Results 1 to 25 of 595
Thread: M3A overclocking
Threaded View
    Sep 2007
    Munich, DE
    M3A issues and benchmarks
    I finaly recieved my M3A mobo last week and as there is no oc thread for that board i'll start one.
    The Asus FTP Site with Bios Updates is here or here.
    Asus Forum(no Asus tech support in there).
    Found another thread about the board at legit review here and another one at techPowerUp here.
    If you have trouble with the onboard soundcard read this thread on majorgeeks.
    There is only one Bios version (0301) available atm. Now this bios has very limited options to oc a new phenom cpu but it did not that bad with an AM2 cpu. The bios does not include the tlb fix.
    The board uses an new clock chip (IT8716F-S 0737-DXS), for whom i could not find a tool to modify the ref HT under windows.
    AOD allows only cpu core multi and ram timing modifications with this board.
    With a phenom cpu it is not yet possible to modiy the cpu multi in the bios if cool'n'quiet is disabled.
    Also i was unable to boot with prozessor voltage set to anything beside Auto.
    In terms of ram timing modification this board has more to offer than it's ancestor M2A.
    If an AM2 cpu is in use or an AM2+ cpu is in use it allows setting CAS/TRCD/TRP/TRAS.
    If an AM2+ cpu is used it allows those settings
    With M2A-VM it was possible to ramp up the cpu voltages up to 1,55V + 100mV. M3A has no +100mV option so the max cpu voltage is 1,55V.
    Ram voltages can be bumped up to 2,25V in oposite to the 2,1V max the M2A-VM did.
    So overclocking phenom's with this bios version is a no go atm. No tools under windows and very limited bios settings.
    I tried to oc an BE-2400 (2,3MHz, 65nm, G0) via bios settings and found that the board can boot with an ref HT ~340MHz (M2A-VM ~300MHz).
    With 1,55V cpu voltage i was able to reach around 3,35MHz (M2A-VM maxed out ~3,2MHz with 1,6V) with watercooling. Not really stable but i could run super pi.
    11,5 x ref HT 292
    10 x ref HT 320
    Overall the cpu oc'ed with lower cpu voltages than on the M2A-VM.
    At legit reviews i found those posts:
    Well the 6400 has like no overhead for over clocking but I clocked it stable to 3.52 in like 5 minutes using AI overclock. Just set the AI overclock to manual, increase the FSB to the freq you want and the board adjusts appropriately. I can't say how it'll work for a larger over clock on that cpu. I did stick in a X2 4200 that runs at 2.2, did the same thing, bumped it up to FSB 240 Multiplier 11, gave me 2.64 ghz, had to bump the vcore one notch and drop hyper transport to 4 and it ran stable on orthos for an hour. I started with AI over clock, ran a little funky, so I manually bumped vcore and dropped hyper transport ran good after that.
    Hey Ken, I dropped multiplier to 10x and pushed FSB to 360, got 3.6 stable 15 minutes then temps started to creep (55C), ordered a ThermalRight 120 Ultra and A Vantec Stealth 120MM today. Should solve Temp and noise problems. Had it up to 3.52 with 16x stable same thing temp creep. The IceTank cooler does fine until you put full load on. I'm waiting until the cooler comes in before I push it (for my sanity's sake).
    One sidenote: The board works flawless with Linux, no noacpi noapic irqpoll options where required to boot. I like that.
    Waiting for a new bios with better phenom oc capabilities now.
    Last edited by justapost; 01-18-2008 at 03:29 AM. Reason: No real overclocking possible
