01-04-2008, 05:18 PM
#1
Let's Hunt and Seek for the TLB bug? ;)
Hi guys.
Well, first of all, sorry for my poor english.
I choosen to create this topic here, because a guy here on Brazil tried exactly that: to sistematically hunt down the TLB bug. He had some success on it, but, unfortunatelly, got robbed during the holidays.
The, I've choosen to translate to here his findings, since there is a lot of people here who have phenom processors, ability to oc them and many differente MBs, chipsets and bios versions available.
The original topic (in portuguese) is this: http://www.forumpcs.com.br/viewtopic.php?t=227912
The last update to his findings, translated down here:
Originally Posted by Schakal
Locking a Phenom? Tests Results:
Hi!
Firstly I would like to acknowledge for all suggestions and say that this testing even surprised me, due to two unnexpected events.
Another observation:
In all tests, I've used the configuration below (unavailable anymore), but with differente video card and ammounts of RAM. The video card used was my old X 1950XTX and the system memory was 4Gb (4x1Gb) made of Corsair CM2X1024-6400. In all possible configurations tested, I've didn't used oc to not missinterpretate them as oc issues.
NelsonK wrote:
From what I could understand, the error (system lock) happens in specific condition of L3 cache memory usage, and seems to happens with increase frequency when one uses some kind of virtualization program.
That's right. I won't specify more here, in order to create some "suspense", but indeed, I could not find a "less frequent" bug occurency, what means, I could only find it when using VMs.
Well friends, let's go to the testing!
Test 1 - Super PI, Shrink and WinRAR
In order to flood the CPU totally without having less than 100% usage moments, each core had to executde a 32M superpi calculation Moreover, winrar archiving processes, and dvd shrink video conversions were performed at the same time.
Result: 100% of cores usage and no bug.
Test 2 - Test 1 + Cache Benchmark:
Simulating the previous test with pc wizard, an extra cache bench was performed.
Test 4 - Prime95
4 instances of Prime95, one in each core simultaneously.
Teste 5 - VM 1
With VMWare, I created and emulated a common VM with Windows Vista HP 64bits. In this VM I've made all previous tests, except fourth.
Test 6 - VM 2
With VMWare, I created and emulated a common VM with Windows Vista HP 64bits. In this VM I've made all previous tests, except fourth. A curious event happened: The computer restarted AND one of the VM corrupted. Accordingly with windows events log, something happened with "svchost.exe", what weemed curious cause nothing have ever hppened there.
Result: No 100% of usage on the 4cores, bug didn't happened and something new appeared: the only single 32bits VM that I can't emulate over 64bits is Vista HP. Already tested installation disk, hadware, etc, and nothing
Off-Test=Any clue on this one?
Teste 7 - VM 3
With VMWare, I created and emulated two common VMs with Windows Vista Ultimate de 64bits. In these VMs emulated all tests up to test 3, but I've defined two cores/VM.
Teste 8 - VM 4
With VM Ware, I created and emulated four common VMs with Windows Vista Ultimate 64bits. In these VMs emulated all tests up to test 3, but I've defined one core/VM.
Result: Is that you, BUG?
In test 8, the CPU reinitialized sponteously when, according with the system manager, the cores 1 and 4 reached 100% of usage, core 2 50 % and core 3 a bit more than 80%. I've started to emulate the tests on the VM #3.
Looking for information on the four logs availabel, absolutelly no information on this subject was found.
For a happy coincidence, I've turned off Cool'n' Quiet and did test9:
Teste 9 - VM 4 WITHOUT Cool'n'Quiet
Exactly as in test 8, but with Cool'n'Quiet turned off all time.
It may seem really odd, but without Cool'n'Quiet the CPU executed all tasks normally.
Gone sleep.
In the morning, a few extra tests like 9 using prime95 and all other programs with the 4 VMs. No bug at all. And 100% all 4 cores, as would be expected because emulating 4 VMs is a big job.
Conclusion:
4 VMs + Cool'n'Quiet = BUG
What do you guys think about trying to systematically try to find the TLB error? I admit, that's an odd thing to try, but now we have an initial "systematic way" of trying to do it.
Does it worth the effort? I would think so. But, of course, it's up to you all here.
01-04-2008, 06:43 PM
#3
It's not my hardware.
My house is about to be "unrobbable". :P
And yes, I've seen that thread, were everybody just say it have never been seen, and that the bios fix is     . This thread is somthing differente: Try to see the bug happening, in a reproductible way.
Anybody?
01-04-2008, 09:10 PM
#4
Xtreme Mentor
Yes, virtualization is what the K10 core TLB is most optimized for since K10 took it into hardware (thus why its better and was one of its key advertised and selling features). Hence why the cores were recalled, since virtualization is the biggest raw server market to cap at the moment.
I've already tried all reproduction of the bug for my own curiosity. I use Linux quite a bit through Windows Vista nd XP, and have ran 3 VMs (Ubuntu/Slackware/Gentoo), a game, Firefox (68 extensions, 12 sites open, incl. Youtube and YouOS), Thunderbird (~42 extensions, 31 3yr plus email accounts, 12 feeds (plus 400MB each)), POV-Ray 3.7, Office document, (total 2GB full, 1GB into pagefile), 100% core usage but nothing appears.
Errors are not the bug though. A lockup in extremely heavy load virtulaization will be the bug (more than with Prime95 - check watt meter/temps) and I don't see the need to go hunting for it if you've tried P95 in-place large FFT and EVEREST FPU (tests) because those place the maximum load on your Phenom CPU from my testing possible on the desktop. Orthos max is around 12W lower load. Can you ever get more than that beyond Intel TAT on any day?
In either case, for me it is the same as any errata you weren't openly told about. Pointless for us unless its afected you. Any normal software won't reproduce it unless its virtualization and you can get a consistent heavier than max P95 load with it and in that case, it'll be reproduible at stock clocks. No need for oc.
01-05-2008, 02:03 AM
#5
Hey from what ive read and heard is that Linux is unafected ....It will only bug on Non Linux OS'es...Im not 100% shure of this though...I always though if there was a TLB,,bug it could be present on any Os because its in the Chip?
Oh well i want a B3 and 3.5ghz ill be happy
__________________
"Phenom,...Like the perfect Storm,...Everything needs to be just right"
X550x4BEeeast@4160mhz@1.56v ..........
Oh Fun 720BE X4 3700mhz,,X3-4ghz @ 1.62v
655pump/MXII/FlowModded D-Tek.Idle.@26c.Bad@$$
VisionTek 3870x2(stockAir)945//2200 bothGPU's
GTX260/216 my backup
01-05-2008, 02:49 AM
#6
Xtreme Mentor
The workaround applied for Unix based OSes doesn't affect them as much as with Window -> yep.
3.5GHz retail or oc?
Maybe that's a bit too much to ask of Phenom looking at it right now. 3.5GHz stable is like top 6400+ on air, actually most on water do 3500-3600 stable max. So that would indeed be very good. I know 3.5/3.6GHz sounds good (  ) but you should rather base your expectations on performance you're after rather than speed figures. I mean by B3, bear in mind Penryn quads will be running at 3.8-4.2GHz air and performance that comes with it.
I've never been the crazy type to look at others though. I only change a system if I feel the need to and if it's well worth it to me to keep me throughout 12-18months, not because something better/faster is out. Heck, I'd be in red in every bank account if I did that with just one thing of millions in life and would have to resort to fraud all the time.
01-05-2008, 12:56 PM
#7
KTE: the point in trying to find it is: if I can't have it even searching for it, what's the possibility of that happening on a desktop in normal usage?
It's supposed to be the kind of a test to, if one can find and reproduce the bug "ok, THIS is the ONLY SINGLE THING one should NOT do", and if not finding it, "Com'on, I did ALL THIS and this     ing bug didn't appeared, it's absolutelly pointless to take it into consideration".
For me, it's looking like that it's easier to lock a linux system due to a linux bug in a reproductible way among different distributions than finding the so much mentioned phenom bug once!
01-05-2008, 01:21 PM
#8
Xtreme Mentor
VMWare with Linpack is a b1ch to set up or I would've ran it to test. Theres no point going further than that for me. I'll run Linpack on the BE in Linux and XP and maybe in Vista too (if I can) soon.
To answer your 1st qs: like all reviewers, testers and AMD officials have stated so far, you won't be able to replicate it on the desktop with normal software max loads. They have all tried to do so too and so have we and ultimately failed as expected. In CPU development QC, the standard stability testing is far far higher and more extreme/lengthy than what we can do on the desktop, and these chips on retail passed that perfectly fine. Hence why it was hard and late to be tracked.
01-05-2008, 03:19 PM
#9
Does VMWare workstation use hardware virtualisation? I think it's pure sw-virt.
VMware's latest ESX/GSX Servers user hardware virtualisation and should also use the latest virtualisation features available in barcelona (think also phenom) prozessors.
01-05-2008, 04:33 PM
#11
D.F.I Pimp Daddy
Personally I think this sh**t is blown way out of proportion with these Phenom Processors!
__________________
D.F.I LanParty DK 790FXB-M3H5 ~ 7/27/2009 ~ "Beta" Bios
AMD Phenom II 720 Black Edition ~ For Bios Testing
Custom Water
2x2gb Crucial Ballistix Tracer 1333mhz 6-6-6-20
POWERCOLOR AX3870 X2 CROSSFIRE
ULTRA X3 1000w
Danger Den Torture Rack
01-06-2008, 08:32 AM
#12
Banned
Maybe, but Phenom is still shít.
I had mine, within 2 weeks I was sick of it, sent it back.
AMD have got a cheek to release such a processor, in this day and age, clocked at 2.3Ghz? Nearly 2 Years later than Intel's offerings and it cannot even compete?
They done a microsoft by ditching support for 939, which at the time was the most stupid, retarded and thick thing to do.
They now release a processor which is slow, bugged and expensive + it isn't really much faster than K8!
The future is bleak for AMD and this is from someone which is most defintaly is not a fan of Intel.
01-06-2008, 09:34 AM
#13
Xtreme X.I.P.
dont forget k11 is delayed/cancelled and so is 45nm
__________________
Nvidia: Tesla C2050 and C2070 products (GT300) will retail for $2,499 and $3,999
JHH (Nvidia) sep 2009: The best way to always be the number1 is to have no backup plan link
JHH (Nvidia) nov 2009: Tolerance for failure is important, it puts our employees in a position where they are willing to try new ideas link
Solus Corvus - maybe things would get better if people addressed the content of each others posts instead of trying to discredit each other with insults and poisoning the well. Attack the argument not the person.
Hail Voltage! The Solution to AND Source of all our Hardware Problems
01-06-2008, 10:08 AM
#14
yup k12 and 32nm here we come
i hope....
__________________
cpu- AMD Phenom II 940 @3.0ghz...... for now
Asus M3A78-T 790GX
2x HD4870 cat 9.2
2x 1gb ddr2-1066
corsair 750 Watt
CM690
Originally Posted by perkam
Even McDonalds wouldn't hire Hector, at the risk of him reducing the efficiency of the burger grill
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
