Results 1 to 25 of 50
Thread: Project: V300 H2o Extreme
Threaded View
    Dec 2007
    Cool Project: V300 H2o Extreme
    Looking to modify this this fine Lian Li Case to fit a decent water kit in there.
    Project Started - Rad being fitted to the case.
    First time watercooling and all parts have been recommended.
    Shopping List: (ALL PARTS BOUGHT/ORDERED UPDATED SPECS!!!!!)
    Gigabyte GA-G33M-DS2R MATX
    Intel Q6600 Quad Core
    OCZ 4GB 2x 2x1GB 9200 Flex RAM
    XFX 8800GTX
    Seagate 7200.11 500GB 32MB
    Samsung DVD-RW SATA
    Corsair 620W Modular PSU
    Lian Li V300b
    Water:
    Laing DDC 10w (Alphacool Top + 1/2" Barbs)
    EK Supreme CPU Acetal
    EK FC8800GTX
    D-TEC G1/4" 1/2" Barb x2
    Yate LOON 120mm D12SL x2
    1/2" Tube Clips x10
    Feser One (Purple dye)
    Repack-cooling Slot Black UV Res (no longer being used as it may conflict with the placement of the gfx card)
    Masterkleer 7/16" Tubing 4'
    AC Ryan 2x 12" Blue Cathodes
    Laser Cutting Click for Design or Read On
    MagiCool 240 UV Radiator (Only one that fits in the case same make as XSPC)
    With a total cost of about £1,100 this should be an interesting build.
    Trying to fit a double radiator in a normal case can sometimes be hard,
    so this Small Form Factor case should be a challenge.
    Be sure to watch this space for updates.
    StevenG
