Page 1 of 2 12 LastLast
Results 1 to 25 of 43
Thread: "New" AMD Overdrive Beta out
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
    Xtreme X.I.P.
    Apr 2005
    Can you disable TLB errata fix with that thing?
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by Cooper View Post
    Not in this version...
    Luckily Gigabyte added option to the BIOS for DS5 and DQ6 motherboards .
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Dec 2006
    Still not working on the Asus M3A motherboard, I also get different readings from AOD and cpuz as to the speed that my Phenom chip is running
    Xtreme Mentor
    May 2007
    Thank you, oh Brother.
    Quote Originally Posted by Thesavage View Post
    Can you give us a screenshot of how much difference there is between them please?
    D.F.I Pimp Daddy
    Jan 2007
    You're Welcome my Son
    SuperMicro X8SAX
    Xeon 5620
    May 2006
    Philippines
    Works perfect for me on my M3A!
    D.F.I Pimp Daddy
    Jan 2007
    Yah...so far so good on my End but only been brave enought yo look at it so far
    SuperMicro X8SAX
    Xeon 5620
    Nov 2007
    philippines
    has anyone got temp reading?on my 5000+BE it doesnt show up...
    AMD Athlon 64 x2 6000+ AM2 CCB8F 0740 FPMW
    MSI K9A2 Platinum v1.2
    4 x 1GB Corsair XMS2 (rev 5.1 and rev 5.2)
    Zalman CNPS9700LED
    PowerColor ATi HD 3870 512MB DDR4 256bit PCIe 2.0
    Corsair TX750 Watts (12v @ 60A on a single rail)
    80 GB WD SATA I (primary)
    250 GB WD SATA II (backup)
    Xtreme Mentor
    Nov 2005
    Devon
    Quote Originally Posted by madfaze View Post
    Works well for me (At last)!
    Click image for larger version.
    Nov 2007
    philippines
    what does southbridge speed pertains to...
    Zalman CNPS9700LED
    Dec 2006
    Quote Originally Posted by bro20000 View Post
    bro20000
    Your board is the M3A32 and not the M3A from your screenshot slightly different chipset, will upload images as soon as my account gets activated @ imagehosting
    Xtreme Mentor
    May 2007
    LOL!
    Loving this new one already. Props to AMD and Sami's team since this one is only 22MB in memory usage, very light, quicker loading, displays every info correctly (apart from what I mention below), switches tabs faster (more responsive), displays temps real-time and as accurate as anything I know. The gadget is a real oc/monitoring dream tool. Even picks up southbridge speed and volts too.
    However, some of the voltage readings displayed labels before (when it did not detect properly) whereas now they read some very weird labels that I cannot dicepher thus understand.
    This is 1.33V 2.42GHz / 1.98GHz NB/HT / 440MHz RAM on WCG (100% load) since the 17th AOD measuring Core Temps along with HWMonitor and EVEREST.
    Nov 2006
    Ok Overdrive for newbees, I DL the new version to try and it wants me to have a AMD-7 Chipset, so I can't play if I have a Nvida chip?
    Banned
    Aug 2007
    C:\Philippines\TPC
    Nice info Campbell! hmmm just curious...does it work on other procs/chipsets too?
    Xtreme Mentor
    Nov 2005
    Devon
    I just discovered that this AOD beta can adjust CPU vCore even if I set non-default in BIOS!! That is brilliant!!
    Before if I selected 1.3V in BIOS I couldn't change it from AOD...
    Xtreme Mentor
    May 2007
    Mine is weird. If you change VCore in BIOS, it doesn't change but AOD can change it all the way to ...
    There are some quirks with it yet though. But I have more problems now with my BIOS than AOD.
  18. #18
    Xtreme Mentor
    Apr 2005
    This is really amazing little until! So it's time to pick on small annoying things
    For example I would like to see mem. freq. displayed in DDR value. For example: 1066 MHz instead of 533 MHz.
    This would be especially useful for "Wannabe" O'Cers with real operating values.
    Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
  19. #19
    Aug 2007
    Warren,MI
    Quote Originally Posted by sstrokerace View Post
    correct. you can only use it with AMD/ATI cpus and GPUs and only on the 7 series chipsets.
    cpu- Intel I7 3930K
    Asus P9x79 Deluxe
    2x HD7970
    32gb ddr3-1600
    corsair ax1200
    Corsair 800D
    Corsair H100 lapped
    2x 128gb M4 raid 0
  20. #20
    Fused
    Dec 2003
    Malaysia
    Quote Originally Posted by KTE View Post
    http://img153.imageshack.us/img153/2307/aoddz3.jpg
    nice... Now click APPLY button
  21. #21
    Xtreme Mentor
    May 2007
    I have to increase MHz up to 2.6-2.7GHz before it accepts high volts plus 1.4V. Tried it many times before, it will keep resetting them to lower.
  22. #22
    Nov 2006
    Quote Originally Posted by knightwolf654 View Post
    Thanks for the answer!
  23. #23
    D.F.I Pimp Daddy
    Jan 2007
    OK........New Beta is Not working as thought and more than likely is due to needing Bios Update for this Motherboard
    SuperMicro X8SAX
    Xeon 5620
  24. #24
    Xtreme Mentor
    May 2007
    Can anyone(many) using AOD post screenshot of this section showing their volts/temps/labels please. Much appreciated.
    Name your CPU/MB too please.
  25. #25
    Banned
    Dec 2007
    Most likely inside my PC :)
    PHENOM 9500 | MSi K9A2-CF
