm.. if I don't get no love the E6750 is going back in
    SEASONIC PRIME 750W
    SAMSUNG 970 PRO 1TB
    CRUCIAL X8 SSD 1TB
    ADATA HD770G 1TB
    SENNHEISER HD598
    LOGITECH Z-5500
    LOGITECH K800
    ASUS RT-AC88U
    DEATHADDER
    Dec 2004
    Bucharest, Romania
    You just need more vcore dude. Give it 1.55v and i suspect it'll have no problems at 4200 (on the 8400 that is).
    Intel i7 920 d0 @ 4410MHz @ 1.36v :: Prolimatech Mega Shadow :: Gigabyte EX58-UD5 F9K :: 6GB Mushkin XP3-15000 :: HIS 5870 :: Corsair 1000W :: HannsG 27.5" :: Lian Li V1010B
    Sep 2004
    West Covina. CA
    Why haven't you activated Vdroop control in the BIOS? I'm 100% sure that a maximus extreme has this setting. That should definitely get you somewhere past 3.8 ghz....
    I find it very odd that neither chip would do 4 ghz, though (please activate vdroop control first). Since most qx9650's can do 4 ghz at 1.4v or below, and these are from the same process, this doesn't mean that Intel is binning the dyes for the Extreme models, does it ? .......
    Later on, i'm going to check what vcore I need on my QX to do 3.8 ghz at the default fsb speed (333)...the last time I tested that, it was the 380 FSB on the 975x making the chip unstable (when 333 * 12 was stable at less vcore than 380 * 10)...
    Xtreme Cruncher
    Dec 2006
    Montreal, Qc
    Quote Originally Posted by AriciU View Post
    1,55V for a 45nm will kill it much faster than 65nm
    Main system:
    Q6600 G0 L737B 3,8GHz
    Maximus Formula X38
    Ballistix PC2-8500 2x1GB
    XFX 8800GT XT
    Corsair HX620
    X-Fi Platinum
    150GB Raptor (Dual Boot) /2x 250GB WD Caviar (Apps)
    Lian-Li V2000B Plus II
    School: MacBook
    Studying in: Pharmacy
    Where: University of Montreal
    Sep 2004
    West Covina. CA
    Did you read his post?
    He was operating at maximum SAFE Vcore. Why are you asking him to give it 1.55v on air? That's NOT a Conroe/Kentsfield 65nm he's using, you know! He's using Wolfdale/Yorkfield 45nm. (Yorkfield is the quad version, Wolf is the dual version). That can lead to a very dead, or rapidly degrading chip at those voltages without some sub zero. You DO realize that 1.55v through a 45nm chip is the same as 1.65v on a 65nm? Not many people are willing to put that vcore through these chips on air, for any thing besides a suicide run....
    Dec 2004
    Bucharest, Romania
    Well. I am willing too, i'm just telling him where the problem comes from.
    Apr 2007
    Sweden
    Yeah Loadline Calibration... it works well, and drops only about 0.02, and Load are stable, once you have the voltage there will be no droop at all..
    just figure it out, 1.57500 on my board are 1.55, and its the same with any vcore set, and there are no droop at all, stable as a rock.. try it ..set 1.47~ in bios and you will have your 1.45, and then get back to your OC and show us!
    Intel i7 920@ ???| Inno3D 8800GT OC Edition | 3x1 Corsair 1600 DHX | DFI UT-X58 | TT ToughPower 850W
    Watercooling: D-Tek FuZion V2, DDC Ultra Plexi top, PA120.3, MCW60, Ek's Res.
    Xtreme Cruncher
    Dec 2006
    Montreal, Qc
    These results are a little bit below expectations
    Main system:
    Maximus Formula X38
    XFX 8800GT XT
    Corsair HX620
    X-Fi Platinum
    School: MacBook
    I am Xtreme
    Sep 2006
    OBR can we have al ook at the temps plz if you run them eg at 3.6 or 3.8Ghz ??
    I just wanna see if these are really worth it , my friend wants to buy an E6850 I told him to wait till these babies popped up... my E6850 was rockstable at 3.8Ghz and benchable at 4ghz but temps were over 65°C under water with only 1.45Vcore (and IHS was as smooth and flat as a babyskin)
    If these are pretty hot too I will push him towards a quad...
    Currently I have an E2140 in the rig ( damn man a Vid of 1.375 ) and pretty high temps, really cheap chip ( lended to me awaiting my QX ) FSB wall at 362mhz and runs now happily at 2.667 speed but under prime temps run up to 55°C under WC...
    Question : Why do some overclockers switch into d*ckmode when money is involved
    Remark : They call me Pro Asus Saaya yupp, I agree
    May 2007
    Philippines
    Yes, they fall quite below the ES versions that have been benched on air.
    Rig Specs
    Intel Core 2 Extreme QX9650 4.0ghz 1.37v - DFI Lanparty UT P35 TR2 - 4x1GB Team Xtreem DDR2-1066 - Palit 8800GT Sonic 512MB GDDR3 256-bit
    160GB Seagate Barracuda 7200RPM SATA II 8MB Cache - 320GB Western Digital Caviar 7200RPM SATA II 16MB Cache - Liteon 18X DVD-Writer /w LS
    640GB Western Digital SE16 7200RPM SATA II 16MB Cache - Corsair HX 620W Modular PSU - Cooler Master Stacker 832
    Auzen 7.1 X-Plosion - Zalman ZM-DS4F - Sennheiser HD212 Pro - Edifier M2600
    Custom Water Cooling
    Dtek Fusion Extreme CPU Block - Swiftech MCR-220 - Swiftech MCP655-B - Swiftech MCRES-MICRO Reservior - 7/16" ID x 5/8" OD Tubings
    Dual Thermaltake A2018s 120mm Blue LED Smart fans.
    www.mni-photography.site88.net
    Banned
    Dec 2005
    Everywhere
    if i set 1.45V in BIOS, in idle i have in windows at cpu 1.43v ...butunder fully load 1.38-1.39 ... maybe is something with Loadline wrong ...
    Banned
    Dec 2005
    Everywhere
    Quote Originally Posted by Leeghoofd View Post
    test under water tomorrow ... but on air with 1.35V real voltage is in Orthos temp about 58C degrees ...
    Sep 2004
    West Covina. CA
    Wow...that definitely looks like "loadline" is NOT working....or not working properly....
    I had almost that exact vdroop on my P5W before doing the mod....With the mod, my idle and load voltages are 0.02v below bios setting.
    Your load and idle voltage should be virtually identical...
    4 ghz may be out of reach but if it could maintain a 1.42 vcore at load, you should have at -least- 3.9 ghz.
    Xtreme Guru
    Jul 2004
    Wow. Can't even hit 4ghz? were you drunk?
  18. #18
    Nov 2007
    Yeah on air I was getting around 60 degrees in Orthos on both of them
    SEASONIC PRIME 750W
    SAMSUNG 970 PRO 1TB
    CRUCIAL X8 SSD 1TB
    ADATA HD770G 1TB
    SENNHEISER HD598
    LOGITECH Z-5500
    LOGITECH K800
    ASUS RT-AC88U
    DEATHADDER
  19. #19
    Nov 2007
    Quote Originally Posted by trans am View Post
    You're not listening dopey, the retails are nowhere near as good as what you've been seeing from the ES
    SEASONIC PRIME 750W
    SAMSUNG 970 PRO 1TB
    CRUCIAL X8 SSD 1TB
    ADATA HD770G 1TB
    SENNHEISER HD598
    LOGITECH Z-5500
    LOGITECH K800
    ASUS RT-AC88U
    DEATHADDER
  20. #20
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by godsfist View Post
    I know. I was just joking with OBR> Sorry your chips suck man.
  21. #21
    Banned
    Dec 2005
    Everywhere
    i can run every benches at 4050MHz ... but not Orthos stable
  22. #22
    Xtreme Guru
    Jul 2004
    Do you have 45 nm quad to test?
    did both max out around 3.8? Just curious since E8200 is very inexpensive.
  23. #23
    May 2007
    Philippines
    so the 4ghz 24/7 use is far from reality again, isn't it?
    Rig Specs
  24. #24
    Jan 2005
    As long as the new quads (Q9450 really) see 3.6Ghz+ on air, Im all over it.
  25. #25
    Nov 2007
    Quote Originally Posted by fireice2 View Post
    I hate the silicon, on one E8400 one of the cores is 10+ degrees higher than the other one.. and the other chip both cores are the same but hot as hell, like 15 degrees hotter than my E6750
    SEASONIC PRIME 750W
    SAMSUNG 970 PRO 1TB
    CRUCIAL X8 SSD 1TB
    ADATA HD770G 1TB
    SENNHEISER HD598
    LOGITECH Z-5500
    LOGITECH K800
    ASUS RT-AC88U
    DEATHADDER
